Old 07-19-2009, 01:06 PM   #1
bwallca OP
Oddometer: 128
Position Marker Question
I was out exploring a bit off road yesterday and zoomed in and out a few times. After that my position marker seemed to have a mind of it's own, before it was always up but then it was sideways or down, very confusing. It was also off the screen at times. I do have 'track up' selected. This is on a GPSMAP76CSx. So what's up with that and if it does that again how do I get back to normal.
Thanks, Ben
bwallca is offline   Reply With Quote
Old 07-19-2009, 02:53 PM   #2
Howard70
Oddometer: 107
Hello Ben:
It sounds like you might have "panned" away from the current position when you were zooming in and back out. I've had that happen with other Garmin GPS units (I don't have a 76). Usually a couple of hits on the "quit" or "back" buttons (depends which your unit has) solves the problem, and your map centers on the current position again.
Howard
Thanks, Ben
Howard70 is offline   Reply With Quote
Old 07-19-2009, 02:57 PM   #3
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 12,936
Try hitting the Quit button next time. That usually fixes display problems.
dunno.....
Old 07-19-2009, 09:14 PM   #4
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,446
Could be compass heading too. My 60csx tends to "walk" a bit when it's still. If it detects motion in a certain direction, the bearing pointer shifts to that direction.
Use of the electronic compass is suggested if available.
But... just start moving and the heading should correct itself.
SnowMule is offline   Reply With Quote
Old 07-21-2009, 01:25 PM   #5
bwallca OP
Oddometer: 128
Moving does not solve the problem. I'll try hitting the quit button next time.
Thanks for the suggestions.
Ben
Old 07-21-2009, 04:17 PM   #6
Countdown
Oddometer: 5,336
zoomed in and out a few times. After that my position marker seemed to have a mind of it's own, before it was always up but then it was sideways or down, very confusing. It was also off the screen at times. I do have 'track up' selected. , Ben
Ben two issues; Track Up also has a setting for "below" you zoom out far enough it it switches to North up.
Sounds more like you hit the rocker switch to "scroll" but you should have also noticed a white curser arrow and a new pop up with a heading, position, and distance.
Jerry Counts
Countdown is offline   Reply With Quote
Old 07-21-2009, 04:49 PM   #7
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,737
Yeah, that's what I was thinking too...
Ben, what value is set in the block labeled "below" under the "orientation" block under "map setup"?
Not sure this could explain all of your issues though
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 07-24-2009, 11:37 AM   #8
bwallca OP
Oddometer: 128
The "below" value is set to 200km, I think that is OK.
Ben
Old 07-24-2009, 11:40 AM   #9
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,737
Ben
Mine is the same (120 miles). I've never experienced the problem you had (that I know of) though.
Mike S.
AMA MSTA
Times are GMT -7.   It's 02:46 AM.
