Old 12-21-2010, 12:14 AM   #1
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
BergDonk's DR650
Hi Guys (and Gals),
I posted some of this on the DR650 thread, buts its easy for stuff to get lost there so I thought I'd follow otehr's examples and make my own thread for my DR650 because I thought some would be interested to see what I'm up to.
I got a deal on a used 09 DR650 in February. It came with a lot of kit, including:
0.46 fork springs
8.5 kg rear spring
Barkbusters
braided front brake line
protaper bars with raiser for
MSC steering damper
wind screen
big footpegs
acerbis rear guard
headlight protector
bash plate
rear brake m/c guard
32 l safari tank
sheepskin cover
aluminium hardcase panniers and frame
megacycle muffler
extra air filter
spare rear sprocket
+ 2 sets of partly worn tyres and 11,000 kms on the speedo.
I paid $6900 AuD for the lot, unregistered. Not a gift, but a good deal I thought.
Iíve ridden DRs before and weíve had them in the company fleet Iím a casual employee of, as tour bikes. They are the ultimate do all, good at nothing in particular, but capable of anything. It was time to own one and do some adventuring.
I have ridden Husabergs in the bush for over 10 years, having a 98 FE501, now with 33,000 kms, and a 07 FE650 coming up 10,000 kms. The Bergs are reliable, but need regular +/- 5 hr oil changes as they only take 800 ml per change and with 2 ring pistons are hard on oil. The 650 with some pipe and carb work puts out 63 hp at the wheel on the dyno and weighs 122 kg blinged and fueled with 10.5 litres on the bathroom scales, so I didnít get the DR to go fast in the bush!
I got it to go far with not much more maintenance than oil changes.
Since getting the DR Iíve done a few more things to it, including strip the frame and wiring and reassemble for reliability, ie lube all bearing and wiring connectors, check for chafing etc etc.
Iíve also adding a couple of racks. I did this by removing the stock taillight and fitting an old Berg extender and light I had lying about. This made room to fit the KLX 250 rack I had lying about and left over from my wifeís bike. I then cut and welded a Ventura rack I also had lying about for the top rack. The Kelly tool bag hides under. Youíll note that its facilitated by the beefier seat which incorporates a Yam XT600 foam from the wreckers piggy backing the stock Suzi seat. Iím 6í 3Ē and have dodgy knees. While I was in there, I reinforced the subframe just in case, because I could, and it was easy to do.
Iíve also added some 12v accessory outlets to the tank bag and behind the headlight. I did this by rewiring the headlight and using the original headlight wiring for the accessories and heated grips. The headlight now uses a +80% Philips bulb and is wired directly to the battery through a switch and relay.
Iíve fitted Fastway pegs and cut down and rearset the stock footpeg hangers. I may yet fabricate new hangers without the rubber bushes. I donít want them failing at an awkward time.
The bike came with a Megacycle tailpipe and muffler as well as the stock system and crap jetting. After some debate with myself, and testing of the stock system, and looking at the Berg system and DR Staintune option, I got an FMF Powerbomb header and fitted that up. Also got a Dynojet kit and am still working on trying to get rid of the slight off idle hesitation. Iím convinced that my seat of the pants, and test hill, demonstrate a slight improvement in grunt with the header. Its now the same bore all the way through to the muffler, and the same size as the Staintune. I note that Staintune only sell a full system. Many of their other systems are either or, including my wifeís KLX250/300 which just has the Staintune header and stock muffler. I ĎTí vented the carb and removed the limit switch while I was in there, just in case.
I also modded the fuel inlet on the carb so all the Safari litres get into the carb via gravity. It seems it actually holds about 38 l.
After some further debate with myself I decided to fit an 18Ē rim. Ended up with an Excel and HD stainless spokes from JTR. Primarily it gives me more tyre choices, especially out west. The 12 mm or so of extra ground clearance is nice too, they are close to the ground! It also has the effect of removing 3 teeth to the back sprocket and slightly speeding up the steering.
I had played with gearing by trying 14/15/16 countershaft sprockets. Iím running 15/46 now which equates to 15/43 with the 17Ē wheel. This was somewhat forced on me when the bearing in the sprocket carrier collapsed while testing my jetting just after fitting the 18Ē rim. Fortunately it was near the shed and in 1st gear at the time. It locked up the back wheel and destroyed the chain. It could have been at speed up my hill a few minutes beforeÖ My 2 mates with DRs have also had them collapse, and I discovered that when we had them in the fleet they were sometimes replaced on tour. They had to be checked every day. So Iíll change them at say 10,000 kms to be safe, maybe each chain.
