Old 09-22-2010, 04:49 PM   #1
SuperCruise OP
SuperCruise's Avatar
Oddometer: 329
XT1200Z Super Tenere Rostra Cruise Control Project
I have recently ramped up my efforts to install a Rostra electronic cruise control unit on my S10 and thought some of you may be interested in my progress.
So far I have acertained that, although fly-by-wire in its final implementation, the throttle assembly should be able to accommodate the attachment of the cruise control cable where the throttle cables terminate. I'll need to physically inspect the throttle assembly and its clearance with surrounding components, but the following diagram from the repair manual looks promising.
I've also poured over the wiring diagram and have managed to locate every required connection except for a tacho signal. As mentioned in another thread, I don't consider this a major issue as by using the NSS wire there are sufficient other ways to disable the cruise control namely:
  • cruise control power off
  • rear brake on
  • front brake on
  • clutch in
  • neutral gear
  • sidestand down
I've also had to include a relay for the brake signal as the LED brake lights on this bike will not provide the path to earth that the cruise control needs to see to operate correctly. The following is the current draft of the circuit diagram I am developing. Let me know if it looks as though I have messed anything up or have missed something major.
With regards to finding somewhere to mount the cruise control servo, unfortunately the S10 doesn't have the space in the left fairing area to mount it where it fit nicely in my Wee Strom so I'll have to look elsewhere. This weekend I will open the guts of the bike up and look for suitable mounting locations and cable run routes.
XT1200Z Super Ténéré 2010
Around Australia, Super Tenere Style
SuperCruise is offline   Reply With Quote
Old 09-22-2010, 05:08 PM   #2
simmons1
simmons1's Avatar
Oddometer: 1,598
Goldwing, Super Tenere, WR250R, ST1300, KLR, GS1000s, GT750, H2 750, H1 500
simmons1 is offline   Reply With Quote
Old 09-22-2010, 05:36 PM   #3
R3B
Lazy Motorcyclist
R3B's Avatar
Oddometer: 1,279
Here you have a photo of the actual throttle bodies and their placement;
Every Adventure big or small
................*is* an Adventure all in all.
.........................So every day: Give in to the call
Riding tips: . -----www.LazyMotorbike.eu-----
R3B is offline   Reply With Quote
Old 09-22-2010, 05:53 PM   #4
SuperCruise OP
Oddometer: 329
Thank you muchly. From your picture, it looks like plenty of space on the left there to run and attach the cruise control cable.
Old 09-23-2010, 08:58 AM   #5
Gandalf17
Oddometer: 8
Gandalf17 is offline   Reply With Quote
Old 09-24-2010, 05:02 AM   #6
GB
Mod Squad
GB's Avatar
Oddometer: 57,135
SuperCruise have you talked to your fellow aussies at www.mccruise.com? They do excellent plug and play electronic cruise for a range of bikes.. maybe they have something in the works for the S10.
Old 09-24-2010, 05:09 AM   #7
SuperCruise OP
Oddometer: 329
Thanks but I've checked them out in the past and they lost me with their CC solutions approaching A$1000 and you still have to install them yourself or get someone to install them on top of that cost. I reckon my implementation will cost A$300 max if it works, just like with the V-Strom home-grown solution. If I am successful, maybe they'll contact me for some sort of business arrangement.
SuperCruise screwed with this post 09-24-2010 at 05:15 AM
Old 09-24-2010, 07:39 AM   #8
GB
Mod Squad
GB's Avatar
Oddometer: 57,135
I'll be following your thread closely
Old 09-24-2010, 07:17 PM   #9
SuperCruise OP
Oddometer: 329
Alrighty, today is surgery day for my S10's cruise control operation. First up is finding a place to locate the cruise control unit. I did find what seems to be a nice spot for it underneath the fuel tank as shown here:
Here's what it looks like when I jimmy the cruise control unit in there:
It's a fairly snug fit, but with the tank down and the air filter box back on there is adequate clearance for the fuel pump and its attachments to hang down where they need to without obstruction and the radiator hose is a good 1cm from it. The cruise control unit also sits in an upright direction, as it is supposed to, but angled nicely for its wiring loom and control cable to run up alongside the right hand side of the airbox for looping around to the left where the throttle cable is connected. It's hard to take a picture with the tank down, but here's one I took from the right hand side to show clearance when closed:
This only issue I can see with this location is that it takes some of the airspace around the alternator (first pic, bottom-left, silver thingy) but I still reckon it's got enough space left for cooling purposes. I'm going to have a look at whether under the seat is another location possibility but I don't think I'll be able to mount the cruise control unit near vertical as it is supposed to be mounted. In the meantime, can anyone see any major flaws with using the location I have just identified?
Old 12-02-2010, 12:07 AM   #10
Bargenator
Bargenator
Oddometer: 168
Supercruise, I'm looking for the speedo signal wire from the ECU to fit a speedo healer, do you know which one it is, it would be much appreciated.
Cheers
YAMAHA XT1200Z
IT'S NOT THE BIKE YOU ARE RIDING, AS LONG AS YOU'RE RIDING A BIKE.
Bargenator is offline   Reply With Quote
Old 12-02-2010, 10:39 PM   #11
Bargenator
Bargenator
Oddometer: 168
Found it, stop looking.
YAMAHA XT1200Z
Old 12-03-2010, 04:51 AM   #12
llamapacker
Mr. Conservative
llamapacker's Avatar
Oddometer: 1,400
I would be interested where/what it is? Blue?
14 KTM 1190 Adventure
llamapacker is offline   Reply With Quote
Old 12-03-2010, 06:16 AM   #13
Bargenator
Bargenator
Oddometer: 168
Your right, it is blue and it runs from the ABS to the ECU, if your fitting a speedo healer this is the signal wire you splice into, pick up power from any ignition activated power source, and run the ground wire, well, to ground.
You do not disrupt the ABS or the TC using this wire as it is up stream from the ABS module.
YAMAHA XT1200Z
Old 12-03-2010, 02:49 PM   #14
llamapacker
Mr. Conservative
Oddometer: 1,400
Good job, thanks.
Times are GMT -7.   It's 03:01 AM.
