Old 10-24-2009, 03:43 PM   #1
DSM8 OP
Where fun goes to die....
DSM8's Avatar
Oddometer: 4,009
990 Fuel Pump Filter How-Too
I have gone through and seen several really good threads that show a lot of details about the In’s and Out’s of the fuel filter. After 9K miles I decided as a preventative measure to change out mine. What I didn’t know were the tricks you needed and couple of really odd tools necessary to make this an easy project.
I won’t go into how you have to take of the tanks etc. I am assuming your smarter than a 6th grader (well except maybe for a couple of you) and am not going to bother with those details. This starts from the point where the pump is already removed from the tank and you have the necessary filters and O rings to make the swap.
One tip, it is really a pain in the ass to re-use the smaller of the two O rings that seals the pump to the tank. I tried but had no luck so I just replaced it with the new one.
This is what the pump assembly looks like split into its two main components. The top part in white houses the cartridge filter. You have to remove the cage, ground screw and electrical leads to remove the second part of the pump and filter from the housing. The first part is just held in place with two clips.
Those are the two ears you see above where my thumb is pointing to the ground screw I referred too.
This was the first tricky part I could not figure out, how to separate the top section to get at the cartridge filter. There are two ears internal to the piece that have to be pushed in and the inner section pulled out with a pair of pliers.
I used two 1.27mm allen wrenches to slide down the guide-way to depress the two ears, you can use a small screwdriver but you would need two sets of hands. This was fast and easy.
You can kinda see the guidways at the 3 and 6 O'clock position in this pic
Here is that part with the new cartridge filter on it. Make sure to transfer over the O ring inside the cartridge filter to the new one.
Now it was time to go after the bag filter, you have to remove the pump from the housing to do this.
Start by removing the electrical connections.
Two terminals and the ground.
The terminals are marked so don’t worry about it.
Next come the cage screws.
There is one on either side of the pump.
Kinda hard to see but they are peeking out from either side.
Once the pump is slid out of the housing you have access to the filter bag
It just pops off no screws etc.
There is one fiddly bit under the pump is a rubber thingy you have to make sure you put it back with the pump properly oriented when inserting back into the housing. Forgot to get a picture of it but if you get this far you will know exactly what I am talking about.
Now just reverse the order and put it back together making sure to lube all the o rings for safety.
Old vs. New
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 screwed with this post 06-08-2010 at 11:36 AM
DSM8 is offline   Reply With Quote
Old 10-24-2009, 07:00 PM   #2
K80JIM
Super Tanker
K80JIM's Avatar
Oddometer: 556
Nice break down of the job. Looks like you were ready for filter changes from the color of them. My 990 has 13K and I'm thinking it's about time for me also.
You're never lost as long as you still have gas!
K80JIM is offline   Reply With Quote
Old 10-24-2009, 07:02 PM   #3
DSM8 OP
DSM8's Avatar
Oddometer: 4,009
Yea I didnt have any debre in the tanks like alot of people have reported but it was alot of dusty off road, that is only after bout 9K miles.
Old 10-24-2009, 07:35 PM   #4
Dusty
Dusty's Avatar
Oddometer: 1,302
Thumb good post
Did you happen to save the sock filter? somebody here was looking for one to try to find an after market that would fit... see if i can find the post...
This is how my 1st set looked after 8000 mls.
I was able to get the plastic housing apart with a little screw diver and only one set of hands...
One thing that gave me a little trouble was when i put the plastic filter housing back on the pump , i heard the metal clips click but it wasn't completely seated and it ran like shit. So make sure that it gets seated...
I am on my 3rd set with 22,000 mls, i put in the 2nd set at 18,000 and it didn't look nearly as bad as the 1st set, i reused the big o-rings on this change without any problems so far. I also didn't find much crap in the tanks...
My old thread...http://www.advrider.com/forums/showthread.php?t=372139... I didn't get a pic of the rubber thing under the pump either...
Also in... HOW
Originally Posted by d0gWateR
Vagrant, vagabond, transient, hobo, bum. But park a motorcycle next to him and PRESTO! He's an advrider!
Dusty screwed with this post 10-24-2009 at 07:40 PM
Dusty is offline   Reply With Quote
Old 10-24-2009, 07:47 PM   #5
DSM8 OP
DSM8's Avatar
Oddometer: 4,009
I have been in contact with the manuf that was looking for make the sock filter aftermarket, I am sending my old one to him will email monday when back at work to see if he still wants it.
I looked in the HOW and didnt see your thread that was why I did this. Should of looked harder...
Old 05-20-2011, 02:05 AM   #6
Kenbike
Oddometer: 718
Did you have any luck with an aftermarket sock filter replacement?
