Old 03-05-2007, 08:43 PM   #1
KTM640Dakar OP
Motorsick
KTM640Dakar's Avatar
Oddometer: 2,075
Laugh Ask your WELDING questions here.
Do you have a question about welding? How to weld a material or which welding process to use? MIG, TIG, stick, oxyfuel?
If you read through this thread and can't find an answer to your question then ask it in the last page or PM me.
If you are looking for free "how to" welding information search here:
Welding School:
http://www.lincolnelectric.com/en-us...ng-school.aspx
Safety:
http://www.lincolnelectric.com/en-us...ng-safety.aspx
Do it yourself read and learn:
http://www.lincolnelectric.com/en-us...materials.aspx
There is good information on safety and getting started in welding if you are new at it.
http://www.lincolnelectric.com/en-us...s/sitemap.aspx
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
It is not the destination, it's the journey.
KTM640Dakar screwed with this post 02-13-2014 at 07:01 PM
KTM640Dakar is online now   Reply With Quote
Old 03-05-2007, 08:50 PM   #2
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,880
Could I toss in a technical question about plasma cutting or Plasma Arc Welding?
- Jim
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 03-05-2007, 08:51 PM   #3
KTM640Dakar OP
Motorsick
Oddometer: 2,075
Sure. Plasma cutting is good too.
Old 03-05-2007, 08:58 PM   #4
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,880
Say a drag tipped torch cutting .250 carbon steel sheet, with compressed air. The arc is running and the tip is dragging.
What is the approximate power supply output voltage measured across the leads at the supply side? Or, the arc voltage measured between the electrode and the workpiece.
Either one.
- Jim
Old 03-05-2007, 09:14 PM   #5
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,648
OK, this should be easy.
I need to weld some aluminum. I have one of the Lincoln 220V wire feed machines. I am using Argon. Can I just buy some aluminum wire and use the Argon? This is not a critical weld on a frame or anything.
I know............I need a TIG.
Gordy is offline   Reply With Quote
Old 03-05-2007, 09:43 PM   #6
KTM640Dakar OP
Motorsick
Oddometer: 2,075
Yes use argon 100% and get some 3/64 Superglaze 4043 wire. You will also need a teflon liner for your torch and 3/64 or (.047inch) U-grooved drive rolls for your welder. When you get ready to weld set your drive roll pressure in the wire feeder so that it is enough pressure to push the wire but not bird nest the drive rolls if you fuse a tip. Usually you will set the drive roll pressure for aluminum a lot less than for steel wire.
The hardest part about MIG welding aluminum is getting the wire to feed through your welding gun, so keep the welding cable of your gun as straight as possible so the aluminum wire will not have to go through too many curves in the gun cable/liner. That is why you use a Teflon gun liner to reduce friction. There is also a sticker on the inside door of most Lincoln welders that has recommended settings for different thicknesses of metal, as well as different weld wires (like 3/64 dia, Aluminum wire).
If you are using the smaller SP175 220V machine then you might have to use .035 diameter wire.
The best way to MIG weld aluminum is with a spool gun or push/pull gun.
Old 03-05-2007, 09:19 PM   #7
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,522
Where is the best place to learn to weld?
I was watching a show on CMT, they were fixing up a guy's dump truck and used a plasma cutter tool to cut 2" holes for round lights. The tool was fast and worked like a compass. What is that tool and what other cutting tools are available.
You weld something critical and it needs to hold up. How do you know the weld is strong or correct without beating up your project testing the weld?
Is it true a beer can can be welded if the welder is skilled?
Does grinding a weld weaken it?
scooteraug02 is offline   Reply With Quote
Old 03-05-2007, 09:47 PM   #8
KTM640Dakar OP
Motorsick
Oddometer: 2,075
There are welding classes at most community colleges.
Here is a motorsports training program: http://www.lincolnelectric.com/en-us...ls-course.aspx
http://www.lincolnelectric.com/en-us...on-center.aspx
KTM640Dakar screwed with this post 02-12-2012 at 06:02 PM
Old 03-05-2007, 10:23 PM   #9
G-Force Junkie
G-Force Junkie's Avatar
Oddometer: 1,328
Yes, bottom to bottom, but they have to be empty I probaly got some around the shop I've done, I'll see if I can find them.
Mike
Welder/Fabriator
G-Force Junkie is offline   Reply With Quote
Old 12-29-2007, 12:21 AM   #10
mysterio
Eventually an Adventurer.
Oddometer: 985
Re; How do know the weld is good? Other than welds that require x-ray checks and all the other very technical stuff, have you ever tried to break an even 'ordinary' weld?
Err, I didn't check the date on this stuff. Oh well, back to my dreaming...
mysterio screwed with this post 12-29-2007 at 12:38 AM
mysterio is offline   Reply With Quote
Old 03-05-2007, 09:26 PM   #11
KTM640Dakar OP
Motorsick
Oddometer: 2,075
Either one.
- Jim
To cut 1/4 inch plate you will need about 30 Amps. With plasma cutting the voltage is determined by the distance of the tip to the plate you are cutting. You don't really set the machine voltage on a hand held plasma cutter, you set amperage. The key to getting a good plasma cut is setting the right amperage to thickness and keeping the torch slightly above the surface you are cutting without touching the plate. You also need a steady hand, and don't move too fast. If you go too fast the spatter will shoot back at you. You also need clean dry compressed air with the right pressure setting. Most plasma cutters have recommended flow rates for their machine. Usually 65 psi. for a 50 Amp machine as an example. Also make very sure you have a new electrode and nozzle since these parts wear out and will effect cut quality.
Are you using an automated table plasma cutter or hand held plasma cutter? If you are using an automated plasma cutter then you would set voltage to control torch stickout.
Old 03-05-2007, 11:05 PM   #12
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,880
That's pretty good. You are the first person, Welding Engineer or otherwise, that went right to arc length.
Yea I get that. That the physics of the plasma in any particular gas, in this case air, set the arc voltage over the arc length.
I was just thinking that you might have played around and measured that voltage with a meter, or looked at it on a scope.
I realize I am asking more of a mechanical question. More like "How far back is the electrode from the face of the 'swirl cup' nozzle?" Or terms to that effect.
So, say select one of your more popular Lincoln hand held plasma torches. What is that dimension?
- Jim
Old 03-06-2007, 09:12 AM   #13
gsweave
Yinz, blinkers are on.
Oddometer: 11,474
I will tell you up front that I am a Welding Engineer for The Lincoln Electric Company so if I sound bias to my company's products, well.. I am.
So tell us about your welding project?
Glad your here.
Should we retire this old Carbon arc machine? She cuts 2" Niconel like a bitch.
Hey all kidding around aside
It may be ugly, but this portable, 480V machine can really burn some nice stainless welds.
One of our lincoln sub-arcs
Thanks in advance for taking on this task in the "Garage"
I am thankful that it is here......
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 03-06-2007 at 09:42 AM
gsweave is offline   Reply With Quote
Old 03-06-2007, 09:34 AM   #14
gsweave
Oddometer: 11,474
Here is a question we see alot.
Home shop? Greatest overall versatility. And I have never laid a bead in my life. Mig or Stick? And yes shop is wired for 240.
1Paul 2:15
Old 07-05-2007, 11:39 AM   #15
openboatt
Don't harsh my mellow
openboatt's Avatar
Oddometer: 276
Sorry to ask...
But was this question answered? I'm in this boat... obt
openboatt is offline   Reply With Quote
Times are GMT -7.   It's 09:54 AM.
