Old 07-05-2004, 02:12 PM   #1
upsman OP
Oddometer: 256
airhead problem need help please
long story short, riding my 78 R80/7 yesterday when it went down to one cylinder without warning. i have checked all the usual things , spark, fuel, timing, compression they all check out good but i still cant get it to run on the right hand cylinder, it backfires out the carb on this cylinder and wont clean out, the bike has a dyna 3 electric ignition and is otherwise stock.
any help or advice appreciated thanks greg
upsman is offline   Reply With Quote
Old 07-05-2004, 02:48 PM   #2
Rubber Cow
GS Dork
Rubber Cow's Avatar
Oddometer: 5,338
Have you checked the carb main jet for debris or inspected the carb diaphragm for tears?
Dyna coils have been know to fail but I haven't heard of their ignition module/booster failing for this vintage BMW.
Hope this helps.
Jorge
"He had that rare weird electricity about him--that extremely wild and heavy presence that you only see in a person who has abandoned all hope of ever behaving"normally"."
HST-RIP
"Woof, woof woof woof ...woof woof!!!!!!!!!"
Cricket the Dog-RIP
Rubber Cow is offline   Reply With Quote
Old 07-05-2004, 03:04 PM   #3
upsman OP
Oddometer: 256
airhead problem
yes we checked the carb and put on one from another bike and still nothing, thanks for the input thats what im looking for, we have tried everything and nothing made a bit of difference so far. thanks again greg
Old 07-05-2004, 08:40 PM   #4
Chopperman
I am dead
Chopperman's Avatar
Oddometer: 27,033
Couple things
Dynas have been known to blow a channel resulting in one side barfing like that. But also check the ring on the cam where the points used to be. That ring will sometimes slip and the timing will get fuxored.
dead
Chopperman is offline   Reply With Quote
Old 07-05-2004, 10:09 PM   #5
RockyRaccoon
Found:Gideon's Bible
RockyRaccoon's Avatar
Oddometer: 62,855
Have you determined whether it's getting spark? Take out the plug and hook it back up to the wire, make sure it's grounded and then turn it over and see if you can see a spark. Sometimes the spark plug wires and caps go bad.
RockyRaccoon is offline   Reply With Quote
Old 07-08-2004, 11:38 PM   #6
Cpt. Ron
Advrider #128
Cpt. Ron's Avatar
Oddometer: 3,296
Take the left plug wire and put in the right side, and vice-versa. See if the problem changes sides. If it doesn't, it's a fuel or compression issue. If it does, it's an ignition issue.
Fuel/compression problems: blocked main jet, torn diaphragm, broken throttle cable....
Ignition: worn out spark plug caps, old spark plugs, broken coil, bad connections....
Cpt. Ron
"I don't know what you do, but I know what I do, and I don't do that." --Uncle Doug, R.I.P.
"Without the possibility of death, adventure is not possible"--Reinhold Messner
Cpt. Ron is offline   Reply With Quote
Times are GMT -7.   It's 10:26 PM.
