Old 07-29-2009, 04:47 PM   #1
BarryT OP
Oddometer: 674
I got the 77 BMW 75/7 now I need help
Well I picked it up today and I already have a question. The previous owner was wrong about the bikes issue. I jumped it and it fired up after a few seconds of cranking. All electronics seem to work fine. The "kill switch" doesnt go into position firmly, it seems like it could rattle up or down and kill the bike. The right cylinder is ticking by far more then the left one. I assume I just need to set the clearances on both, but here is the real issue. The generator light is on and even when I rev my needle on my meter doesnt indicate a charge. The pre owner said he replaced the diode pack and I have the old one wrapped up to prove it. What should I be looking for now alternator, fuse, wiring issue somewhere, retest the diode pack, bad battery?
Thanks,
Barry
2006 Buell Ulysses
BarryT screwed with this post 07-29-2009 at 05:04 PM
BarryT is offline   Reply With Quote
Old 07-29-2009, 05:09 PM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
Check the rotor.
crazydrummerdude is offline   Reply With Quote
Old 07-29-2009, 05:13 PM   #3
BarryT OP
Oddometer: 674
alternator?
2006 Buell Ulysses
Old 07-29-2009, 05:16 PM   #4
crazydrummerdude
Wacky Bongo Boy
Oddometer: 7,651
The spinning part inside it. The stator is the stationary part.
When I had a charge problem, my GEN light was on at half intensity all the time. It ended up being a cracked wire in the rotor. If yours ends up being bad, you'll need the special rotor removal tool (a specific bolt).
Old 07-29-2009, 05:18 PM   #5
BarryT OP
Oddometer: 674
How do I test the rotor though? Just pull the front cover off? Will I be able to see damage. I think I am going to run it and do the 1st eletrical test in my book. It should tell me if its the diode board or alternator.
-barry
2006 Buell Ulysses
Old 07-29-2009, 05:22 PM   #6
TimTowtdi
TimTowtdi's Avatar
Oddometer: 247
Berry,
Well, since the light is lit, that means the bulb is working and the rotor is not open. The voltage regulator can be tested by unplugging it and connecting the two terminals that do not have brown wires. Check at the batt for charging. If it charges, replace the regulator. If it does not, post back here.
TT
TimTowtdi is online now   Reply With Quote
Old 07-29-2009, 05:27 PM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,279
If it aint the battery...
it's usually the rotor. That's the most common alternator failure.
And, it seems, charging and ignition problems are the most prevelent of all problems on the board.
The stator almost never fails, and the voltage regulator - rarely.
Since the charge light is staying on, that indicates the slip ring brushes are good because that circuit is complete to ground. That would tell me there isn't an open in the rotor windings, though maybe it's shorted somewhere.
With the heat, rotational acceleration and deceleration, those windings take a helluva beating. Used rotors show up on ebay frequently for $35 or so.
To eliminate the voltage regulator, unplug it and jump two of the three terminals (not the brown one) which essentially bypasses it. If the system now charges, you know it's the regulator.
Wirespokes is online now   Reply With Quote
Old 07-29-2009, 06:15 PM   #8
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,533
And the best place, IMO, for Airhead electrics is Motorrad Elektrik http://www.motoelekt.com/ . Don't fret, the alternator rotor goes out.
Motorrad also has a great reference book Airhead charging systems.
'73 R60/5 Toaster
Old 07-29-2009, 06:36 PM   #9
BarryT OP
Oddometer: 674
Well i jumped the wires and the light stayed on so the alternator is at fault? I can check the windings on the stator though right? How do I prove it is the rotor?
_barry
2006 Buell Ulysses
Old 07-29-2009, 06:42 PM   #10
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
put your multimeter (ohms setting) on the 2 copper slip rings and see what the resistance is between them.
You have to make sure the brushes (black square things riding on the rings) are not touching it. block them with a piece of paper or something if you don't want to remove the stator.
if you have infinite resistance, your rotor is most likely bad.
(rotor in first pic. new and old brushes in 2nd pic)
datchew is offline   Reply With Quote
Old 07-29-2009, 06:46 PM   #11
TimTowtdi
TimTowtdi's Avatar
Oddometer: 247
_barry
You need to jump them and check charging voltage at the battery with the engine running around 2k rpm. If it is below 12.6 volts, it is not charging. Then check the resistance of the rotor. The current from the lamp flows through the regulator, through one brush, through the rotor, through the other brush and to ground to light the lamp. Is the lamp light brightly or dimly?
TT
Old 07-29-2009, 07:25 PM   #12
dduelin
Oh boy that was close
Oddometer: 1,623
_barry
You say the Gen light is bright. That itself rules out the rotor. If it had a broken wire and was "open" then the bulb would not light up. Rule out the regulator by jumping the blue and black wires at the bottom of the regulator and running the bike to 2000 rpm. If the light goes out it is the regulator. Not likely. If the light stays on it is likely the diode board or if you are lucky the PO misplaced the insulating washer under the left hand stud of two that locate the brush holder on the stator. If the washer is not between the brush holder and the stator the brushes are grounded to the stator and the light stays on. The nuts that hold the brush holder to the stator are hidden inside. The outer ones only hold the wires to the brush holder. Leave them alone. If you remove the brush holder be very careful with it. It breaks easily and costs too much to replace.
Very important! Always remove the ground wire to the battery before removing the front cover to access the alternator. If the cover touches the diode board it shorts to the block and it is ruined. The the light will stay on for sure.
Triumph Tiger 800
Honda ST1300
Honda CH80
Dave
dduelin is offline   Reply With Quote
Old 07-29-2009, 08:39 PM   #13
d mc gee
d mc gee's Avatar
Oddometer: 804
X2 Buy the book, Rick is very helpful over the phone too.
If it wasn't for my graceful wife, my dumbass would be banned already
Doug Mc Gee
01 1150 GS
84 R100RS
74 XL350
d mc gee is offline   Reply With Quote
Times are GMT -7.   It's 07:20 PM.
