Old 02-23-2010, 12:24 PM   #1
Gustavo.Ramos OP
Gustavo.Ramos's Avatar
Oddometer: 932
Talking My own DR650SE mod thread
Hi,
After a few months absent due to unscheduled events, looks like by the end of 2009 the planets are aligned enough to restart my Project.
Almost one year colecting parts, searching, reading, cursing i finally did a few mods to my mature DR650SE ’97.
I apologise for my English, but as someone once told me “you sure speak a lot better English, than most here speak Portuguese!”.
Some items to be covered:
Exhaust
Engine
Suspension
Lighting
Protection
Comfort
Range
Here it is… before:
Practically bone-stock with na extra 130.000 kms of (ab)use by me and 2 or 3 other previous owners.
Firt step: Exhaust
Out with the stock one, let’s get a GSXR. I didn’t had the 2000/1 1000 gixxer can, so i used the 750 counterpart. Yes a bit heavier, and the sound isn’t he same either, but still much better than stock anchor
Link pipe was done in stainless steel by a local.
Nothing too scientific:
Front Forks
As Lukas already did on His DR650, i followed His excellent work. However firt I managed to get some progressive springs, but who was I kidding? WP forks rule!
Got a nice deal with forks, brake calyper+master cylinder, wheel, rotor and a good tire.
Only needed the handlebar and triple clamps. Manageable too!
However nice deals sometimes pose a few surprises:
Need a complete rebuild, oil was low and seals dead.
Ups... Washer that holds forks inner tube and outer tube in one piece. On was ok (flat) the other, a bit more and someday the tubo would comeout. Not good.
Improvising
OhOh….
Bad sign, the hidraulic was toast, but i managed to get it back to life
Home made seal fitting tool.:
Triple clamps… in Orange!?!?!?!!!?!?
Before:
Aircraft paint stripper!
Oh baby… (in a matter of few minutes)
Assemble.
Old forks:
And increased bar height, a few extra 50 mms.
Then i noticed the stock headlight mounts would not fit, and i needed to go for a ride.
So i got this really stinky solution
Bah… but at least i have lights and cops won’t bother me…too much.
The engine
After 12 years of (ab)use, billions of strokes, thousands of fuel liters, 3 or 4 owners, 130.000kms, engine started giving up… Oil burning, vibration, gears jumping off, etc.. not good.
And the 3rd gear ghost always around me made do the correct thing before the engine would go out with a big bang… in the middle of friggin nowhere… and since the 3rd gear was getting worse by everyday… it was time.
It was time for a big mistake. Had to wait 4 months to get all the necessary parts to rebuild the engine. Unbelievable… Next time I’ll order these in Germany to Stefan Hessler, or get them directly from the states.
Live and learn!
Ended up with few pictures and i somehow lost a memory card..
The condition of one of the gears (not the 3rd one)
Overview
After assembling, it fired right away!
Clear increase in torque, power and smoothness
Took the time and shimmed the head by 0,7 mm, just to increase compression a tad bit!
Then 1000 kms of break in…
By the end of these 1000 and a few hundred more, everything was retightned and also too the chance to install a different camshaft.
Result? Quite interesting!
Lighting
The previous lighting solution sucked.
I remembered I had somewhere a headlamp from a Suzy SV1000N. With it I also found a Givi winshild, that would be useful for longer distance rides
So i needed to do some mountings.
A bit basic yes…
And the result.
Not exactly what i had in mind, but for now… will do.
Rear suspension
While looking for alternatives i came accross this WP shock for a KTM… which KTM!? I don’t know. Neither the seller knew as he told me he had bought it for his 640 and was too big.
The stock DR650 rear shock measure 45 cms between axles, this one was 46 cms. Maybe I could benefit from a few extra cms!
Price was too good to pass by so I snagged it.
Stock vs WP
Small adjustments required
Overal height increase was 4 cms
Got a CRD bash plate too.
Didn’t come with mountings so I had to build them
Only after going for a ride i really noticed how much stuff hits the cases. Never heard of that pinging sound before.
Also found something i wanted to try. A wider exhaust header
Disassemble
Compare
4,5 mms wider!
Before:
After
It’s a bit noisier… can feel some difference with médium to high revs, but low end is a bit softer, maybe due to lower back pressure caused by wider tube
Range
The choice was the Acerbis 28~30 Litre that is fitted on the KTM 620/640 Adventure. With the tank i got the seat too.
This tank fits quite well into the DR frame and tank mountings, i had to do little cut and paste.
Some rubber mountings (highly scientific)
Fittings and available room:
Central fitting.
Side fittings.
Due to tank size, the petcock is considerably lower than the carburetor, so i choose to get a fuel pump. This time was a Mikuni from a SV650...
With the new seat i also had to do some mounting mods and relocate the ECU
Current status
Before…
And after:
Testing indicates the bike i quite comfortable, not hard considering the dreaded seat from hell the stock DR650SE has, engine response is quite good, handling is much better, WP’s really make the difference. Bike is high!!
Later will get a TM40, decent lighting, roadbook, GPS, etc…
Thanks to all who helped with tips, research, and their own invaluable projects!
