Old 03-31-2010, 05:38 AM   #1
By-tor OP
remember 6/6/44
By-tor's Avatar
Oddometer: 256
Klr 650 Battery
What battery should I get that will fit properly? Bike Bandit has some for around 85.00.
By-tor is offline   Reply With Quote
Old 03-31-2010, 06:54 AM   #2
tofire409
Geared up and ready.
tofire409's Avatar
Oddometer: 654
I went with the Yuasa sealed. As for the size... bike bandit should be able to get you the right size. The web site looks like it gives you all the options that fit.
http://www.bikebandit.com/2006-kawas...6?mg=43545&t=1
The link is from a Canadian site, but maybe the part numbers will work.
http://dualsportplus.com/klr650/batt...0_battery.html
Damn I wish all roads were dirt.
2011 White F800GS, 30,000 km's
Toronto to Maine and back, Toronto to Boston -The Long way, To the Dragon, 2days TCAT
tofire409 is offline   Reply With Quote
Old 03-31-2010, 07:44 AM   #3
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
STOP!
This is probably the best motorcycle battery I have ever bought. Cranks the engine faster and holds a charge longer than any others I've tried. Here is the right one for the KLR. $66.95 with free shipping.
DEKA PowerSport Battery (ETX15L)
http://www.tristatebattery.com/produ...roducts_id=977
Mike S.
'09 Bonneville Black, '05 KLR650, '07 Yam Majesty
AMA MSTA
http://www.reddeliciousband.com
tbirdsp is offline   Reply With Quote
Old 03-31-2010, 07:56 AM   #4
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,929
I bought my KLR in February, 2007, and one of the first things I did was put in one of these. It's been fantastic. You'll have to do some fiddling to get it to fit, but it's worth it.
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al screwed with this post 12-06-2010 at 10:49 PM
Bigger Al is offline   Reply With Quote
Old 03-31-2010, 01:42 PM   #5
Dagofast
Full giggety ahead.
Dagofast's Avatar
Oddometer: 1,752
+1 with Bigger Al. My Odyssey has been in my A14 since 2005. Still going strong. (knocks on wood) And that is pretty rare for a battery in AZ.
Dagofast is offline   Reply With Quote
Old 03-31-2010, 02:29 PM   #6
kdxkawboy
Mr. NVKLRGirl
kdxkawboy's Avatar
Oddometer: 2,631
+2
The wife has an Odyssey in her KLR and I am completely impressed. No mater how long the bike has been sitting it always cranks over and it has been in her bike going on 6 years. When the current old tech battery dies in mine I will put an Odyssey in my bike as well.
When the going gets weird, the weird turn pro
kdxkawboy is offline   Reply With Quote
Old 03-31-2010, 09:42 AM   #7
JSPEED
650 Strommer
JSPEED's Avatar
Oddometer: 106
Originally Posted by tbirdsp
STOP!
+1
The Deka ETX15L is the way to go.
Fits perfectly, it's an AGM and it's affordable.
Plus it has the best terminals I've ever seen.
___________________________________________
2012 V-Strom DL650AEXPL2
www.dualsport.ca
http://www.rideatlantic.ca/
JSPEED is offline   Reply With Quote
Old 03-31-2010, 12:43 PM   #8
CA Stu
CA Stu's Avatar
Oddometer: 47,291
I buy the Walmart specials, they are $34.99 out the door and I get at least 3 years reliable service out of them with maybe one or two fluid level checks (if I remember to check at all ).
CA Stu
http://youtu.be/C6cxNR9ML8k
CA Stu is offline   Reply With Quote
Old 03-31-2010, 01:38 PM   #9
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
CA Stu
No way would I use a regular lead/acid battery again. I cooked my OEM battery dry *twice* in 15 days on the Continental Divide ride The second time it was a goner (luckily it died for good in my driveway).
Get the Deka AGM and be done with it
Mike S.
AMA MSTA
Old 04-01-2010, 07:20 AM   #10
Iron Horse
I Make Shit Up
Iron Horse's Avatar
Oddometer: 9,284
STOP!
+10000000
Wandering Wapiti
Iron Horse is offline   Reply With Quote
Old 01-28-2013, 02:20 AM   #11
macdoc
Canuck in Cairns
macdoc's Avatar
Location: Jan- Apr Cairns Qld - May- Dec Southern Ontario
Oddometer: 240
any Aussie riders on here?
My KLR battery went dry from no maintenance over a 9 month layaway in very high temps in a metal building. ( friends were supposed to ride it etc )
Even the fuel cooked out of the tank.
Bike started and ran fine once it had juice but needs a new battery - suspect it was the original from 2004 anyway.
Inclined to cheap since I only ride 3 months of the year but would prefer sealed.
Got any sources thanks.... 2004 KLR 650
Ontario Canada rider staying in Cairns Australian for 3 months each year Jan to April.
macdoc is offline   Reply With Quote
Old 03-31-2010, 05:43 PM   #12
welder
welder's Avatar
Oddometer: 1,523
Odessey batteries are a pain as you have to extend the battery cables and mount the battery on its side. just get a agm replament and be done with it. no mods,no fluid to check. its just easy.
"If you come to a fork in the road, take it." Yogi Berra.
welder is offline   Reply With Quote
Old 03-31-2010, 05:53 PM   #13
tbirdsp
REMF
tbirdsp's Avatar
Oddometer: 8,739
Mike S.
AMA MSTA
Old 03-31-2010, 07:41 PM   #14
subybaja
subybaja's Avatar
Oddometer: 2,889
A replacement battery would be way down near the bottom of the list of stuff a new KLR needs in my book.
Originally Posted by OP
Motorcycles owned currently:
04 Suzuki DRZ 400S, 05' KLR 650
Another happy Odyssey user here. Extending the wire is easy, and the bullet-proof battery is great.
We had part of a Slinky. But I straightened it.
subybaja is offline   Reply With Quote
Old 01-29-2013, 08:35 AM   #15
pilot815
pilot815's Avatar
Oddometer: 1,443
I was very unhappy with a deka I tried a few years ago. After about one to two hours of charging my gps off the electrical system it would blow the 1-2 amp fuse in the charger. Swapped the battery for an odyssey when the deka died, and problem solved!
Sent from my Samsung Note 10.1
2009 KLR650
pilot815 is offline   Reply With Quote
Times are GMT -7.   It's 09:39 PM.
