Old 09-17-2008, 05:35 PM   #1
Justinmarque OP
Thumper>Airhead
Justinmarque's Avatar
Oddometer: 105
Question Instrument Cluster ?
Is there any reason a R100 cluster wouldn't work on a 75/6?
'75 BMW 75/6
'04 Honda XR650L - Stolen!!!
http://justinmarque.blogspot.com/
Justinmarque is offline   Reply With Quote
Old 09-17-2008, 06:19 PM   #2
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,842
The 100 cluster will for sure have an electronic tach, whereas the /6 had a mechanical cable-drive tach. Easy enough to wire an electronic tach.
Speedo: ratio may or may not coincide, depending on the rear end. If you can find a speedo with the same w=xxx, then it should work perfectly....
Don't know about physical mounts, probably similar?
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 09-17-2008, 06:23 PM   #3
Justinmarque OP
Thumper>Airhead
Oddometer: 105
Thanks bpeckm.....that's what I needed to know.
ps...your bike is looking GOOD!
'75 BMW 75/6
Old 09-18-2008, 08:00 AM   #4
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
you're welcome to check out my vapor, it's installed but not quite all back together. would be an easy way to have less stuff on the bars. of course you'd have to figure out the warning lights or buy the dashboard with the lights built in.
bmwblake is offline   Reply With Quote
Times are GMT -7.   It's 04:07 AM.
