Old 02-12-2010, 02:30 PM   #1
Stovebolt OP
Team Ruptured Buzzard
Stovebolt's Avatar
Oddometer: 392
Custom GPS Cradles for select Garmins and SPOTs
Hi,
As users of the 60-series Garmin GPS's are probably aware, there are cradle mounting options from RAM and TOURATECH, and either of those cradles may serve. Some users, myself included, have noticed that while the RAM mounting system is a great system - at least it is in my opinion, that the cradles themselves can leave a little to be desired. So, I went ahead and made my own to keep the pesky GPS unit attached to my cockpit. Long story abbreviated, I made a few for some friends going off-road to Baja last March, and they reported that they were an improvement over the RAM cradles, certainly in terms of performance - no more premature ejections.... as it were, so to speak. These were one-offs I made with Berg Briggs in his shop and used a one-piece clamshell design of Kydex material, and retained the standard RAM ball/diamond mount system. They work great, but are in my opinion, a bit on the ugly side.
A year later, and I've picked up with the effort at the encouragement of some users and others, and revisited the cradles and redoubled my efforts to improve them and offer some of them for sale. Each one is made by me by hand using Kydex or Concealex materials, tools I have fabricated from scratch, and they take me a bit of time for each one. I haven't tooled for mass production and I do this more or less as a kitchen table home occupation effort.
Anyway, since my business consists of me, the sole proprietor and some tools and plastic and effort, this ad falls right in line with that.
If anybody wants a cradle, I'll sell you one for $75 and mail it to you CONUS USPS. You'll need to mail me a check. Free shipping remains in effect for ADVRider inmates, indefinitely. That is, free mailing US Postal Service, Flat Rate Priority Mail with USPS tracking to the continental United States addresses. International may be extra, but no UPS or FEDEX.
Fit and finish is improving as time goes on and I get better at it, and there is still room for improvement. They look like they've been made on some guys' kitchen table. They have. But, they absolutely work, they keep your 60-series GPS mounted to the RAM system perfectly, they allow for bike-power access through the power port in the back and are reasonably workable to deal and fidget with. Hand fitting and finishing of the closure wings and clips gets me away from using any hardware like I used on my first tries - which worked, but this is better - and the fit is friction tight and compression from the closure wings of the two piece top and bottom locks the unit in place. There's also a fair bit of impact protection for the entire GPS, and especially for the antenna. The old design I did only protected the back half of the antenna.
The power on/off button area is relieved for access and the buttons are easily navigable with a gloved hand. I've tested these new-improved cradles on my snowmobile on clapped-out trails in Idaho and Montana, and I really like it. What guarantee can you expect from Home-Handyman-Built-in-his-own-garage-guy-posting-on-the-forum? If you want one and buy it and don't like it, I guess I should take it back and send you a check back for what you paid me for it. I don't take PayPal or credit cards. I'm sure I'll continue learning through this experience, I just hope it's not all bad. I've learned a lot about working with these materials already, and I've enjoyed the process and have been encouraged by the fact that what I set out to do, make a solid 60-series cradle, has been successful.
And at least I got one for me that works and is bomb-proof. "Doh..."
I call it the "Buzz Bomb Cradle" because it's a Team Ruptured Buzzard effort. I hope the cradles are as good and catchy as the name - or actually, better.
Criticisms of the product are welcomed and invited. (RAM ball/diamond mount not included, but I send a pre-drilled reinforcement insert with two bolts and locknuts for mounting to the standard RAM ball/diamond.)
