Good tie down spot
Discussion in 'GS Boxers' started by Menachem, Apr 25, 2012.
  1. Menachem
    Menachem Been here awhile
    Feb 20, 2009
    194
    Boston,MA
    Would this be a good tie down spot for the front? Didn't seem to compress the suspension much but it's very secure in the condor.
  2. Snarky
    Snarky Vodka Infused.
    Feb 24, 2011
    1,364
    Old El Paso and Swamp Houston
    That's what others seem to do...I might put a soft rag between the straps and the bike.
  3. SCflyer
    SCflyer Long timer
    May 25, 2007
    1,859
    Back in NC
    Why not use the crash bars towards lower front at the weld? I put tie downs on each side of the rear to "center" it and one on either side up front. Just gotta be sure to get the bike fwd with the wheel against a board...
  4. SiouxsieCat
    SiouxsieCat Been here awhile
    Mar 22, 2010
    243
    KCMO
  5. Snarky
    Feb 24, 2011
    1,364
    That's an old document: 1999. On my bike, the service manual actually recommends soft straps on the fat bare metal parts of the handle bars and the rear swing arm. I'll post a picture in a thread this weekend when I get to my shop computer.
  6. Mike Ryder
    Mike Ryder Kriegerkuh Supporter
    Oct 11, 2003
    2,021
    Peachland B.C. Canada
    You are not able to compress the suspension at all when tying the bike down that way.
    That is a good thing.
    The suspension can still absorb road shock and damp it out for you.
    That is also good.
    The brake lines are there so make sure you are not pulling on them.
  7. Raven Rider
    Raven Rider Been here awhile
    May 3, 2010
    267
    Mesa,AZ
    I did it this way in my toy hauler without a front or rear block for the wheels to rest compress against with 0 problems and I went on a 4000mi trip and over many very ruff 4X4 roads. No problems at all.
  8. Yankee Dog
    Yankee Dog Long timer
    Jan 31, 2008
    2,242
    Decatur, AL
    right on the money. that is the way I started doing it a few years ago. ZERO problems.
    when ties come loose it is usually because they loosen and tighten as the suspension bounces up and down. If you attach above the suspension, like the bars, and you are so tight there is no bounce then you are likely to bend something.
    #8
  9. gonzo2k
    gonzo2k Adliberator
    May 3, 2007
    331
    Belford NJ
    I bought my bike during an open house at Cross Country BMW in 06.
    I asked about the R1150GS Adventure... they had an 04... but no one knew where it was.
    Turned up in a trailer for a demo on the proper way to tie down bikes for transport.
    Fork tubes for the front tie downs is the method used. That's my way of doing it.
    I use the frame loops near the passenger pegs for the rear straps.
    #9
