-   The Garage (http://www.advrider.com/forums/forumdisplay.php?f=50)
-   -   Prevent stuck wheel bearings? (http://www.advrider.com/forums/showthread.php?t=832585)
Ceemack 10-08-2012 09:38 AM
After a considerable struggle, I've finally gotten the old bearings out of my front hub so I can install fresh ones. The old ones were stuck so badly I had to cut them with a Dremel tool before the could be pounded out.
I'll have to replace these bearings again someday, so I'm trying to think of ways I could make it a bit easier.
Is there any reason not to spread a tiny amount of grease or anti-seize around the outside of the new bearings before they're installed?
D.T. 10-08-2012 10:43 AM
If the bearing is a press fit and tight, grease or anit seize would be fine! I put the stuff everywhere. Well not there...:huh
Only bad thing is the grease collects dust and holds it. Make sure to use sealed bearings. Old skool is open or sheilded. Sealed mo bettah.
LuciferMutt 10-08-2012 10:50 AM
Should be fine. I use a light coat of grease on just about every new part that gets installed by sliding through something else.
Ceemack 10-08-2012 10:50 AM
Yeah, I've got sealed bearings to go in. Thanks.
ragtoplvr 10-08-2012 11:46 AM
I assume you heated the hub before driving out the bearings.
Rod
speedracertdi 10-08-2012 05:22 PM
Rod
^ This.
Ceemack 10-09-2012 02:56 PM
Rod
I did, but it didn't accomplish anything. Hence my desire to make it easier on myself next time.
disston 10-10-2012 11:39 AM
If the bearings are a press fit and the hub is supposed to be heated for removal and installation then I would do it that way. What does the manual say? What kind of bike is this? Putting the thinnest layer of grease somewhere where it doesn't belong will change the seating of those bearing races. Not much but it will change. Raising the bearing race will change bearing preload.
sailah 10-10-2012 11:53 AM
Rod
Put the bearings in the freezer overnight. This in addition to heating makes the job almost tool and beating free. Almost.:D
Yossarian™ 10-10-2012 12:05 PM
So true!
Freeze the bearing, heat the race.
Wear gloves.
ragtoplvr 10-10-2012 12:11 PM
I also put the spacer in the freezer. Makes it a tiny bit shorter so easier to seat the bearings without stressing the inner race.
Rod
Times are GMT -7.   It's 06:37 AM.
