Old 02-11-2008, 09:04 AM   #1
the white rabbit OP
Vicarious
the white rabbit's Avatar
Oddometer: 3,051
Beta RR /RS 4T enduro thread
If I may be so bold I think a thread for Beta related info might be a good idea as a few of us have or are thinking about them. Perhaps then some resource may build. There's short threads here, on TT and elsewhere but the info is patchy.
I don't actually know what I am talking about when it comes to thumpers so I am hoping for incoming faq and ideas although perhaps collecting info here I find out as well as what others know may be a help generally.
A Beta sign in thread if you may
Some resources:
The official website for Betamotor and for the RR 4T.
The Beta RR 4T Enduro information source, tech, how-to, cross referencing...very useful. Looked after by Scud.
American Beta the US importer.
Beta UK , Lampkins UK importer (mostly trials bikes but enduro too).
Thumpertalk, Exotics section a few threads.
Of course the engines are KTM and so far it looks like they are a straight bolt in so no Beta specific issues at least in the motor department. So KTM info directly relevant.
What is this thread about? These, in 400, 450 and 525 cc
The RR above. The RS is the same but has road kit on installed.
'These are the hardest conditions I have made a basket like this in' Ray Mears
the white rabbit screwed with this post 03-10-2008 at 12:03 PM
the white rabbit is offline   Reply With Quote
Old 02-11-2008, 09:12 AM   #2
the white rabbit OP
Vicarious
Oddometer: 3,051
My 07 400RR
Old 02-13-2008, 01:54 AM   #3
the white rabbit OP
Vicarious
Oddometer: 3,051
First post about oil
This is the 400 RFS engine in mine and my dealer is recommending Motrex Cross Power 4T 10W50 fully synth.
The manual is contradictory in places and recommended Motrex Cobra 15W40 for one, which does not seem to be available any more, so I am going with the 10W50.
I know oil is one of those emotive things
the white rabbit screwed with this post 02-13-2008 at 05:24 AM
Old 02-13-2008, 07:23 AM   #4
kenaroo
I am because i ride
kenaroo's Avatar
Oddometer: 881
Remember it's a KTM motor. tons of experience with those over at KTM talk.
I'd stick to 10 w 50 as well if I were you
what does your garage look like
http://www.garage-interiors.com
kenaroo is offline   Reply With Quote
Old 02-13-2008, 12:34 PM   #5
the white rabbit OP
Vicarious
Oddometer: 3,051
Ok, so just starting to ahve a fiddle about with the 400 now.
Just swapped over from the Beta handguards to Acerbis Rallypro wrap arounds.
I took a chance on the Renthal fatbar kit, and it does fit on the black Betamotor branded bars made by Reikon on the 07. Unsure what bars are on the pre-07 models. Trim to end of throttle tube required and bit of padding against abrasion of clutch line on guard metalwork seems a good idea as this needed rerouting slightly.
Also while in that region worth checking the wiring to the starter, mine had chaffed where it had been slipped under the bolt attaching the starter unit.
the white rabbit screwed with this post 04-13-2008 at 01:44 AM
Old 02-13-2008, 12:36 PM   #6
the white rabbit OP
Vicarious
Oddometer: 3,051
Old 02-19-2008, 10:27 AM   #7
the white rabbit OP
Vicarious
Oddometer: 3,051
The clutch lever on the 07 is an AJP long lever old type and the brake a Nissin compatible, short from stock I think.
The long clutch is a bit of a nuisance with wrap-around guards. I am sure many types fit but these aftermarket ones for the Beta trials bikes certainly do. Adjuster screws are slightly better on the stock levers but swap over.
http://www.trialcast.co.uk/betalevers.htm
I guess the news is that something pretty bog-standard swaps on ok. Probably a complete unrevelation to most
the white rabbit screwed with this post 02-21-2008 at 11:42 PM
Old 02-21-2008, 03:45 PM   #8
PozoRider
Just Ride
PozoRider's Avatar
Oddometer: 209
08 525 rs
Here are a few fotos of my 08 525 rs.
IMS Tank:
Enduro Engineering Hand Guards:
GPR Under Bar Mount:
Rich Reyes
2011 Beta 520 RR
2009 KTM 690 Enduro R
Dick's Desert Dash
American Beta
PozoRider is offline   Reply With Quote
Old 02-21-2008, 11:41 PM   #9
the white rabbit OP
Vicarious
Oddometer: 3,051
Neat. You are right the EE handguards do seem to fit on there very well.
Old 03-10-2008, 12:43 AM   #10
the white rabbit OP
Vicarious
Oddometer: 3,051
Clutch / case savers
I found the KTM 400 RFS clutch saver bolts right on but there are issues (which Pozorider pointed out). More about this add-on a bit later.
I was surprised to find no chain bar though.
the white rabbit screwed with this post 03-15-2008 at 02:03 AM
Old 03-10-2008, 09:07 AM   #11
CrankyCoyote
scud no more
CrankyCoyote's Avatar
Oddometer: 100
I've got Cycra Pro-Bends on mine; get the KTM parts and everything "just works".
I use Rotella-T Synthetic 5w-40 as the engine oil. None of the nasty car friction modifiers to mess up your clutch, full synthetic, seems to work pretty well, and it's less than $10/qt.
You guys mind if I add your bike pictures to the gallery at http://www.betamotorcycles.net? Credited however you want, of course.
CrankyCoyote is offline   Reply With Quote
Old 03-10-2008, 10:15 AM   #12
the white rabbit OP
Vicarious
Oddometer: 3,051
Good to see you here on this thread Scud, and use my pic certainly. I will get some more up as soon as I can actually get out on the thing.
You have email as well
Old 02-09-2012, 09:21 PM   #13
Woundflatout
Woundflatout's Avatar
Oddometer: 501
A ride last week...Diamond Mill in the Tillamook Forest OR
The deadfall was luckily high enough to drag a bike under. Otherwise our bikes would have stayed in the forest for a day or 2!
Jason Slutsky
PROUD TO BE RIFF RAFF
'09 Husaberg FE570
Rallymoto #159
Woundflatout is offline   Reply With Quote
Old 02-12-2012, 05:53 PM   #14
Woundflatout
Oddometer: 501
Hey ABD,
Thanks. I think we're just having a strange winter. But I'm not gonna complain about the blue skies as long as it means riding!
Cheers,
Js
Jason Slutsky
'09 Husaberg FE570
Rallymoto #159
Old 03-12-2012, 07:09 PM   #15
Woundflatout
Oddometer: 501
Originally Posted by The Bladerunner View Post
If anyone's interested I will post some impressions when we are back at the end of march.
Heck yeah, we're interested. I'd love to see your cockpit setup / fairings and any additional tanks.... Also gearing setup. Good luck! Go Bladerunner!
Jason Slutsky
'09 Husaberg FE570
Rallymoto #159
Times are GMT -7.   It's 08:14 PM.