Iíd also read that some have lost the top chain roller. Mine was AWOL after a 1,000 km trip to Dargo via Pinnibar. The pics show a repair. The welding looks worse than it is, shadows, but I did struggle a bit getting the MIG torch in there, even with the shock and airbox out.
Another weakness that they seem to have is a fragile chain guide. I fitted a Procycle replacement and fabricated a reinforcement to support the inside up to the swingarm which is attached using nutserts.
Iíve got some more racks to make for my Wolfman panniers, coming soon. Iíve also got a set of tank panniers which work well after fine tuning the webbing.
With the suspension, I got my mate Frank Pons to fit some Gold Valve emulators to the forks and revalve the shock to suit the spring. Much better, but still I want more. The Berg benchmark is a problem. A bit inspired by Snowy, who just lives up the road a bit, and I met on a ride in Feb, and Mezo and LukasM, Iím in the process of fitting an Ohlins off a 96 KTM and a 48 mm WP USD front end off an 08 SXF. The shock is now with Frank for servicing, respringing and valving after test fitting this week when I fixed the chain roller. May also get a slightly shorter reservoir as it only clears the exhaust by 1-2 mm, and its not really enough. The extra shock length will result in 12 mm more travel and swingarm sag according to my measurements. We shall see how that effects the handling. With the 26 mm axle hole on the WP forks, I plan to fit the Suzi wheel with eccentric bushes, so can experiment with trail a bit to compensate if necessary. Means I can make a up a caliper carrier, and keep the stock brake too.
Thanks to Procycle for their great service and assistance to date. Enough words, some pics.
Steve
shed time IS quality time
BergDonk's DR650 BergDonk's XT1200Z
BergDonk is offline   Reply With Quote
Old 12-21-2010, 12:24 AM   #2
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
And here it is
BergDonk screwed with this post 12-22-2010 at 03:22 PM
Old 12-21-2010, 12:49 AM   #3
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
And here is a shot of the KTM forks fitted and tested yesterday. They work extremely well, and heaps better than the upgraded stock forks I've used to date.
08 450 SXF WP4860 MXMA CC.
They are a closed cartridge design about 45 mm longer than stock. i set them up at 25 mm higher, ie 20 mm poking out the top clamp, and with the 12 mm ride in the tail due to the 18" rim it balances nicley. There is another 12 mm to come in the tail when I get the Ohlins fitted. My measurements indicated that the axle offset is the same as the DR and the triple clamp offset in the forward 20 mm position is 2 mm less than the DR triples. This means that the trail is increased, but riding suggests it steers quicker, but also more precisely, as well as absorbing the rail snot fantastically well. the 0.48 springs which I assume are in them are right on too.
There is no issue with steering locck as the KTM triple clamps are extremely low profile.
BergDonk screwed with this post 12-22-2010 at 03:23 PM
Old 12-21-2010, 12:53 AM   #4
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
I machined up some bushes so I could use the Dr wheel and brake disc. the KTM axle is 26 mm. I found an old 17 mm axle in my junk heap, and a brake side spacer that I trimmed up to get everything to line up.
BergDonk screwed with this post 12-22-2010 at 03:24 PM
Old 12-21-2010, 12:53 AM   #5
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
BergDonk screwed with this post 12-22-2010 at 03:25 PM
Old 12-21-2010, 12:54 AM   #6
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
BergDonk screwed with this post 12-22-2010 at 03:31 PM
Old 12-22-2010, 10:40 PM   #7
kaijb
ianb
Oddometer: 116
Steve
Nice machining work. I know Snowy well and have ridden his bike so appreciate what the mods can do.
63HP is a big big number even for a DR. Are you sure it was that high? Many 4 valve 650's struggle to get that much.
kaijb is offline   Reply With Quote
Old 12-22-2010, 11:51 PM   #8
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
Not the DR. My 650 Berg has 63hp at the knobs, on the dyno, lights up at any speed in any gear, instantly. The suspension is also Frank Pons' WP test bed, been through a few iterations, and it just works, and has created a benchmark that causes me to try and get the DR up to in some areas.
I'm not trying the match the 63 hp, but better throttle response will be nice. With the jetting noted above it now works better than ever, but I know with an FCR it'll be better again. I'm familiar with FCRs, having fitted one to my 501 Berg years ago, as well as playing with the 650 Berg's stock one. And besides, I enjoy the shed time, I've never had a stock bike for long, just enjoy playing with them to improve them, and then ride them, analyse whats happening, and then play some more in the shed. I can't help myself, its a drug
I even built my first frame in the mid 1970s when I created a monocoque one for my highly tuned CB500, but that's a whole other story.