Current Bikes: 2014 BMW GSA, 2010 Vespa 300 Super scooter ( hers), 2012 Vespa 300 Super (his)
Kenbike is offline   Reply With Quote
Old 03-27-2013, 01:17 PM   #7
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,637
Originally Posted by DSM8 View Post
..... What I didn’t know were the tricks you needed
Thanks for being there for us mechanic n00bs....
I used two cut up pieces of nylon wire tie. Fit right in there to release the top.
I have been BAD. I do not know how long it's been. Easily 20k miles.
It fell apart when I removed it, with little disentigrated pieces of plastic all over
Yes, it still ran when I parked it
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 03-27-2013, 01:26 PM   #8
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
Looks like it was due....
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 03-27-2013, 01:49 PM   #9
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,890
Mine looked like that at 12k mikes! I'd say you did well in getting that kind of easy miles out them
It's not an adventure until you cross a bridge , 2011 WR250, 2015 ktm 690r
findLadukebob
Ladukebob is offline   Reply With Quote
Old 01-23-2012, 08:57 PM   #10
4corners14
4corners14's Avatar
Oddometer: 669
filter
great post......thanks
4corners14 is offline   Reply With Quote
Old 01-24-2012, 03:36 PM   #11
Blakduk
Just trying to get by.
Blakduk's Avatar
Oddometer: 1,252
Yes, would have been *&^%$# nice to see this YESTERDAY before I took my fuel pump apart for the first time. I didn't know how to take out the cartridge filter from the white plastic housing, so after cleaning the sock filter with soapy hot water, then carb cleaner I put it all back together. 9000 kms and dirty like yours was.
A tip I found to get the pump back into the tank without the o-ring coming out crooked. You can't really do it well by hand, you're not strong enough and the pump only has to go a bit crooked and the o-ring bulges out wrong.
I set the pump against the fuel tank gently, with the o-ring just touching the sides of the fuel tank, then I put all four bolts into the corners of the pump and did them up by hand until they were holding the pump's o-rings just against the tank. Then I did each bolt up about 1/2 a turn (diagonally sequenced) at a time. It kept the pump totally even/level/straight, and I was able to roll the oring inside the fuel tank without it bulging out.
The whole fuel pump kit is about $170, I think there are options to buy just the filters at this place. ($80??) I haven't checked it out yet. http://www.powersportswarehouse.com/...007&fveh=23399
I know that there is now a "fuel pump purge kit" available. A bloke in Maryborough has built them and they are sold (in Oz) through Dalby Moto KTM and (o/seas) through a bike shop in Biloela. I think. This kit causes the fuel pump to pump backwards for 5 seconds after you have turned the bike off for 30 seconds. It is purely an electrical plug in gizmo, apparently a 5 min job. I'm thinking of getting it. They 'say' it causes the filters to last longer. Cost about $270.
FE450.
XT660R
Blakduk screwed with this post 01-24-2012 at 03:41 PM
Blakduk is offline   Reply With Quote
Old 01-24-2012, 04:36 PM   #12
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,974
We have one of the Purge Kits in hand stateside and will start testing this before the end of the month. We plan to start offering them once we get some first hand experiance with it. So far it looks like a great setup and I have a friend in OZ testing one too for feedback.
Keep you posted how this works out.
Old 01-25-2012, 05:14 AM   #13
mattc
mattc's Avatar
Oddometer: 441
Very curious what this purge kit consists of.
mattc is offline   Reply With Quote
Old 01-25-2012, 10:58 AM   #14
Blakduk
Blakduk's Avatar
Oddometer: 1,252
Straight off the Dalby Moto site. Google is your friend.
View Full-Size Image
EFI FILTER PURGE KIT
$270.00
Ask a question about this product
FIX KTM 690 ENDURO AND 990 ADVENTURE DIRTY FUEL FILTER PROBLEMS.
Now includes genuine KTM plugs with the kit!...
The EFI FILTER PURGE KIT is an easily installed computerised part, that tests so far have revealed to keep your fuel filters clean indefinitely.
Fitting instructions included. (See instructions here)
Valued at $270 AUD plus freight.
The EFI Filter Purge Unit will fit straight to the KTM990 Adventure simply by unplugging your fuel pump power wires, and plugging the unit in to the KTM wiring harness.
Then fix the unit under the battery box by zip tie and attach the power wire to the positive terminal and your ready for the bad fuel of Outback Australia.
FE450.
XT660R
Old 01-25-2012, 01:18 PM   #15
knobbyjoe
knobbyjoe
knobbyjoe's Avatar
Oddometer: 526
How does it work?
What is going on when the fuel pump is in the purge mode? Is it as simple as just crossing the wires from one pole to another to make the pump go into reverse?
KTM 400 XCRW with Thumper Racing 450 kit and 450 cam 2007
KTM 450 XCRW with Christini AWD and Plated 2008 now has 520 Thumper Racing kit
KTM 990 Adventure 2008
knobbyjoe is offline   Reply With Quote
Times are GMT -7.   It's 02:01 PM.
