Old 03-27-2007, 09:57 AM   #1
magli OP
knaetsch
magli's Avatar
Oddometer: 172
Question Kick-starting LC4 with dead battery?
Greetings..
This winter, I had to put my LC4 ('99 E) in the garage for three months due to my insurance policy. Since I almost always use the kick-starter, I figured that I did not care if the battery went dead, so I did not even bother taking it out when I left the bike.
Sure enough, it was completely dead when I brought the bike out the other day... So I got prepared: put on my left-boot, and started kicking away. I was getting nothing- nada. After about a half hour of trying (and by this time, questioning which position of the emergeny starter was "on".. and having to continusouly switch between the two positions to make sure), I finally rolled it over to a mechanic, who suggested that it was possible that you could not start the bike if the battery was dead.
So, I got the battery out, and gave it to him to charge for me - I also noted that without the battery, my spark plug was definitely *not* sparking when I was kicking.
Once the battery was charged, I put it back in, and was able to kick-start the bike without a problem. Now me's happy.
But was this just a coincidence, or is it not possible to start the bike without a battery?
Say my battery just mysteriously dies on me when I am deep in the forrest - does that leave me stranded?
cheers.
magli is offline   Reply With Quote
Old 03-27-2007, 10:33 AM   #2
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
The electric start LC4's need the battery to power up the Kokusan ignition. It only requires a little bit of power, but if the battery is dead flat or disconnected, it won't start from a kick. You can't kick it over fast enough to generate enough stator power to energize it.
The earlier kick only model LC4's had an SEM ignition that didn't need any battery power at all to run.
gaspipe [the original]
Hair of the dog....
gaspipe is offline   Reply With Quote
Old 03-27-2007, 10:47 AM   #3
Ooobah-Moto
Ooobah-Moto's Avatar
Oddometer: 3,809
Dead battery... re-wireding possible to kick over?
As it's been mentioned that the previous models were capable of being kicked over under the condition there's no charge in the battery or no battery at all(?)... my question is whether or not a 2003 (2001-2005) LC4 is capable of being re-wired such that it can be kicked over with a dead battery??
Ooobah-Moto is offline   Reply With Quote
Old 03-27-2007, 10:56 AM   #4
djchan
djchan's Avatar
Oddometer: 1,173
I've always thought that an electrically inclined lady or gent could put together some type of a small jumper circuit (maybe a capacitor or some such other energy storing electronic gizmo) which would allow removal of the battery and thus lower weight for serious offroad jaunts. I tried kicking mine for days this spring but finally had to give in and just charge the dang thing to get it started.
Dean
djchan is offline   Reply With Quote
Old 03-27-2007, 11:03 AM   #5
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 800
Well, at least I know it ain't just me now....Kinda defeats the whole purpose of kick starter doesn't it?
BlitzBike
BlitzBike is offline   Reply With Quote
Old 03-27-2007, 11:56 AM   #6
JP4
Thumper Geek
JP4's Avatar
Oddometer: 170
Sometimes, even a weak but not dead battery will not start an LC4. Many times I've encountered an LC4 that will turn over for quite a while with the starter, but it's not enough to get it to light off. The kick starter can be much more effective than a weak battery (if you know the 4 stroke starting drill) in starting an ornery LC4.
Jeff
'01 LC4 640E 18L
'93 XT225
JP4 is offline   Reply With Quote
Old 03-27-2007, 03:01 PM   #7
Ricardo Kuhn
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,318
so mister Gaspipe can you install a SEM Ignition module on a electric start version...!?!?
or is the newer Kokusan ignition that much more evolve that will be a waste to use the SEM version.??
I just think is kind of stupid to have a kick start if you need a full charge battery to run the bike anyway, since If the battery was working I will not need to used the kick start in the first place..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 03-27-2007, 03:16 PM   #8
magli OP
knaetsch
magli's Avatar
Oddometer: 172
I completely agree with you. It is stupid, and annoying - and I have already been a victim of this stupidity.
However, at least in my case, the battery does not have to be fully charged in order to kick-start it. In fact, my battery is quite old, and it usually fails to start the bike - it is often too week to even get the motor rotating.... but I can still kick-start the bike. The only time I was unable to kick-start, the battery was so dead that it could not even make the neutral indicator glow when I was in neutral.
