-   Trials (http://www.advrider.com/forums/forumdisplay.php?f=73)
-   -   TL125 super hard clutch pull, "Now What" (http://www.advrider.com/forums/showthread.php?t=767517)
More CowBell 02-25-2012 12:41 PM
I got a 74 TL125, it runs great. I want to set it up for my daughter but the clutch pull is way too hard. I got a an easy clutch but didnt make hardly any differance. Can I put in lighter springs? Has anyone else did something to lighten it up?
Twin-shocker 02-25-2012 01:14 PM
I take it you have already fitted a new cable?
welder 02-29-2012 07:21 PM
lengthen the actuating arm on the cases
anonny 03-03-2012 09:55 PM
Oil the cable and grease the moving parts, it will make an amazing difference.
Twin-shocker 03-04-2012 09:38 AM
Not as much as renewing a damaged or worn cable...................
buls4evr 03-06-2012 10:12 AM
Or putting on a new cable from Motion Pro, an EZ Pull and lengthening the arm:clap.
trialxls 04-12-2012 11:20 AM
You can solder /screw a lever extension...
http://i29.servimg.com/u/f29/14/99/78/75/dscn0044.jpg
trialxls 04-12-2012 11:38 AM
Hi,
I tried to answer with a photo, but I am not sure I'm allowed, because it's my first post; I just found this forum today: I am french and offen on honda-125xl dot com forum...
You can solder or screw an arm extension on engine side: I did it on my XLS to get more progressivity ...
Shercoman 04-12-2012 03:20 PM
If a new cable and lubing everything doesn't work....
We used a Magura hydraulic clutch kit on my wifes 400EX to fix this issue.
Pulls with one finger now.
Probably no kit for this bike but a simple bracket to mount the slave cylinder would be easy to make.
Twin-shocker 04-12-2012 11:53 PM
Chinese pit bike hydraulic clutch kit may well fit, and is only about 1/10 of the cost of the Magura ones.
Shercoman 04-13-2012 10:41 AM
Where do you buy those?
Times are GMT -7.   It's 09:44 PM.