These are the kinds of things you will need (and supply for yourself - I don't sell these RAM mounts) to mount my CRADLE -
A RAM diamond plate with ball
http://www.gpscity.com/ram-mount-dia...am-b-238u.html
The BUZZ BOMB Cradle is designed to connect to the RAM Diamond Plate on the back of the cradle. The diamond plate has a 1.0 inch diameter rubber ball connected at right angles to the plate, which connects directly to the 1 inch arm socket. You will also need the RAM arm socket...
http://www.gpscity.com/ram-mount-med...am-b-201u.html
You will also need a way to get this onto your bike, and there a different ways to do that with the RAM system. A common mounting is on the handlebars using a setup like this...
http://www.gpscity.com/ram-mount-zin...m-b-231zu.html
Medium length arm kit:
https://www.gpscity.com/ram-mount-cr...inch-ball.html
or maybe,
Short length arm kit:
https://www.gpscity.com/ram-mount-zi...-assembly.html
Thats the basics. There are so many options to "get your balls together" with RAM components that each rider needs to sort that out with their own bike. Different handlebar diameters take different sized U-bolts, so pay attention to your dimensions when shopping.
But I will stress that the cradle I make is designed to work only with the RAM mount system. The adjustability and shock absorption and impact resistance of the RAM mounts help keep my cradles "bomb-proof." Mounting them any other way with any other components is recommended against.
PM for further if interested, or post here. If BALDY runs a Garmin 60CSX and wants one, his is free.
Respectfully,
Dave Jankowsky
aka "Stovebolt"
Victor, Idaho
CURRENTLY AVAILABLE:
Garmin 60-Series Black Carbon Holstex
Garmin 78-Series Limited on hand availability - check with me
Garmin Montana Series Black Carbon Holstex
Both Generation SPOTS Black or (Gray fleck carbon KYDEX - discontinued color. Check with me for colors...)
All models remain $75 and I will pay to mail them to any ADV inmate within Continental United States via US Postal Service, Flat Rate Priority Mail, for free.
I need signed release form prior to mailing the SPOT cradles.
Garmin Montana now available - September 2012
Montana - Carbon HOLSTEX
Garmin Montana on left ant Garmin 60CSx on right - Carbon HOLSTEX
Montana and GEN1 SPOT
G60 and GEN1 SPOT
GEN1 and GEN2 SPOTs
GEN1 SPOT in BLACK CONCEALEX and Carbon KYDEX (now available)
Also, for the Gen2 SPOTs, they must be installed with the safety covers removed from the SPOT devices first, so that in an emergency, the buttons can be accessed without having to disassemble the cradle. In the event the user is injured and can't use his hands properly, he can still get at the buttons. They are already protected inside the cradle, and the user must agree to this install at the time of purchase. That's the indemnification in a nutshell, and here is the copy verbatim:
Buzz-Bomb Cradle For
SPOT Locator/Messenger/Tracker
Emergency Beacon
IMPORTANT SAFETY INSTRUCTIONS AND CONDITIONS
OF USE
Every SPOT user is 100% responsible and liable for use, misuse, accidental activation of their SPOT units and accounts. Using a cradle to carry it on a vehicle such as a motorcycle, ATV, snowmobile, personal watercraft, ultralight aircraft or anything else is fine – but it doesn’t in any way negate the user’s responsibilities. Ever. Period.
Installing a SPOT emergency beacon/satellite tracker-locator into a BUZZ-BOMB cradle will not cause satellite interference with the SPOT signal. However, SPOT satellite signals will experience intermittent failures to communicate between the SPOT units and the SPOT satellites as part of that technology and the limitations of that technology. Understand that as a SPOT user.
If a SPOT unit fails to communicate with its satellite and/or vice versa, you agree to hold the maker of the Buzz-Bomb cradle harmless of any and all liability and damages whatsoever. Use this cradle made of materials tested and known to be radio frequency transparent by KLEERDEX and BOLTARON laboratories at your own risk. The material will not cause any interference with GPS or SPOT devices, period.
SPOT Generation 2 Unit owners – Read and understand and comply with the following instructions: NEVER INSTALL YOUR 2nd Generation SPOT device into a Buzz-Bomb Cradle with the SPOT factory safety covers in place. YOU MUST PHYSICALLY REMOVE BOTH PLASTIC TAB SAFETY COVERS THAT COVER THE HELP AND 911 ACTIVATION BUTTONS PRIOR TO PLACING YOUR SPOT INSIDE THE BUZZ-BOMB CRADLE. FAILURE TO FOLLOW THIS INSTRUCTION COULD RESULT IN INADVERTANT SPOT ACTIVATION, SERIOUS INJURY OR DEATH.
