Old 06-30-2009, 10:11 AM   #1
jossef OP
Oddometer: 37
My DR650 Rebuild Project Thread (Yossi / Israel)
Hi everyone,
I would like to start a rebuild thread of my DR650.....as I promise to Mezo last week. since it is my first time here let me introduce myself....My name is Yossi and I am from Israel, age 40 married with 3 kids,my love to suzuki thumpers started 20 years ago and since then the DR650 is my favorite bike. I read a lot on ADV but always stays in the background.....
So, the story of this rebuid begun last year while buying a faulty motor, year 99 from a friend who decided not to fix it, so I bought it and started an overhall. The engine was disassembled in order to find the root cause of the noise been generated while changing gear.
I started by taking off the clutch cover and the problem immidiatly appear, the primary gear axe was moving, and the bearing had significant play. I then understand that I need to open the case in order to replace this particular bearing......
So the goal of the project are:
1- rebuild the engine: replacing all bearings, all oil retainers, gaskets, rings, piston etc'
2- Then find a bike with a broken engine, pay cheap and install this one.
3- Rebuild the whole bike from scratch so at least it will be like a new one.
3- Build a bike which will be a real adventure bike, good both for off and on road.
4- comfortable.
5- Able to ride long distance with larger fuel tank.
6- and then if I don't have budget problems , start upgrading each module like: shock absorber, brakes and accessories.
Realy don't know how this bike will look at the end .......with these kind of projects you know how you start but don't know how it ends, so I will go slowly slowly step by step.....
So I start with the head removal, camshaft etc
and the cylinder. As you can see the walls were shiny. Before assembling back, I tried the scratching stuff with scotch-bright and WD40 as recommended in many websites for Nikasil material- what I can tell you guys this is BS- Nikasil is very hard no scotchbright can do anything to it unless I missed something here.....
while inspecting the clutch cover I noticed that a piece of metal is missing arround the clutch rod (in the middle of the picture)- I assume this was the root cause for the demaged bearing of the primary gear axe. Probably the rod had some play and clutch release was not smooth as should be.
To make the long story short the case was openned and finally reached the faulty bearing and removed it....
On the way a new set of engine bearings was bought and the old ones got replaced.
so as all the oil retainers...
Then after the case was closed I install a new JE piston+rings, this is a high comp one 10.5:1 instead of 9.5:1.
Here I want some feedbacks from you guys regarding this uograde. How does the engine feels ? how is the riding with the new piston?
keep moving upward...now it was the engine head turn to be rebuilded. all valves spings and stuff were dismantled and kept in separate boxes.
Head was cleaned thoroughly and start lapping the valves seats.
Nice to meet you all.....welcome to my shop.
Once the head was ready I put the valves and springs back to their original places.....now it was the valves cover assembly to be taken apart: all shafts were inspected and measured with a micrometer to make sure they are in spec limits, then moly pasted them and lube.
Don't get me wrong....This pix above is the "before" cleaning....
jossef screwed with this post 07-03-2009 at 01:05 AM Reason: type error
jossef is offline   Reply With Quote
Old 06-30-2009, 10:17 AM   #2
LukasM
Oddometer: 5,425
Jossef,
I got a sneak peak at your project from Mezo and thought it was great. Looking forward to seeing more of it!
Lukas
Old 06-30-2009, 11:13 AM   #3
jossef OP
Oddometer: 37
Originally Posted by LukasM
Jossef,
Lukas
Hi Lukas
thanks, I will try to write a little each time to keep you updated, since I have a lot of pictures/photos
You can call me Yossi.
Old 06-30-2009, 11:26 AM   #4
clinton1396
Oddometer: 10
I just had to crack my crankcase open on my sp200 same as dr just to replace this drive shaft part b/c a bolt snapped off into it that made me mad lol. but it was a great learning experience good luck with the project
clinton1396 is offline   Reply With Quote
Old 07-01-2009, 06:04 AM   #5
NOSIGN
NOSIGN's Avatar
Oddometer: 94
Hi Yossi,
looking with interest...
NOSIGN
DR650SE ('97) current project
CBR954 ('03) daily ride
CBR900 ('96) the 'ol days
CR250 ('03), 125 ('89), 80 ('85) the 'ol days
KX80 ('92) the 'ol days
NOSIGN is offline   Reply With Quote
Old 07-01-2009, 10:31 AM   #6
nave
Nave
nave's Avatar
Oddometer: 354
Hey Yoosi,
Come on, don't be lazy and load more pix...
Nave
nave is offline   Reply With Quote
Old 07-04-2009, 06:01 AM   #7
GB
Mod Squad
GB's Avatar
Oddometer: 56,725
Fixed your thread title as per your request.
Old 07-06-2009, 06:06 AM   #8
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,143
Good stuff.
I havn't got much of a rebuild thread myself. It's more of an ongoing "build" thread...
NordieBoy is offline   Reply With Quote
Old 07-06-2009, 12:04 PM   #9
jossef OP
Oddometer: 37
Hi again
So the bike got stripped till the frame. the chassis was cleaned and it was clear that it will be repainted.
I sandblasted it - tooks me 4 hour to complete the whole frame then I send it to be galvanized.
Then I took the frame to a painter for regular painting, I choose a metalic color , and it come great....but
But the surprise came soon...when I inserted the engine back into the frame , I put some tape to protect the chassis and then when I took it off, the paint started to pill off ....needless to say I was disappointed....
The painter did a great job but didn't used the right primer for galvinized metal.
So without too many questions, I looked for powder coating shop and found someone. The problem with powder coating is that you don't have a big choise of colors and also the don't have metalic colors either. So I choose one that looks like metalic, a color that have some metal particles inside. When it came out the paint texture was rought and not smooth, so I did something that has not been done before- additional powder coating laquer layer. And this came great......
In reality the coating looks much better than the pix.....
friends, tha's all for today I am going to sleep....
jossef screwed with this post 07-07-2009 at 01:00 AM
Old 07-06-2009, 02:26 PM   #10
DRjoe
DRjoe's Avatar
Oddometer: 5,151
She looks great Yossi.
How did you galvanize the frame? I hope it wasn't hot dipped.
DRjoe is online now   Reply With Quote
Old 07-06-2009, 03:26 PM   #11
Mezo
Oddometer: 2,129
Pauline Hanson "Please Explain" ?
Mezo.
Mezo is offline   Reply With Quote
Old 07-06-2009, 04:08 PM   #12
DRjoe
DRjoe's Avatar
Oddometer: 5,151
I worked for a marine and civil construction company and we used to get a lot of stuff hot dipped and if it was lightly built it would warp from the heat.
I would think a motorcycle frame would warp if exposed to that kind of heat a as well but I'm normally wrong about these things.
Yossi how did you stop the head stem bearing seating surfaces from getting coated by the zinc coating.
Times are GMT -7.   It's 04:13 AM.
