Old 07-16-2008, 10:52 AM   #1
Uncle Ernie OP
Uncle Ernie's Avatar
Oddometer: 3,978
Stinky BMW gas mileage ?!
Started out with a full tank. Took a passenger that weighs around 120 pounds up the hills, through the dells, along the river. A fair amount of twisties and gear-changing. Put on 62 miles, went into the gas station and put a little over 2 gallons in the tank.
BTW- this is a BMW R100/2 conversion w Steib S500.
Is it possible I'm only getting around 30mpg ?!
LOOK OUT IT'S COMING THIS WAY!
Uncle Ernie is offline   Reply With Quote
Old 07-16-2008, 12:43 PM   #2
Blue Ridge Wheeltor
Oddometer: 428
I guess it's possible. Most Urals get high twenties/low 30's. Any ethanol in the gas?
Blue Ridge Wheeltor is offline   Reply With Quote
Old 07-16-2008, 12:49 PM   #3
muschelschubser
muschelschubser's Avatar
Oddometer: 294
That's around 8l/100km, sounds normal.
Dirk, on a R100/Ural
Central East Tour
http://gespann.wordpress.com
The fastest way to yourself leads arround the world!
Richard Hoffmann (*1938 ),
muschelschubser is offline   Reply With Quote
Old 07-16-2008, 06:28 PM   #4
scottro
scottro's Avatar
Oddometer: 460
That's about what I get
R69 w/ R90 engine & Sputnik sidecar w/ 50-100lbs of ballast. 32ish when ridden gently and 29ish when ridden like a fiend.
But when people ask, I tell them 75 mpg
Heehee F'em !
scottro is offline   Reply With Quote
Old 07-16-2008, 09:34 PM   #5
gregbenner
Oddometer: 1,176
I get around 30 (less on the interstate) on both my GoldWing/GTL and V Strom/Ural. Neither bike is a mileage queen solo, however. As near as I can tell, the sidecar reduces mileage by 20-25% in local riding conditions, and maybe more than that running high speeds, which might make sense due to the significant drag of the car. 40 mpg on either a 1000 Strom or a Wing are in the ballpark (without a sidecar).
2014 Triumph Tiger 800
2015 Vespa 300 ABS
2007 Dyna, 1947 Harley 45 flathead
1975 BMW R75/6
gregbenner is offline   Reply With Quote
Old 07-16-2008, 10:04 PM   #6
Sidecardoug
Pleasantly pleasing
Sidecardoug's Avatar
Oddometer: 1,796
Sounds about right to me. If I am flogging my R100/Ural rig I get about 28 mpg, treat it gently and I might get 36 mpg.
Sidecars do not lend themselves to good fuel economy. Something about hanging 250 pounds of air brake on the side of an unsuspecting motorcycle does not equal high fuel mileage.
The best lack all convictions, while the worst
Are full of passionate intensity.
Sidecardoug is offline   Reply With Quote
Times are GMT -7.   It's 07:17 PM.