If the safety covers are left in place and then the SPOT is installed inside a Buzz-Bomb cradle, the SPOT user will not be able to intentionally press the buttons which activate the SPOT functions without first removing the SPOT from the cradle. This may take an effort or demand manual dexterity and mental acuity that a SPOT user who is injured may not possess, and therefore may not be able to successfully activate the SPOT and call for needed assistance. It is therefore IMPERATIVE that the purchaser/user of this BUZZ-BOMB cradle fully understand this installation instruction, and agree to always install the 2nd Generation SPOT with the safety covers removed first, and never install a 2nd Generation SPOT with the safety covers in place.
This understanding, and an initialed and signed copy of same, is a condition of sale and use of this product.
I understand that I am the SPOT user and I alone am 100% responsible for use, misuse and accidental activation(s) of my SPOT device. ____________ initial here
I understand the warning about intermittent satellite signal loss between SPOT devices and SPOT satellites. _________________ initial here
I understand I will always install my Gen 2 SPOT after first removing the SPOT factory safety covers (2 plastic tabs) and never install my Gen 2 SPOT with the factory safety covers (2 plastic tabs) in place. ________________ initial here.
I will never allow my SPOT to be used by another person in any manner contrary to conditions above. ____________________initial here
Understood and agreed to as conditions of purchase and use:
______________________________ _______________________________
(Print Name) (Signature Name)
(Date)
(Above form for SPOT cradles only)
Garmin 78 in Carbon KYDEX, now available
Current lineup....
Garmin 60-Series / Garmin 78-Series / Garmin Montana Series / GEN1 SPOT / GEN2 SPOT
UPDATE August 2010 - Now offering Cradles for Garmin GPSMAP 78 in addition to 60-Series!
THANK YOU EVERYBODY for all of your support!
Stovey
Garmin 78 in carbon colored CONCEALEX, material no longer available. Cradle design still available in BLACK and 'carbon KYDEX.
G78 on left and G60 on right, mounted up for display on Casper my Friendly Punkin. 2010 450 XC-W Six Days dream bike.
G60CSx on the left in old Gray Flecked Carbon KYDEX (discontinued color) and the GEN1 SPOT in a BLACK cradle on right. Mounted up on "Casper the Friendly Punkin" - my 2010 KTM 450 XC-W Six Days.
Where I use mine during the short summer riding season in the Tetons. This image out my back door...
Stovebolt
http://bustedcompass.com
http://www.spotadventures.com/user/p...?user_id=47618
"Never Give Up"
Stovebolt screwed with this post 03-24-2013 at 02:13 PM Reason: update product info
Stovebolt is offline   Reply With Quote
Old 02-12-2010, 04:52 PM   #2
advjackass
orange crusher
advjackass's Avatar
Oddometer: 927
great product
i have used one of the original prototypes and never had an issue loosing my GPS. sign me up for a new one out of that fancy material Janko!!!
advjackass is offline   Reply With Quote
Old 02-12-2010, 09:43 PM   #3
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,169
looks cool
if i didn't already have a TT one, i'd be on this!
none of us are as dumb as all of us
clapped_r6 is offline   Reply With Quote
Old 02-13-2010, 08:03 AM   #4
Jwats
Bike till u Die
Oddometer: 141
keep your GPS where it belongs
I am sure there are other riders out there that have seen their GPS skipping across the terra firma. Our group cannot be the only bunch. This cradle works very well, it does not block the SAT signal & holds your unit firmly,heh heh. We have had the misfortune of losing a GPS. There have been quite a few miles covered to miraculously find one.You can end that bullshit with the purchase of this cradle, we did. Excellent product Jenks, I want the sexy new model. Joe
Jwats is offline   Reply With Quote
Old 02-13-2010, 10:26 AM   #5
EdGear
Edventurer
EdGear's Avatar
Oddometer: 495
Very nice looking case.
