Old 10-23-2008, 07:43 PM   #1
skibum_1260 OP
Oddometer: 242
Yamaha forks on a BMW F650GS Dakar
Got alot of interest on this so ill try and post what i can remember about doing the upgrade. For starters heres a pick. The forks i used were off of a YZ426f, came with triple clamps, brake caliper and then picked up an excel wheel all for 250 bucks! Put in a heavier weight oil and then the heaviest springs i could find for the forks, new seals of course. The main two issues i remember having(did this last winter) were i had to machine the stock yamaha steering stem down about .010" for one of the bmw steering bearings, the other one fit like a glove! Also i had to trim the inside of the fairing so i could swing the forks without rubbing anything on the inside, and i also think i had to do somethin for the fork stops to work also. But let me know if you have any more questions and ill try and get some better picks once i wash my bike, its covered in a pile of mud right now! But i measured the weight difference of the two it was about 15lbs savings, the new ones were a bit longer then that dakar forks, but handles like a new bike now, and the front end feels so light and no more bottoming out!
skibum_1260 screwed with this post 12-06-2010 at 11:33 AM
skibum_1260 is offline   Reply With Quote
Old 10-23-2008, 11:16 PM   #2
johno
johno's Avatar
Oddometer: 2,911
Skibum, if you use the Yamaha bearing kit, you dont have to machine the shaft. The BMW, and Yammy have the same size outer cup diam.
I used the Yam bearings on my GSPD conversion, and the GSPD has the same bearings as the 650GS/Dakar.
Down in the land of the confused(mainly me)
johno is offline   Reply With Quote
Old 10-24-2008, 03:17 AM   #3
WayneC1
Oddometer: 2,557
Interested in the actual difference in length and also the size of the disc rotor.
You have not mentioned the upper fork yoke & whether it is the Yamaha one.
How do you find the braking performance compared to the BMW disc & rotor
WayneC1 is offline   Reply With Quote
Old 10-24-2008, 06:02 PM   #4
johno
johno's Avatar
Oddometer: 2,911
You use the upper and lower Yamaha yokes.
Not sure on the 650, but I use the BMW wheel and brake on my GSPD.
Old 10-25-2008, 04:13 AM   #5
michnus
Lucky bastard
michnus's Avatar
Oddometer: 1,233
Now this might warrant me to keep the Dakar. Tell me more about the way it performs, does it not make the front end to light? The KTM640 is very twitchy over rocky terrain, where the Dakar normally just plough through, yes, I know it's fronts are rubbish, but it does work there for some reason.
The only problem would be to mod the ABS ring and sensor on the ABS bikes.
Did you also fit different handlebars and did you had to do other mods to the switches and throttle?
michnus is offline   Reply With Quote
Old 10-25-2008, 10:41 AM   #6
2Advent
F650gs moder
Oddometer: 6
Hi, what I would like to know if you tried using BMW wheel set, and if it would fit, and why you went with the yammi wheel set?
2Advent is offline   Reply With Quote
Old 04-06-2009, 08:24 AM   #7
stalia85
Oddometer: 2
Hello everybody name is Michael and i am planning to put a USD WP 48 from a KTM on my 650 Dakar i would like to ask if you now if the yokes from the KTM much on the Dakar
Thanks aloot
stalia85 is offline   Reply With Quote
Old 04-27-2009, 09:32 PM   #8
drivenbydiscovery
drivenbydiscovery's Avatar
Oddometer: 346
dammit, i can't believe i missed this!!!!
i've had my Yamaha 450 forks sitting in the garage for months because i didn't know what i would do about mounting the front wheel/brakes/abs (i didn't want to switch to Yamaha wheel and brakes).
please please please say you'll do another batch of axles and brackets!!! i'm in!!!!
Australia in a Land Rover / Central America on a Moto
drivenbydiscovery is offline   Reply With Quote
Old 05-11-2009, 09:28 AM   #9
Roughshod
weld proud
Roughshod's Avatar
Oddometer: 101
Cool2
This is exactly what I was researching. So glad I found this thread. Thanks guys.
Roughshod is offline   Reply With Quote
Old 07-23-2009, 05:36 AM   #10
jimmy2020
limpiador de ventanas
jimmy2020's Avatar
Oddometer: 983
I'm looking for a set of front forks for a 01 DAKAR.
I thought this would be a good place to post.
jim
"the adrenaline and stress of an adventure are better than a thousand peaceful days"
jimmy2020 is online now   Reply With Quote
Old 08-16-2009, 07:25 AM   #11
jimmy2020
jimmy2020's Avatar
Oddometer: 983
i will try my luck again.
I found a set of forks on this thread.
Now I'm looking for a rear shock for my 01 Dakar.
Needs to be low mileage...aftermarket mo' betta!
jim
Old 08-25-2009, 12:31 AM   #12
john_aero
john_aero's Avatar
Oddometer: 1,173
any idea if the newer 04 forks from the wr bikes would suit or would they be too big for the bike and the parts?
women are like clouds.......
once they fuck off it is a really nice day.......
john_aero is offline   Reply With Quote
Old 08-25-2009, 07:40 PM   #13
JDRadman
Moto Head
JDRadman's Avatar
Oddometer: 195
There were a few guys that used the 48mm / later model forks with no problem. the issue for me seemed to be that they were always more expensive.
Rad
JDRadman is offline   Reply With Quote
Old 08-26-2009, 12:48 AM   #14
john_aero
john_aero's Avatar
Oddometer: 1,173
Rad
picking up a set today for very little cash, just need get a set of clamps now off ebay as well
Old 03-21-2010, 11:25 AM   #15
JDLuke
Ravening for delight
JDLuke's Avatar
Oddometer: 8,644
Well, it took me months and months, but I finally got around to doing something about my sidestand today.
Marking:
Cutting:
New piece (about 7 cm of extension):
Ready to weld:
I'm NOT good:
Coat of primer
Coat of black enamel
Now I have to wait a while before reinstalling it. My bike should finally have a reasonable stance on the sidestand again.
Why did I drink all of the ingredients for vomit?
"Used to be Man vs. Nature.. then Man vs. Space.. then Man vs. the Moon. Now it's Man vs. Food" - Dalar
"you cannot reason a person out of something they were not reasoned into." - Jonathan Swift
JDLuke screwed with this post 03-21-2010 at 05:43 PM
JDLuke is offline   Reply With Quote
Times are GMT -7.   It's 08:06 AM.
