-   Sports (http://www.advrider.com/forums/forumdisplay.php?f=72)
-   -   Bicycle thread (http://www.advrider.com/forums/showthread.php?t=150964)
pierce 06-14-2010 04:46 PM
Originally Posted by Zodiac
only new parts are tires, cables, chain, and rim tape.....
like bringing an old dog back to life...:D
what about the fixie sprocket? or was that recycled from something else?
Zodiac 06-14-2010 04:47 PM
it's a freewheel (16) that I had in my tool box.
EvilGenius 06-14-2010 05:42 PM
I found the leak in the tube, I guess it might be a defect in the manufacture of the tube or something, I don't know. It's just a tiny little hole, completely invisible until you do the bubble trick. I couldn't find any sort of puncture in the tire itself or the spoke band on the rim.
I guess I'll swing by the LBS tomorrow since I'll be in the area and grab a tube patch kit.
What do you guys think of the self sealing tubes or that slime type sealing stuff.
Worth it or a waste of money?
EvilGenius 06-14-2010 05:45 PM
Originally Posted by Gummee!
Barends are gonna go at the same angle as yer hands so that's irrelevent. :nod If yer grips have ends ala the Oury-s up above, take a hammer and 'core' em. Some Windex sprayed under the ends makes em move easily. Take a small screwingdriver and roll it around under there to make the Windex go where ya wants it. :nod Move everything in about 1cm +/- and yer good to go.
HTH
M
If you were to sit on my bike the grips would be at this angle to you, which would put the bar ends at that angle.
I dunno how that'd work.
:scratch
http://www.intownbicycles.com/images...e-bar-ends.jpg
Gummee! 06-14-2010 06:00 PM
:scratch
The barends are angled to make em stick out at the appropriate angle. :norton
M
Gummee! 06-14-2010 06:01 PM
Slime, etc works fine for small holes. Typically whatcha get. Adds weight tho. Going for speed it ain't the best thing to do to add weight in the tires/wheels. Comfort? Who gives a rat's behind?
M
pierce 06-14-2010 06:08 PM
M
he's got bent comfort bars, not a straightish T bar. the bar ends are angled back, so I'd expect that would make the bar extenders angle out. fugly.
EvilGenius 06-14-2010 06:30 PM
Yeah, like I said the bars I have now are fine for a leisurely ride, but trying to cover distance the angles get old. Which is why I was looking at either finding a road style bar that might fit, or just using a straight bar to make a T setup.
kojack 06-14-2010 06:30 PM
Im breaking out the old mtn bike too. finishing off the xtr grouppo on it, adding new wheels, tires, cables, seat, post and steering stem as well. might as well ride it! I may build a time trials bike for fucking around with too...damn two wheeled machines!
Gummee! 06-14-2010 07:31 PM
Two letters: X0
Mmmm 2x10 Works great for 26" wheels
M
edited to add: if its M900 stuff, lemme know. We may be able to work out a deal.
Mercury264 06-14-2010 07:40 PM
fully torn down and rebuilt, every bearing, every screw, every thing.
From death row....
http://cdperry.smugmug.com/photos/890758573_dyMDV-L.jpg
to spanking tight hood lock up outside grocery getter bike....
http://cdperry.smugmug.com/photos/901285193_UsYrS-L.jpg
http://cdperry.smugmug.com/photos/901284935_K9iuJ-L.jpg
Sweet :clap
What does it say on the crossbar there :ear
pierce 06-14-2010 07:50 PM
Originally Posted by Mercury264
Sweet :clap
hahahahaa.
* NOT THE DROID YOU'RE LOOKING FOR
http://cdperry.smugmug.com/photos/901284935_K9iuJ-O.jpg
skibum69 06-14-2010 08:00 PM
Originally Posted by Dahveed
Good video! Enjoyed watching it. Nice editing job. Clever how you removed the front end of the bicycle for easy carrying! :lol3
yeah, turns it into a 2 person bike that way without even having to ride it:lol3
ducnut 06-14-2010 08:13 PM
Also, I just got my first flat.
I can't find the hole, but it went down pretty quick.
The original tires are 700/35C.
The rim is 1" OD wide and 13/16" ID wide.
I was thinking about maybe a 28C?
I know real road bikes go as low as 24-23mm but I still want some shock absorbtion due to some of the terrain I ride on.
Brand/type/size?
I think body position is going to make a bigger difference than tire width. A 35mm to a 28mm is only 7mm. On a bike configured like yours, you probably won't feel much change. On an efficient bike, you probably would notice it, though. While you're getting a patch kit at your LBS, why not ask them about your options to mount a road bar. You're working in inches and all the higher end stuff is metric. I'm guessing somebody still makes chromed steel, road bars like my teenage ten-speed had. Then, you've got lever issues to tackle. Maybe look around yards or shops for junk ten-speeds for parts. Having someone at the LBS looking directly at it, with knowledge of bikes, is going to be much easier than fishing this forum. We all want to help with parts and advice, but, it'd be much easier to have someone standing there telling you exactly what you can do, right then.
Thinking out loud: There are several companies that make low rolling resistance tires in 28-35mm. However, the cost is over $100 for two. Again, the budget versus benefit is not in your favor.
minimize your rolling resistance by keeping the tires near their upper pressure limit.
Here's an article on tire pressures.
I'll have to respectfully disagree with running tires at their pressure limit. At a velodrome, that's fine because you're on a glass-smooth surface. However, on pavement you'll actually slow down. I've tried higher pressures during TT events and lost time that I could feel and see on my computer, when I encountered bumps or rode on less than perfect surfaces. My GF has said the same thing during her tri events. Also, Maxxis has been fighting the max pressure myth with instrumented data, as they found the same result. The pressure chart in the article seems to be pretty close.
Zodiac 06-14-2010 09:15 PM
hahahahaa.
I was hoping someone would get that....:evil
-for this old rig, it works so well - hopefully a cool bike thief will think it's cleaver enough not to poach it out of respect.... or something:lol3
Times are GMT -7.   It's 09:36 AM.