Kydex has technical data showing it good for antenna domes (covers) in the 1.5Mhz region of the GPS signal
http://www.kydex.com/briefs/126.pdf
I did a quick google search and did not find technical data on Concealex. Might want to verify the RF properties before you go too far.
Ed
EdGear is offline   Reply With Quote
Old 02-13-2010, 12:40 PM   #6
Stovebolt OP
Stovebolt's Avatar
Oddometer: 392
RF transparency of Concealex
EdGear,
Thanks for looking at this and for the advice - much appreciated. And thanks for the look at my cradle and the encouragement.
You are correct about precautionary wisdom since the performance of an antenna can be affected by surrounding materials and I did check the Kydex in the field and in the available literature, and found similar performance characteristics reported as in the example provided in your link for Kydex. My intention is to provide a printed disclaimer with links printed that substantiate claims about RF transparency for liability concerns - since it covers a navigation device and all the itinerant legal reasons for that in the crystal ball.
I haven't had more than field testing joy yet though on the CONCEALEX research, and need to source some decent scientific documentation on that RF transparency issue, neutral dielectric effects with this material. So if you or anybody else comes across any such beef in the scientific literature and would care to point me to it, I would be grateful. I'm not a scientist and don't even play one on TV, and the importance of covering this base is obvious and shouldn't be overlooked, even at this stage of the game. I do appreciate you chiming in with this point.
My 60CSX gets a 9-bird lock within about 20 seconds with the CONCEALEX, no different than without a cradle, but will that stand up in court when somebody decides to sue me? Important stuff, to be sure. (Newer MTK chipset. Haven't wrapped the CONCEALEX around SIRFIII chipset'ed 60-series, but can't imagine any difference in chipset technology affecting the antenna performance - but then again, like I said - I'm not a scientist and ought to cover that base as well, now that I think about it.)
Thanks to all who have responded and for the encouragement.
I remain -
Sincerely yours,
Stovey
Ed
Stovebolt
"Never Give Up"
Old 11-14-2010, 08:07 PM   #7
lentil
All round nice guy
lentil's Avatar
Oddometer: 5,923
http://www.advrider.com/forums/showt...6#post14491736
Stovey sorry I have been a slack ass I have just started a group buy thread!!
The first 60 series sale you get let me know and I will post my spare over 2 them!
This gear is the ducks nuts! Happy to be of help!
F5 is for wussies Command R is where the actions at!
lentil is online now   Reply With Quote
Old 11-14-2010, 08:12 PM   #8
Stovebolt OP
Stovebolt's Avatar
Oddometer: 392
Leith,
Damn - you ARE a nice guy! thanks!
Leith is the man, everybody....
Stovey
Stovebolt
"Never Give Up"
Old 11-16-2010, 06:47 PM   #9
DownAgain
Oddometer: 17
how is the 62 comming
DownAgain is offline   Reply With Quote
Old 11-16-2010, 07:11 PM   #10
Stovebolt OP
Stovebolt's Avatar
Oddometer: 392
DownAgain
Good Sir,
I am sorry to have to report that I still have not been able to tool for it, and that cradle is just over the horizon. I just composed a post for my brothers down in Australia, and it's here below, FYI. I WILL post up when I have that one ready for sale.
My continued sincere thanks for your interest, and I have you on my Garmin 62 list!
Stovey
Stovebolt
"Never Give Up"
Old 11-16-2010, 07:15 PM   #11
Stovebolt OP
Stovebolt's Avatar
Oddometer: 392
Aussie Group Cradle Buy - via Leith
For my Australian Brothers on the group buy via DESERT STORM in the Regional Forums:
Hi you guys! Jeez - I'm blushing from all this respect and attention..... THANK YOU DESERT STORM and all you fine men down under. Salute from Stovey!