I met Snowy once, on a DSMRA ride in Tallaganda early this year. He'd not long fitted the forks, and I'd not long got my DR, so I was interested. I was hugely entertained on the day following him, seeing him run wide as he struggled to pull up it for turns, and overshooting many. No point going past as it was too much fun following, watching him create new trails
I know KTMatt too, as I've ridden with him a number of times on DSMRA rides, and he's had a play on my 650 Berg too, and he's building a bash plate for me.
I don't know what geometry differences exist with a RM/RMZ front end, but being off a similar spec bike, presumably the damping and springing is similar, so would perform somewhat the same perhaps, but as Snowy and others have said, huge improvement, even over my resprung, gold valved, and tuned and assembled by Frank stockers. And the WP front end offered a drgree of familiarity from my Bergs, and price was right on the day, so went that way. Now just got to service them and fit some new seals. Next week, got other priorities in the meantime, Merry Christmas.
Cheers
Steve
BergDonk screwed with this post 12-23-2010 at 12:17 AM
Old 12-23-2010, 01:13 AM   #9
kaijb
ianb
Oddometer: 116
Cheers
Steve
That makes sense.
The berg produces stupid silly power and weighs nothing. I am glad you are not claiming those ponies from the DR.....mind you I saw some supermono's in the UK making those sort of numbers from the DR donk but hand grenades I must say.
Since Snowy fitted the RMZ swingarm, his bike well and truly out handles the engine. It is a credit to him and makes you want one....for a bit.
Old 12-23-2010, 02:04 AM   #10
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
That makes sense.
And the thing is that the hp is useless if it can't be used. The Berg's 63 hp makes for fun bragging rights, but would be useless if it wasn't so usable, predicatble, linear, and with no powerband to speak of, just goes from off idle. The DR is peakier, believe it or not.
But the DR is also smooth and has enough power to do what I want it to, the centre and Kimberly mid 2011 among other adventures. I just like fiddling, refining and improving. I've learnt over the years to mostly leave engine internals factory, and play with the outside for reliability, and cost effectiveness. The best money you can spend is actually on rider training followed by suspension.
Steve
Old 12-23-2010, 02:48 AM   #11
kaijb
ianb
Oddometer: 116
Steve
I am a big fan of suspension first and foremost. I would take Snowy's bike anywhere but standard they crack the swingarm and that is a weakness you do not want on any bike.
I would like to try the dr600 twin port head on the 650. It ran a flat slide and the KTM headers fit right up. I think that could help but it is just a guess...
Old 01-02-2011, 09:46 PM   #12
djones745
djones745's Avatar
Oddometer: 170
Steve
Wiser words have never been uttered! Learn to ride first, next suspension then motor!
"Retreat, hell we just got here!"- Chesty Puller
Gas Gas 300 TXT Pro, plated wr450, YZ250F, 07 GSXR750 Road Racer, numerous dusty buddy bikes
djones745 is offline   Reply With Quote
Old 12-26-2010, 01:33 AM   #13
Dakar Dan
Dakar Dan's Avatar
Oddometer: 970
Thanks for the very informative write-up, Berg Donk. Could you give a klutz a bit of info about this carb mod: is it just adding a breather tube (upwards) to the float bowl overflow tube (downwards)?
Now comes with less dak and more arrgh!
Dakar Dan is offline   Reply With Quote
Old 12-26-2010, 01:42 AM   #14
BergDonk OP
BergDonk's Avatar
Oddometer: 3,467
For a klutz, you've got it nailed
I ran the top tube from the T fitting up to the steering head and added a small fuel filter I had lying about at that end. Seat base, or airbox top level water crossings have been negotiated to date OK.
At the bottom ends of any vent lines, the idea is to cut the end diagonally and split them for say 15 mm. This reduces the possibility of them clogging up with stuff.
Does the T eventing make a difference? Dunno, but its easy to do, and has worked for me on other bikes, albeit with different carbs.
Steve
Old 12-26-2010, 02:07 AM   #15
Dakar Dan
Dakar Dan's Avatar
Oddometer: 970
Ah-ha. Think I ran myself into problems recently by running the overflow tube upwards to the airbox, which kept it dry but of course didn't allow it to drain properly. With the lower end: is the split to act as a valve of sorts (ie. sucks itself closed under vacuum) thus "inhaling" through the top arm instead? And why the diagonal cut?
Times are GMT -7.   It's 02:33 AM.
