Old 09-18-2010, 11:13 PM   #1
mg8 OP
Oddometer: 153
KTM Cush Hub, Yes/No for KTM 530?
So I've talked to several folks of the last couple of years and have tried to sort through the BS. Here's what I've got:
1. Cush hub protects the transmission from torque during hard acceleration and hard downshifting on tarmac.
2. Some say not necessary for knobbies or supermoto applications some say it is essential for street riding.
What's the inmate advice? I ride 20 road/80 off-road and have Dunlop 908RR tires f/r. Opinions, upsides/downsides, supermoto or knobbies, etc.
Thanks for comments!
mg8 is offline   Reply With Quote
Old 09-19-2010, 02:04 AM   #2
yamahaman
wannabe bike builder
yamahaman's Avatar
Oddometer: 223
Thumb yes to cush
Cush drives dont really have any down sides except for maintenance on the rubbers and one extra bearing but the positives far out weigh the negatives . If you want to keep the bike long term definatly cush her up heavy sand riding also is very hard on gear box the constant loading and unloading causes heavy wear
If you turn them over quickly mabey not if you want to keep it long term cush cush cush
Build it and you will ride
My crazy bike build
yamahaman is offline   Reply With Quote
Old 09-19-2010, 02:46 AM   #3
LukasM
Oddometer: 5,386
The cush wheel is a lot heavier, and it might not be necessary on the 530 as it has a damper built into the clutch unlike the previous generation bikes. On the RFS bikes I run a cush hub on both my motard and dual sport wheel sets. Besides the 525s often cracking the solid hubs in high traction conditions, it also helps with wear on the countershaft splines, which can be problematic.
Old 09-19-2010, 12:18 PM   #4
The Letter J
lost in the 690 mega
The Letter J's Avatar
Oddometer: 893
Have you considered a dampened counter shaft sprocket as a cheaper (slightly less effective? ) alternative? The splines on your counter shaft are the same as those on a 690e/r/smc which use a rubber dampened sprocket. The difference being that the 690 sprocket is slightly thicker which could be easily cut down to fit the exc. Sprockets are available in 15/16/17 tooth for around $30.
I have not personally tried this but I have put a non-dampened exc sprocket on my 690 using a small spacer behind it, so it would make sense that it could be done the other way by removing material from the inside of the sprocket.
The Letter J is online now   Reply With Quote
Old 09-19-2010, 12:52 PM   #5
Off the grid
Chaotic Good
Off the grid's Avatar
Oddometer: 10,703
Varying opinions. Some swear by it, and others dismiss it as not needed. There was a rental company out West that runs all EXCs and their bikes get flogged mercilessly, all with 10k+ miles and they don't run em.
Were I doing a lot of SM riding I might consider it, but linking trails together and the occasional jaunt to town like I do? (80/20) Nahh..
Wedding(s) = $30,000
Divorce(s) = $25,000
2009 Husky TE610 = Priceless
Off the grid is offline   Reply With Quote
Old 09-19-2010, 01:12 PM   #6
LILBIT
Ride you must.
LILBIT's Avatar
Oddometer: 1,675
I searched and couldn't find a picture of anything but standard. Do you have one.
Dave Hopkins claims to be doing one output shaft a week due to ruined slines from DS bikes.
I eat my candy with the pork and beans-
LILBIT is offline   Reply With Quote
Old 05-22-2011, 11:56 PM   #7
montibank
Happy
montibank's Avatar
Oddometer: 2,790
Mine got replaced on my 530 @ 12k miles runnin in 60/40 street/dirt. Lookin for a cush solution now.
found these guys but they are sold out of the sproket size I want. I emailed them a few months ago and they said they are workin on a 50 tooth as well.
http://www.kushsprockets.com/design
montibank is offline   Reply With Quote
Old 09-19-2010, 01:19 PM   #8
Tusker
Tusker's Avatar
Oddometer: 843
A dampened sprocket isn't going to do anything for you. The sprockets just have a rubber piece on either side that touch the chain as it passes over the sprocket. It's basically for noise reduction, not for reducing driveline shock.
'06 KTM 525EXC
'12 KTM 300 XC-W
Ethiopia Trip 2010
Tusker is offline   Reply With Quote
Old 09-19-2010, 01:29 PM   #9
Didn'tDoit
Didn'tDoit's Avatar
Oddometer: 28
If you only ride dirt it's not necessary. I would recommended for street use.
Didn'tDoit is offline   Reply With Quote
Old 09-19-2010, 02:28 PM   #10
The Letter J
Oddometer: 893
I guess I never looked at it to see what it was all about after removal, but that is good to know... At least I don't feel so bad about running the non dampened sprocket now! Disregard my last suggestion
Old 11-23-2011, 09:11 AM   #11
overlandr
Dystopist
Oddometer: 5,849
I have a bare LC4 cush hub to weigh if someone has the Talon or RAD for comparison.
overlandr is offline   Reply With Quote
Times are GMT -7.   It's 09:52 PM.
