Rear drive rebuild cost 2005 r1200gs 40,000 miles?
I have to get my drive rebuilt as it puked its gear oil recently. I think I stopped before causing too much damage but who knows. Anyway has anybody had their drive rebuilt and if so how much did it cost?
Thanks, Jb |
There are several items that could fail, so the cost will vary. If you are very lucky, it is the big seal on the side of the FD (surrounding the opening) - a not uncommon issue on the R12GS. This is very inexpensive, you just pop out the bad one and knock a new one in. Even I could do that... :evil (Though I paid the dealer a bit under $200 four years ago, when my '06 GS had about 38k on the odometer). Other seals are much more elaborate. Before asking for costs, you'll need to determine what happened. |
+1 replace the seal, check for wheel play at 9-3 and 12-6. In case there is none, ride it and check again periodically.
Dan. |
So the dealer has it and will call when he cracks it open. I will post the outcome when i hear the news. Thanks, jb |
Got the word today it's going to cost 850 all in for seals and bearings
Figure it could have been a lot worse. Can't wait to try it out. |
Any warning before it went? Did you wobble / check for play after the seal gave way? Just interested to learn all I can since I too have an '05.
And when i stopped i had oil all over the rear wheel and tire. jb |
| Times are GMT -7. It's 04:13 PM. |
