Go Back   ADVrider > Riding > Trip Planning
Old 09-02-2008, 11:59 AM   #1
DominicDomingo OP
axe me anything
DominicDomingo's Avatar
Oddometer: 7,133
strapping fuel cans to bike? suggestions or better ideas.
On a desert ride in Morocco in few weeks my buddies and I will need extra fuel for a few desert track crossings. We only need about 10 l each on two occasions so buying an expensive collapsible fuel bladder is out of the question. I've read a few threads on other sites about using water bags and the like but it seems a bit to iffy to me.
Basically I plan to carefully strap good plastic jerry cans to our bikes, and refill the bike's tanks as soon as there is room. I think that if we take reasonable precautions like not strapping the things to the exhaust and venting pressure buildup from time to time we should be fine.
I realize that this is not an ideal set up for the long haul but we will be out in the sand, there is a likelihood of some wipeouts but there's nothing to big crash into out there.
Any comments?
DominicDomingo is offline   Reply With Quote
Old 09-02-2008, 05:19 PM   #2
Lone Rider
Registered User
Oddometer: 25,130
Maybe purge the pressure if needed.
Lone Rider is offline   Reply With Quote
Old 09-03-2008, 05:36 PM   #3
Tim Cullis
Partially heighted
Tim Cullis's Avatar
Oddometer: 273
There's no shortage of suitable plastic containers sold in hardware stores in Morocco. Consider bringing a collapsable funnel with you.
You'll be using fuel at the rate of possibly 1 litre for every 15-20 km, so the best thing is to stop from time to time and top up the main tank.
When you've finished with the container, stick the top back on and leave it by the side of the piste, someone will be grateful for it.
Tim
Access the Morocco GS Knowledgebase
Tim Cullis is offline   Reply With Quote
Old 09-03-2008, 07:12 PM   #4
bananaman
transcontimental
Oddometer: 7,529
I think yer on the right track. When I carried 10 liters, I put some Teflon plumbing tape on the threads, and duct tape over everything- to keep the caps on and clean.
When yer done we need a ride report with pics!
I am Charlie.
bananaman is offline   Reply With Quote
Old 09-05-2008, 04:15 PM   #5
danman
tumbling tumbleweed
Oddometer: 174
Fuel Packs
Hey Dominic,
I bought these, just got them and haven't tried them out. They hold 1.25 U.S. Gallons-about 4 liters, i think--don't know if you can get them in europe. They have a mount that attaches to a pannier and makes them easy to carry, also they make one to carry water (white).
Here is a link to the manufacturer;
http://www.kolpinpowersports.com/pro...uel-packs.html
And here is a retailer;
http://www.sportsmansguide.com/net/cb/cb.aspx?a=441063
And here is a photo;
OK good luck
Danman
danman screwed with this post 11-23-2008 at 09:25 AM
danman is offline   Reply With Quote
Old 09-05-2008, 04:44 PM   #6
TengaiJohn
TengaiJohn's Avatar
Oddometer: 3,120
I like this one http://www.kolpinpowersports.com/pro...fuel-pack.html
TengaiJohn is offline   Reply With Quote
Old 09-14-2008, 02:42 PM   #7
Vinnie the Snake
Oddometer: 1,093
My Front Mounted 2-stroke Oil and Motor Oil
2ea 1.5 gallon Rear Tanks, with a 4 gallon fuel tank
2007 - Vintage TAT - Ok, NM, Co
http://www.advrider.com/forums/showthread.php?t=233901
2008 - Vintage TAT - Ut, Nv, Or
http://www.advrider.com/forums/showthread.php?t=331983
2009 - Vintage TAT - NC, Tn, Ms, Ar
http://www.advrider.com/forums/showthread.php?t=507149
2010 - Unfinished Business Tour - TAT, CDR Shadow of the Rockies
http://www.advrider.com/forums/showthread.php?t=615279
Vinnie the Snake is offline   Reply With Quote
Old 09-14-2008, 06:45 PM   #8
Gluaisrothaí
Feckin' gobshite
Gluaisrothaí's Avatar
Oddometer: 547
DIY from Walmart in Cabo
After nearly getting caught fuel-less on the way down here, I've added ocho litros to the bike.
Gluaisrothaí is offline   Reply With Quote
Old 09-15-2008, 09:35 AM   #9
DominicDomingo OP
axe me anything
Oddometer: 7,133
Well we're off to Morocco by plane tonight, start riding on Tuesday. Our setup will surely be like Klevin's, I'll post when I get back about how it worked. I'll also make a full ride report.
DD
Old 02-04-2009, 05:27 PM   #10
Macadam Drifter
Explorer of the Backroads
Macadam Drifter's Avatar
Oddometer: 723
I know this will not appeal to everybody. But my solution is to carry all my gear in a single wheel trailer, keep the bike light, drop off trailer at a base camp, explore, move on. The fuel tanks give me good loiter time without having to drive out for gas.
Because the bike is light and geared down I can carry alot of gear even though the bike engine is 196cc. My current range should I need to push it is somewhere between 600 and 750 miles (depending on terrain, winds, bike speed, etc). I can change rear gears very quickly about 15-20 or less from a 47-55). It's amazing where this thing can go.
In arid regions I take fewer gas cans and carry water cans in lieu of fuel.
See pictures below.
The TW200 is slow but the Earth is patient
A Solo TW200 Travels From WA to MN
My Travelblog Updated 11/22/2011
Macadam Drifter is offline   Reply With Quote
Old 02-07-2009, 01:06 AM   #11
ADVBMR
Polygamotorcyclist
ADVBMR's Avatar
Oddometer: 892
quite the set-up
See pictures below.
Wow. I give you a 9.5 for creativity and a 10 for individuality. Yup, a lot of folks wouldn't go for it, but it looks like it works great. Pretty cool set-up.
ADVBMR is offline   Reply With Quote
Old 02-07-2009, 05:14 AM   #12
Rollin
Go.
Rollin's Avatar
Oddometer: 542
Well I can tell you what doesn't work...
I'm lucky I didn't blow myself up.
A good traveler has no fixed plans, and is not intent on arriving. ~Lao Tzu
Rollin is offline   Reply With Quote
Old 02-09-2009, 08:48 AM   #13
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,750
Rocker59 (aka guzzimike), Aux Arcs
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 02-09-2009, 08:50 AM   #14
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,750
See pictures below.
I've seen that Uni-Trak Dakar trailer on the Dauntless website.
Tell us about it. Your impressions, etc...
IBA #24873
Old 02-09-2009, 09:59 AM   #15
Macadam Drifter
Oddometer: 723
Thanks for your request. I'm working on a write up and will post it on this site. But at this time I don't want to disrupt this thread, PM me and I will respond to your request.
MkD
Macadam Drifter screwed with this post 02-09-2009 at 10:49 AM
Times are GMT -7.   It's 05:20 PM.
