Old 09-14-2010, 06:31 PM   #1
alexk243 OP
alexk243's Avatar
Oddometer: 398
1970s Sears Free Spirit 8088 Moped NEED PARTS
I am trying to fix a 1970s Sears Free Spirit 8088 Moped and it is running and whatnot, but its bogging down on full throttle and not wanting to go good without the choke on, I am thinking about replacing the jets, but I dont knwo where to get them from. Any ideas? Would there be any other names this scooter would be sold under?
1992 Yamaha TDM 850
1980 Honda CX500
1977 Honda Goldwing GL 1000
alexk243 is offline   Reply With Quote
Old 09-14-2010, 08:03 PM   #2
approachbears
250cc is 50cc too many
Oddometer: 917
Head over to moped army.
approachbears is offline   Reply With Quote
Old 09-15-2010, 06:45 AM   #3
2speed
Puching adventurer
2speed's Avatar
Oddometer: 854
What type of carb?
Probably a Bing?
Mopedwarehouse.
1977mopeds.
Any moped parts place.
Loud intakes save lives!
2speed is offline   Reply With Quote
Old 09-16-2010, 04:53 PM   #4
hugemoth
hugemoth's Avatar
Oddometer: 2,897
Probably just a clogged main jet. Clean out the carb. No need to replace the jets.
Old 09-16-2010, 05:22 PM   #5
alexk243 OP
alexk243's Avatar
Oddometer: 398
Well I have cleaned out everything on it. Anything that contained gas now contains dust, but I have since cleaned everything out and replaced the fuel line and filter.
I kinda figured that was the only thing that may be an issue, maybe corrorision on the jet (which it has some) has caused it to allow less gas through.
1992 Yamaha TDM 850
1980 Honda CX500
Old 09-16-2010, 05:41 PM   #6
hugemoth
hugemoth's Avatar
Oddometer: 2,897
Needing the choke indicates a lean mixture. If the main jet is clean I'd suspect an air leak, possibly leaking main seals. Jets don't go bad and don't need to be replaced unless changes such as porting, exhaust, etc., are made to the engine.
Old 09-16-2010, 06:18 PM   #7
alexk243 OP
alexk243's Avatar
Oddometer: 398
By main seals on this you mean the head? intake?
1992 Yamaha TDM 850
1980 Honda CX500
Old 09-16-2010, 07:06 PM   #8
hugemoth
hugemoth's Avatar
Oddometer: 2,897
The main seals are the ones that seal the crankshaft main bearings. Rubber seals eventually harden and allow air to be sucked into the crankcase leaning the mixture.
Times are GMT -7.   It's 12:38 AM.
