Old 04-24-2009, 06:21 PM   #1
Canadane OP
Canadane's Avatar
Oddometer: 43
Zumo Trouble
Has anybody out there had trouble with a Zumo not taking a charge from the battery. I bought it last spring and have been very happy with it. This spring, when The weather finally allowed for riding here in Canada, I took it out and after three hours or so it showed low battery. It will take a full charge when hooked up to the usb connection on the computer but will not charge from the battery on the GS1200. I even ordered a new powercord although there was no p visible damage to the old one, all the connectors have been cleaned, both on the GPS and in the cradle mount and I replaced the fuse just in case.
This is driving me crazy and I know that it would be a good excuse to buy a new Zumo 660 but the one I have is less than a year old and shouldn't have packed it in already.
Please help, Canadane
Canadane is offline   Reply With Quote
Old 04-24-2009, 06:30 PM   #2
jwd98056
jwd98056's Avatar
Oddometer: 111
Sound like a problem with the Zumo motorcycle mount. There are a number of threads on the subject of mounts going bad. I haven't had a power problem but two mounts have had one or both channels of audio go out. I am now on my third mount. Garmin only replaced the first one.
You can try cleaning the contacts on the Zumo and the mount. A pencil eraser or electrical contact cleaner are a couple options. Otherwise you may need to look for a new mount.
Jim or JD from Renton, WA
IBA #32756 - BMWMOA #122647
'05 BMW R1200GS - Desert Yellow (Brutus)
'12 HD Road Glide Ultra - Ember Red Sunglow (JD'sRoad)
'02 HD Heritage Softail - Custom Paint (JDsHog)
jwd98056 is offline   Reply With Quote
Old 04-24-2009, 06:51 PM   #3
BikePilot
BikePilot's Avatar
Oddometer: 10,901
My motorcycle mount crapped out after just over a year. Garmin of course refused to do anything about it. Since yours is less than a year it should still be under warranty.
'09 Buell XB12XT, TL1000S, H1F, M620, CR250R, DR250SE, XR650R, Cota 315R
Summer 2009 Ride Report http://advrider.com/forums/showthrea...1509c&t=507038
Summer 2008 RR. http://www.advrider.com/forums/showthread.php?t=367703
BikePilot is offline   Reply With Quote
Old 04-25-2009, 05:14 PM   #4
bass_on_tap
bass_on_tap's Avatar
Oddometer: 2,141
I just replaced my bike mount for the same problem. I have two bike mounts so I swapped and narrowed it down to the mount. Over a year old so I didn't bother with Garmin. I ordered a new one on Ebay, about $50.00. Also, at another time, my battery died at 1 year and 3 months, it would not take a charge. I called Garmin, explained the problem and what I did to troubleshoot it. I also told him it was older than a year so it was out of warranty. The gentleman said he would send me a new battery free of charge, problem solved. Great service. I may be worth a call to them. Hope you have the same luck.
bass_on_tap is offline   Reply With Quote
Old 04-29-2009, 06:49 PM   #5
Canadane OP
Canadane's Avatar
Oddometer: 43
Pissed
I went ahead and ordered a new mount and it arrived by FedEx today. I promptly installed it and hooked it up directly to my battery through a new power cord I had bought also and then stood back and watched the battery indicator, which was still showing, lose it's bars slowly, so that is obviously not the trouble either. I had sent an e-mail to Garmin and they agreed that it sounded like a defective mount and would send me a new one free of charge. I have contacted them again to say that they might as well not since that is not the problem. Maybe your advice to give them a call is a good one and I will try that and get back here to let everyone know the result of this frustrating experience.
Old 04-29-2009, 06:54 PM   #6
Sox Fan
SoxFan
Sox Fan's Avatar
Oddometer: 793
i had the same exact issue 3-4 months after i bought mine. After a bunch of phone calls, Garmin ended up swapping my unit out. It wasn't the mount.
Sox Fan is offline   Reply With Quote
Old 06-02-2009, 12:06 AM   #7
fargodroid
Oddometer: 98
Originally Posted by Canadane
27cdb6e-ae6d-11cf-96b8-444553540000" width="0" height="0">I went ahead and ordered a new mount and it arrived by FedEx today. I promptly installed it and hooked it up directly to my battery through a new power cord I had bought also and then stood back and watched the battery indicator, which was still showing, lose it's bars slowly, so that is obviously not the trouble either. I had sent an e-mail to Garmin and they agreed that it sounded like a defective mount and would send me a new one free of charge. I have contacted them again to say that they might as well not since that is not the problem. Maybe your advice to give them a call is a good one and I will try that and get back here to let everyone know the result of this frustrating experience.
How did that go?
fargodroid is offline   Reply With Quote
Old 06-18-2009, 04:14 PM   #8
TebKLR
TebKLR's Avatar
Oddometer: 496
Fuse?
Canadane --
This may sound condescending (it is not intended to be), but have you checked the in-line fuse in the power cord? Could be blown, vibrated loose/apart, or corroded. Also, is the power source (from the bike) fused?
Good luck, Tom
TebKLR is offline   Reply With Quote
Old 06-20-2009, 01:53 AM   #9
snake007
snake007
snake007's Avatar
Oddometer: 26
Wicked Zumo 550 Circut Board
So this was my problem....sound familiar.....my Zumo 550 was would not run off of or charge for that matter off of bike power. I have a CAM Buss installed so I have power off the battery to the CAM buss, which has a fuse, checked the power at the leads going to the mount and I had power. NOTE: If you have a CAM buss installed....no need to check continuity on the fuse bc. you will not get a reading at the GPS leads if there is a short in the fuse. Anyway, so then I checked the wire from the CAM buss to the end of the wire that goes into the Zumo mount (a four pronged end that screws into the mount) and I had power. Then I checkd the pins on the mount (one will be power and you should get a reading if power is getting to the pins). I had no reading at the pins (gold nubs that the Zumo 550 sits on). So I cracked open the back of the mount and there it was.....a burnt track on the circut board staring me in the face. I am guessing that water or moisture got into the mount (I have had my bike and Zumo 550 out in some serious rain). Anyway, I would be willing to bet it is your mount. You can get it at Amazon.com pretty cheap...about $65.00. Don't get it direct from Garmin you can find it cheaper on the internet.
Snake
Read the rest of the thread and it looks like you have someother problem. Well anyway, here is my experience for anyone who reads this trying to solve a Zumo problem. Good luck on getting the problem solved.
snake007 screwed with this post 06-20-2009 at 02:00 AM
snake007 is offline   Reply With Quote
Times are GMT -7.   It's 03:14 PM.
