Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 12-02-2010, 04:40 PM   #1
chromedome OP
chromedome's Avatar
Oddometer: 137
XM radio from Zumo 550 to Shuberth SRC, via Bluetooth?
Forgive me if this has been addressed here elsewhere, but I've searched and could not find it...
I have my Schuberth's SRC paired to my Zumo 550 successfully. Can I plug a BT dongle into the 550's cradle, pair that to the SRC, and get stereo from my 550's XM receiver?
I know the 550 doesn't support BT stereo on its own, but will the helmet "see" both the Zumo and the dongle at the same time? The SRC's manual says you can pair it to both a GPS and a phone at the same time, so I'm assuming it will, but I bet someone here has already tried it, eh?
chromedome is offline   Reply With Quote
Old 12-04-2010, 04:28 PM   #2
s72237
s72237
s72237's Avatar
Oddometer: 3
good question...anyone, Bueller?
s72237 is offline   Reply With Quote
Old 12-05-2010, 03:24 PM   #3
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,758
The SRC-System is a very nice helmet Bluetooth implementation for the Schuberth hats but it only supports connection of one Bluetooth device via the mobile channel. When the manual states it can connect to both a GPS device and a cell phone, it also states that the cell phone must be connected via the GPS device - as you would normally do with the zumo.
You can not do as you desire. Garmin did do it right with the zumo665 but I can understand the reluctance to update.
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 12-05-2010, 05:07 PM   #4
xlcr
Stop being a dick, dick.
xlcr's Avatar
Oddometer: 4,895
I'm sot seeing that on the web site. I see A2DP support. The 550 only supports HSP.
Beg/borrow/steal a phone with A2DP support and pair it to the Schuberth. If the phone shows "phone audio" and "music" as distinct selectable options, you can pair with a 550 and a dongle.
You may have to disable pairing between the Schuberth and the phone and route all of your calls through the 550. My Motorola headset "knows" the phone supports both protocols and initiates a 3-way pissing contest if I don't limit the connections.
Also, route all non-phone GPS/MP3/XM audio through the dongle. It transitions to driving instructions more cleanly and reduces battery consumption at the headset.
xlcr is offline   Reply With Quote
Old 12-06-2010, 04:57 AM   #5
chromedome OP
chromedome's Avatar
Oddometer: 137
Okay, I have previously connected the iPhone 4 to the Zumo 550 via bluetooth, and answered/dialed called using the Zumo's touchscreen. I have the hockey puc antenna and listen to XM through the Zumo as well. Up till now, all of this audio has been routed through a StarCom1 hardwired to my helmet.
So, if I use the hardwired audio coming out of the Zumo (both nav and music outputs) and plug that into a BT dongle, pairing SRC to the dongle, I should have nav prompts, phone and XM/MP3 in stereo, right?
As stated above, I was a little dismayed that the SRC only allows BT connection to one device at a time. It's definitely the slickest, most streamlined helmet audio system I've found, but that's an annoying little inadequacy.
Old 12-06-2010, 01:15 PM   #6
lhendrik
Truffle Rustler
lhendrik's Avatar
Oddometer: 2,371
I am getting XM, MP3, Phone and GPS prompts from a Zumo 550 by using a dongle (WiRevo D1000 plugged into Zumo output) to connect to an A2DP stereo headset via (Camos BTS 200 in my case). In order to do this I pair the Zumo first to the Camos headset, this takes care of GPS prompts and phone, and then pair the dongle to the headset (Camos permits two connections at same time) to get XM and MP3's to the headset. This double pairing may be an issue for you with the Schuberth device....I don't know.
Normal is just a setting on the dryer.
2009 R1200GS A, 2008 K1200GT
lhendrik is offline   Reply With Quote
Times are GMT -7.   It's 11:34 PM.