I just walked in the door from a long-ish winter commute home from work over an 8200-foot pass, and I have miles to go before I sleep, so if I don't reply again here tonight, I'm not ignoring anybody. I will of course subscribe to this thread and keep people posted. First, a few answers to a few of your questions.
I currently make cradles for only Garmin 60-Series (Cs, CSx, etc.) and the 78-Series which is the new marine handheld. The 62 is a new and different series, so no - I don't have that tooled up yet. Not the same unit/form factor as already mentioned by an astute GPS user on this thread. :-)
Price for either/any cradle I have is $80 US funds to Stovey per unit to Australia - with no tracking number provided. (See the post Leith quoted.) I need to talk with Desert Storm (Leith) about shipping and distribution though, so hang tight with me for just a short, short bit on that - umkay? And I'll have a solid back to you on that ASAP.
It would be great in the meanwhile, if everybody who is interested enough in this cradle to buy one, actually sat down (with a beer of course) and read my commercial ADVRider thread through. That way, when questions come up, we're covering new ground and this will courteously save and respect each others' time. I'm pleased and honored to answer any questions you may have, but please accept my invitation to read through that entire thread. Especially the parts where people say they love the cradle and they think I'm great.
When I am able to get a hold of a 62-series unit to tool up with, I will, and will post up.
Everybody who is bored to tears now go and read my recent ride report here:
http://www.advrider.com/forums/showthread.php?t=630870
with video (iffy video, sorry)
or here on RDS forums with no video
Here's my website for fun:
http://bustedcompass.com/
Here's my new bike build (still in progress, it only takes money....)
http://ridedualsport.com/forum/index.php?topic=1086.0
Here's me:
No, seriously - here I am:
(I'm the friendly chap on the right - just after de-noobing in Montana last July at the ADVRider MT1K Rally and Westfest.)
Thanks for all - I am truly humbled. I'll be back around soon! PM me in the meanwhile and I will get a reply back to you.
Sincerely,
Stovey
"Never Give Up"
Stovebolt
"Never Give Up"
Stovebolt screwed with this post 11-20-2010 at 08:05 PM
Old 09-28-2012, 04:18 PM   #12
RevBill
Irreverent Reverend
RevBill's Avatar
Oddometer: 2,078
Any reason your spot cradle can't be used as a protective case on a person??
Still looking to get me one for my 60csx ..
Sent from RevBill's iPhone using Tapatalk .. Ride Blessed y'all ..
"On the road less traveled there ain't no TP, bring your own and that will make all the difference.."
RevBill's SmugMug Shenanigans
My '06 KLR
RevBill is online now   Reply With Quote
Old 09-28-2012, 08:11 PM   #13
Stovebolt OP
Stovebolt's Avatar
Oddometer: 392
Good questions and viewpoints - THANK YOU!
Good question,
Answer/opinion - absolutely no reason not to use as a cage on the person or in luggage for protective purposes. There is every reason to "encapsulate" the device if so desired, with as much protection as you want to, and my cradle form factor would arguably 'hit a home run' in that regard. One would, however, strongly desire to NOT have a RAM ball attached to it while not needed in this example, as all that would do is give an unwieldy ball in your personal carry when not needed as a bar mount. It would seem to be a fairly hardened and true protective option otherwise. I'd say, it might make out better off than a soft human tissue argument with a tree, or a guardrail, or a moose, or any other "bump in the trail" or battlefield than if left alone. The Garmins are pretty sturdy units, in my opinion, and so are the other GPS manufactured units and SPOTS, in and of themselves. But naked on the dashboard, and in crashes, and just unprotected - they are relatively more protected in a full-on cradle than not.
Can't beat logic...
...unless of course, you can!
Anyway, my two cents and thanks for the questions and interest. Your opinions and viewpoints are appreciated and valid.
Many thanks, and
Rally on,
Stovey
Stovebolt
"Never Give Up"
Times are GMT -7.   It's 03:14 PM.
