03-17-2010, 11:24 AM
#1 |
explorer
Oddometer: 73
DR650 What have I gotten into
I bought a 1999 DR650SE last week. It has been sitting since 2003, 2010 miles, wiring harness cut through and stripped out of the bike, start / kill assemble removed, front and rear shocks modified (front shocks have air valve to add air to them?) (rear shock has a lowering link) airbox missing, exhaust system needs to be replaced, the plastic and gas tank rattled canned black complete with drips and runs
. The deal is I got the bike and clean title for 500.00Now it is like a jigsaw puzzle and I am working through it a little at a time. I pulled off the carb, cleaned and installed an oversized jet kit, got a new airbox and did the airbox mod, the tank is a piece dented and sprayed black so i will be replacing it with an Acerbis 6.6 gal which will require a bracket mod to make it fit , removed the exhaust and am waiting for a new FMF Q-4 system, waiting for new dual sport tires.I got the new wiring harness but can not figure out the wiring layout / routing. Would someone, who has their bike apart, take a picture of the wiring harness routing and post it so I have an easier job routing and reconnecting things up or is there someone close by that I can come have a look at their bike? With the way I have it routed right now there are a few open connectors with no mate to plug into. This is my first DR650 and my hope is that I can have it running this month. Thank you for your help, Steve Barrus North Bend, WA
Steve Barrus North Bend, WA 1976 BMW R90/6 1999 DR650SE 1991 DR350S 1980 XL250 Steve B screwed with this post 04-09-2010 at 11:28 AM |
03-17-2010, 11:38 AM
#2 | |
Bronze Age Fall Guy
Oddometer: 5,131
Hate gets you nowhere. |
03-17-2010, 11:53 AM
#3 |
Oddometer: 4,923
Sounds like you got a great deal!
Distech's build thread is really good, mine should have a bunch of pictures of the wiring as well. Link in my sig. Lukas
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
03-17-2010, 12:03 PM
#4 |
explorer
Oddometer: 73
These are great resources.
thank you,
Steve Barrus North Bend, WA 1976 BMW R90/6 1999 DR650SE 1991 DR350S 1980 XL250 |
03-17-2010, 01:22 PM
#5 |
plainsman
Oddometer: 89,128
The factory service manual is excellent, and there are excellent drawings for routing the wiring. It might be worth buying it. I enjoy reading it.
_______ |
03-17-2010, 02:52 PM
#6 |
explorer
Oddometer: 73
The bike also came with an 18" rear tire and no tachometer, is that common or after market?
04-04-2010, 03:08 PM
#7 | |
Oddometer: 172
Hi Steve,
I don't know if you already knew about this, but the 1998-99 DR650s can have a problem with the starter gear (depends on the serial number, you can Google "Suzuki DR650 starter problem", or something like that for the scoop). I also have a 1999, and replaced the solid gear that was driven by the starter motor, with the earlier/later gear that has a torque limiter clutch. If the engine backfires when it shuts down, this can break the solid gear, and that apparently destroys the engine case. Interestingly, my torque limiter came from a 1995 DR; I checked the part number from one of the on-line Suzuki parts houses, and it was identical to the later number. The retail price for the parts is about $175, but I bought mine through eBay for $40... Regards, Harry Quote:
04-05-2010, 12:59 PM
#8 |
explorer
Oddometer: 73
Ok I set up a smugmug account and here we go My bike in a box.
![]() this is what the wiring harness looked like ![]() some sort of front fork mod ![]() my rear wheel was on this bike so i assume the rear wheel on the 650 came off of this bike ![]() parts used to get the rear wheel to fit ![]() rear wheel I took off ![]() Misc photos ![]() ![]() ![]() busted off the chain guard mounting brackets ![]() wear on the swing arm
Steve Barrus North Bend, WA 1976 BMW R90/6 1999 DR650SE 1991 DR350S 1980 XL250 Steve B screwed with this post 04-05-2010 at 01:29 PM |
04-05-2010, 01:02 PM
#9 | |
explorer
Oddometer: 73
Thanks, My SN is after Suzuki changed back. Do I still need to check?
