how is the f700 gs on dirt
just curious how the f700 gs is on dirt trails. any info would help, thinking about getting one but not sure how the cast rims on the f700gs will work on tough trails also the suspension.
2 of the reasons I bought a lowered GS800.......
I am a complete rookie and still have much to learn, but so far it has served me well and has been fun as hell! Taking it to Quartzsite AZ in a few weeks, then Death Valley at the end of March. I need some real tires though, the stock BattleWings gotta go.
http://www.advrider.com/forums/showthread.php?t=853509 |
How it is on dirt depends on what you mean by dirt.
I have a 2010 F650GS which almost identical. It is very good on dirt roads...in my mind equal to the F800 as you do not need the extra ground clearance. On two track jeep trails it is again equal to the F800 up to the point where you are going over stones, ruts, that need the extra clearance. If you are going over desert or jeep trails, etc at high speeds where you are jumping the bike, the longer (and lightly better) front suspension gives you more travel when you land before bottoming. the cast wheels are stronger but not as tough as spoke wheels. ie the spoke wheels bend/deflect energy, and the rims are steel (i think??) again so the bend before breaking. cast wheels are stiff...but break when high by high impact. The cast wheels track better on spriited riding on pavement (ie don't flex) and are tubeless....which is much easier to fix on the road than pulling tire and patching a tube. because the F700 is lower it handles the twisties better because of the lower center of gravity and flick between corner easier for the same reason. Of course the F800 looks more macho.....except when you are tip toeing around the parking lot because your feet don't fully touch the ground. Doing the alaskan dempster or dalton roads or the trans labrador on the F700 or similar long remote dirt roads is just fine. If you are truely going off road...get the F800 or better yet a KTM or some lighter bike hope this helps ps the F650 gets noticably better gas milage.(regular gas) ...not sure about the F700 |
great response vtbob, just the kind of info I was looking for. I want tubeless tires, period, I don't want to have to pull a tire off to repair a tube. I have a r1200 gs now and do love it but getting tired of wrestling it around. I got it for long distance touring and after a trip cross country last year realize that's not my thing but want something stable on road to get to my offloading dirt and gravel and some jeep trails riding. I think cast wheels will be ok. I had a klx 250 and love that offroad but what a pain on road. seems like I'm looking for a bike that doesn't exist, 400 lbs, tubeless tires half decent suspension and fuel injected.
This is my 700, at least for me. But if you are going to beat the ever lovin' crap outta something and ride like its Dakar, it probably won't work for you. We went through what I thought was some pretty gnarly stuff a couple weeks back without issues. Did it on the stock street tires too. Like I said though, I am a rookie. |
IMO and this is just MO. The 700 is great for forest service roads and unmaintained roads but up in the northwest our jeep trails tend to get pretty chewed up. I have bottomed out my 800 countless time and the 19 inch front wheel on the 700 would be more difficult going over things. If your looking at something that's under 400 lbs maybe you should look at the KTM 690, under 400 lbs and has the suspension for nasty roads.
Yes the 690 is fuel injected.
But, compared to the F650 or F700GS, the 690 is really less comfortable, burn more gas to make 100km and the tank is only 12l. Seat height is 91cm too... You can avoid having a passenger too... |
I have my F650GS set up for long distance "road" adventure touring. this past summer I and two friends did the alaska trip from vermont. One had a brand new R1200GSA nice bike but BIG..he is 6 4 and young so it is ok. I'm old and 5 9 so the f650 fits me fine. 10,000 miles, crused across the candian plains at 75 to 85...several 500 +mile days. I did put on K60s for this trip so it would be better on slick mud with the alaskan rain...yep we had some! I have the Aeroflow touring wind screen and other aeroflow bits, Jesse bags, etc etc....this give me almost as much weather a fatigue protection as my old RT fairing. Let us know what you decide |
You can ride 10k km (6k + miles) with the K60s... But the rear will wear in square.
Good in highway, a little more vibrations but that's normal for a tire like that... The tire is very robust so it won't be affraid of all your ADV equipment. But in the rain it is less good, due to its robustness. |
They are much better than the typical Tourances/anakees etc on dirt / gravel and especially mud. they do have some bite where the other turn in to slicks. On the pavement they are slippery on wet roads...as compared to tourances which I normal use. They are very hard rubber to get the high miles. I do not doing aggressive riding in the twiesties evan on dry pavement with them. Yes they vibrate at some speeds....ie semi knobbiest ...duh! I had them up to 100 a couple of times....no problems. My friend on the GSA..got into a mild tank slapper (bad head shake)...which he controlled...but he took them off right after that!! Note these tires were pretty well worn at that time. |
If it is as good as an F650GS twin, it will be fine.
See roads below Cofre de Perote, Mexico http://i1169.photobucket.com/albums/...ps1607221f.jpg More dirt http://i1169.photobucket.com/albums/...ps8bae3658.jpg Some more high road dirt http://i1169.photobucket.com/albums/...ps1f28f9b0.jpg Good to go on dirt upwards of 4,300 meters without too many problems. Biggest issue is tire choice. I have dinged 3 rims to the point of needing replacement. This is what they can look like and still be rideable. It'll shake quite a bit above 60mph but you'll still make it home. Worst part is how unnerving the tire distortion gets. http://i1169.photobucket.com/albums/...psc8ab3787.jpg Not sure how the suspension and traction electronics of the F700 will react, but the F650GS, when used within the limits of its suspension, is fine. It'll be more about tires than anything else. |
cast wheels in first gear
just curious if in first gear slowing picking way through some pretty rough stuff will the cast wheels hold up. I noticed the ding in the last post and wondered if that was from speed in bad conditions. I am a slow first gear rider in rough jeep trail two track, I like to take it easy. maybe cast wheels at slow speed will do me just fine.
| Times are GMT -7. It's 10:17 AM. |