Old 04-15-2007, 09:02 AM   #9
dirtydeeds
I'm alive.
dirtydeeds's Avatar
Oddometer: 2,564
This happened to me with my 2003 only 2 weeks ago. (I wired my hand warmers to my battery instead of my ignition and left it on over night.) The dash would not light up -no power anywhere. I kicked it for 10 min, until I noticed I had also flicked the "run" switch to off. Feeling like an ass, I kicked it a couple more times and it started. (I know there was no more juice in the battery, the clock was reset to 12:00. )
So, either the 2003 model will start with a dead battery or a bunch of kicks with the Kill switch "off" will charge the ignition enough for a spark. What do you think?
990SMT, 640A, TXC450, TE510, ATC350X, ATC200ES, 550MXC, BW200. Need more space in garage.
dirtydeeds is offline   Reply With Quote
Old 03-27-2007, 07:48 PM   #10
Speaker
What's an estart?
Speaker's Avatar
Oddometer: 888
The SEM uses a different flywheel, and ignition coil than the Kokusan. You could swap but it would be a step backwards in my opinion, many of your existing electronics would have to go.
Speaker screwed with this post 03-27-2007 at 07:57 PM
Speaker is offline   Reply With Quote
Old 03-27-2007, 08:07 PM   #11
gaspipe
Wandering Soul
gaspipe's Avatar
Oddometer: 11,352
The SEM system only generated about 130 watts of energy anyway. IMHO, it has a superior advance curve for the LC4, but that's about it.
The smart thing to do is wire a permanent jumper cable off the battery posts so any 12v power source can energize the ignition and you could kick it.
It's a bad system for an adventure bike, IMHO, but then again, you can get a battery for less than $40 new. Get a new one every 2 or 3 years.
Hair of the dog....
Old 03-27-2007, 11:48 PM   #12
bmwktmbill
Traveler
Oddometer: 5,049
Gaspipe,
I sure as hell am not an electrical engineer and maybe you are so You can explain how it works.
My wiring diagram for the '02 Adventure shows a capacitor just prior to the Kokusan ignition.
I was under the impression that it contained a charge that would light the ignition with a dead battery assuming it was charged up.
Tell me I am crazy.
Bill.
'02 KTM 640 Adventure-lowered
Cormack McCarthy-The Crossing
Bill Shockley
bmwktmbill is offline   Reply With Quote
Old 03-28-2007, 12:07 AM   #13
Ricardo Kuhn
Oddometer: 12,318
make sense
I allready did that, but still need to find the sourse to piggybag
actually Florencenbrown introduce me to this incredible little nickel metal batteries so I'm making a proper carrior to keep on the bike just in case, they are freaking tinny and light (like a c type battery but lighter) but you require to use four of them to achive the 13,4volts (3.3 volts each or something..
Were...!?!?
All the ones I see are about $60 and then the oddisey 310 (since they are incredible) i want is about $125 including shipping.
Old 03-27-2007, 07:15 PM   #14
ElFuego
hold your horses
ElFuego's Avatar
Oddometer: 84
...But was this just a coincidence, or is it not possible to start the bike without a battery? Say my battery just mysteriously dies on me when I am deep in the forrest - does that leave me stranded? cheers.
I am new to kickstarting (also new to dual sports, KTM, single cylinders not intended to mow the lawn, etc.), so I am merely speculating here: it seems to me that if the battery is out of the bike, you could connect the two leads and kick the bike off.
I may give this theory a shot over the weekend. I could look at the schematic, but what would be the fun in that?
It's so hard to live with someone who's mentally ill. Especially when you're the one who's mentally ill.
ElFuego is offline   Reply With Quote
Old 03-30-2007, 05:02 AM   #15
bmwktmbill
Traveler
Oddometer: 5,049
From Sommer...
This from Sommer KTM on kickstarting with reduced voltage:
"good morning,
starting (kick) an adventure 640 (or all LC4) with dead battery (reduced voltage / V) will be very, very hard, because you need full 12V Voltage (reduced ampere is allowed - so for example a little Volume 12 V battery (with 3 or 4...A) will work for kicking.
So you need 12 Volt .
Finally it is possible, but you have to kick a lot of time and if there is enough luck, you will get Voltage for first ( Zünderregung "ignition impulse") .
Mit sportlichen Grüßen
SOMMER KTM Rainer Kroll"
Bill Shockley
Times are GMT -7.   It's 09:01 AM.