To be continued…
Gustavo
690R
Gustavo.Ramos screwed with this post 02-24-2010 at 04:06 AM
Old 02-23-2010, 12:34 PM   #2
Kilo Sierra
Kilo Sierra's Avatar
Oddometer: 189
Nicely done.
ks
Kilo Sierra is offline   Reply With Quote
Old 02-23-2010, 12:37 PM   #3
hscrugby
"That guy"
hscrugby's Avatar
Oddometer: 4,099
Looks really nice. Except that light.
Not sure why the light bugs me, but it does. But it sounds like that's a temporary (And I'm sure better lighting) solution.
Anyway, how'd you go about making the mounts for the skid plate? Got any more pics of that, or where it actually mounts? I'm in the same boat, have skid plate, and no mounts.
hscrugby is offline   Reply With Quote
Old 02-23-2010, 12:58 PM   #4
Gustavo.Ramos OP
Oddometer: 932
Thanks! Yes it is temporary, untill i get the front end ideias sorted out.
Regarding the mounts for the skid plate i used the 2 rear screws on the frame and 2 brackets on the front. All with a thick layer of rubber.
The mounts:
And before being tightned:
Sorry, don't have other images, but that will give you a starting point.
Edit: spelling
690R
Old 02-23-2010, 01:26 PM   #5
LukasM
Oddometer: 5,425
Hey Gustavo,
Good to see that you are still around. After the troubles with the forks leaking and the engine being done I thought you had given up on the ole' DR. Didn't you also buy a 950 Adv?
Great build up so far, I like the innovative solutions. Finally somebody has detailed what it takes to fit the 28L KTM tank, those will be a much cheaper source than the Safari supertankers. Now you also have a great base to slap a 640-Adv front fairing and lights on there! I assume you have seen Ron's awesome build where he used one?
What did it take to fit the WP shock? I have a couple of those lying around, they are not worth much to KTM people as they come stock on lots of them. But for the DR it should definitely be a nice improvement.
By the way, the ring from the forks sure looks familiar. I found the same in a set of SX forks I rebuilt last year. Must have been pounded pretty good!
Old 02-23-2010, 05:41 PM   #6
Ron Seida
Adventman
Ron Seida's Avatar
Oddometer: 1,256
Awesome build Gustavo, and like Lucas pointed out, very innovative .
One thing i would like to point out. Your fuel pump and lines are very close to the cylinder, vapor lock may become a problem in hot climates. You might want to consider either shielding it with an aluminum heat sink, or find a new home for it. Keep up the good work, i look forward to your lighting solution .
"¿Qué sería de la vida si no tuviéramos el valor de intentar algo nuevo?"
Van Gogh...
"Your the only guy i've met driving a BMW who isn't an asshole."
D. Irwin...
Ron Seida is offline   Reply With Quote
Old 02-23-2010, 05:46 PM   #7
DisTech
DisTech's Avatar
Oddometer: 616
Many interesting choices. Nice work!
DisTech - Suzuki (1993 DR350S & 1994 DR350, 1996 DR650/DR790), BMW (1999 R1100GS)
DisTech is offline   Reply With Quote
Old 02-24-2010, 04:45 AM   #8
Gustavo.Ramos OP
Oddometer: 932
Originally Posted by LukasM
Hey Gustavo,
Hi Lukas,
Yes i've been a bit away... other priorities. Main problem with forks was leaking o-rings, but that was solved! Engine parts availability was a nightmare too... never again.
Not yet on the 950, maybe a 990 soon...
I'm quietly following a number of DR build threads, and some KTM 640 with kwak engines, etc.. , i also have a full 640 Adv fairing ready in my garage with brackets and lighting too, but i find it to be quite heavy. I'm thinking about a mixed solution where i can have 2 set ups available with little hassle.
To be honest i just had to add 3 washers on the top axle, 2 on the left side, 1 on the right side.
Same thing below, 3 washers a longer bolt with locking nut and it's done.
I'll dig into that however all the fuel lines i used are reinforced a double layer of non rubber fabric that helps to protect from elements and heat.
I tried another location, but nowere else seemed to fit (at all). But i'll have a look for a heatsink.
Originally Posted by dylandr
Brilliant work! You guys are all evil! If I stay on ADV I'm never gonna stop farkling bikes!
Good job, Keep it coming!
Thanks! Don't leave ADV, whats the fun about not farkling bikes!?
Originally Posted by peteandheidi
Very interesting...just a couple of questions as im going to be mounting the same forks soon.
Did you just retain the suzuki bearing cups and use the ktm stem and bearings???
Yes, same bearing cups from the DR and KTM bearings. Have a look at LukasM DR650 Build thread.
What did you do about the steering stops???
So far i do not have them, but these will be done by applying 2 rubber inserts on each sid of the fuel tank side brackets. forks go directly there!
Originally Posted by DRjoe
bloody awesome mate your a legend
Thanks! Have you looked at your DR thread recently!?
690R
Old 02-23-2010, 12:43 PM   #9
SeanF
SeanF's Avatar
Oddometer: 2,171
Before enlightenment, change oil and adjust valves; after enlightenment, change oil and adjust valves.
SeanF is online now   Reply With Quote
Times are GMT -7.   It's 09:58 PM.
