Old 01-03-2011, 02:11 PM   #1
lenny6753 OP
Oddometer: 88
Need help with mounting HB crashbars.
I ordered set of Hepco Becker crash bars for my Christmas present to me for my '10 Adventure. I'll try to keep this short but I just spent over an hour trying to mount just one side(left side) to the motorcycle. Between the bolt, spacer, washer, lining up the holes for the upper engine guard(i think that is what it is called), then trying to screw the bolt into the hole without stripping the bolt or bolt hole it is not working. I don't know if the crash bars are slightly off alignment wise or what but I had to stop before I started throwing tools. Does anyone have any suggestions or pictures that would possibly make this easier? Any help would certainly be appreciated
lenny6753 is offline   Reply With Quote
Old 01-03-2011, 02:44 PM   #2
grinns
Semper Fi
grinns's Avatar
Oddometer: 1,327
Don't worry you will get good at putting them on and taking them off.
Mine were a pain to at first.
2012 300 EC Race
2010 690 R
2014 hypermotard sp
grinns is offline   Reply With Quote
Old 01-03-2011, 04:13 PM   #3
KTMandu
Adventurer Wannabe
KTMandu's Avatar
Oddometer: 332
http://www.touratech-usa.com/media/Y...370-0310-1.pdf
Hope this helps. Mounting the bars can be a PITA but you'll get it.
I start with the lower bolt first and just thread the bolt in a few turns, then do the same for the bolt over the battery compartment and then move to the bolt that clamps the CB to the frame. Once all three bolts are loosely threaded in, then you can tighten them all a little at a time.
14 500 XCW, 06 950 Adv, 06 400 EXC, 00 300 EXC
KTMandu is offline   Reply With Quote
Old 01-03-2011, 04:20 PM   #4
RozzyCat
Bleeds orange
RozzyCat's Avatar
Oddometer: 537
I faced the same ordeal recently. I found it much easier to do one side first while keeping the other side intact. This held the guard pretty much in place. Do the lower bolt (engine guard) first and then one going into the tank. That last one - that attaches to the frame - aaaargh!
I'm not looking forward to that next oil change. But practice makes perfect, eh.
RozzyCat is offline   Reply With Quote
Old 01-03-2011, 04:24 PM   #5
killurtv
free range moron
killurtv's Avatar
Oddometer: 640
+1 on this routine. Just rebuilt my water pump and changed oil, put crash bars back together as described above, perfect.
one day I will learn, until that day... fuck it.
2001 HONDA XR650R
killurtv is offline   Reply With Quote
Old 01-03-2011, 05:45 PM   #6
lenny6753 OP
Oddometer: 88
Thanks for the replies. I had to step away from it for the evening as I was thinking some evil thoughts. I'll try again tomorrow.
Old 01-03-2011, 08:05 PM   #7
AdvRat
AdvRat's Avatar
Oddometer: 175
I am getting ready to deal with the same issue for my new 2010 990 Adventure - I hope you don't mind if I ask a question that kind of relates to this situation, and maybe not? What made you decide to go with the H&B crash guards and not the SW or Touratech? I'm trying to decide on the 2 companies (H&B or SW's) and even thou they are very similair - I guess there is a decent weight and/or build difference. So I'm not sure which ones to go with. I guess SW have much thicker tubing, and weigh a little more, H&B use thinner tubing, weigh less and cost a little more. Sorry if this is a little off track/thread. Thanks & good luck, I'll be there in a couple weeks myself if I ever decide - they will be my Christmas present also from my Christmas farkle money.
AdvRat is offline   Reply With Quote
Old 01-03-2011, 06:01 PM   #8
jeveretts
jeveretts's Avatar
Oddometer: 488
+2 this is exactly how I do mine and it works perfect.
jeveretts is offline   Reply With Quote
Old 01-03-2011, 10:57 PM   #9
Subutai
Oddometer: 555
What are you crying about, I removed the chain guard, or whatsamacallit, well the plastic thing between the swingarm and the rear wheel on the chain side. Two screws on top, one under. The screw on the underside did not strip, THE FUCKER CAME OUT WITH THE THREAD! Great, brand new '10 bike. Guess did it line up when I put it back together? ..and trying to make the screw seat on the thread what was left in there was great. Prolly have to glue it on with thread locker or something.
I've got SW Motech bars coming, let's see if they are such an ordeal as yours.
Subutai is offline   Reply With Quote
Old 01-04-2011, 06:17 PM   #10
lenny6753 OP
Oddometer: 88
Thanks for all the help. I haven't got around to working on 'em again but will this week. The stud mounts are a good idea.
AdvRat - The only real reason I chose the HB bars over SW was I liked the look of the HB's better, for what that is worth. I cannot comment on the design or sturdiness of one vs the other.
Old 01-04-2011, 06:38 PM   #11
ten_fiver
ten_fiver's Avatar
Oddometer: 2,035
Advrat: can't really compare the other brands, but I have the SW's. They are very solid, and I like the cross-brace by the radiator.
About the mounting studs: trust me, those bolts on the battery box are the ones that are the trickiest to get in (imo) and the threads will strip in a heartbeat. There were a few thrown tools when I stripped my first one.
ten_fiver is offline   Reply With Quote
Old 01-04-2011, 06:39 PM   #12
RoundOz
Plenty of seasoning
Oddometer: 1,015
My thoughts...
The studs are a MUST if you want to maintain sanity and avoid having to dig tools out of the garage wall. I made my studs from countersunk allen bolts, heads ground down, so that I had a way of driving them in, as my local fastener supplier doesn't speaky-da-metric too well and didn't have setscrews that size. I am looking into reversing the rear frame clamps as well and mounting some "studs" (actually bolts with a spacer and nut) as well, as I find getting a wrench on the nut at the back, particularly on the right side, almost as big a PITA as the front bolts were. Reason suggests this set up won't be quite as strong as the right way around but...I will let you know how that goes if I get a chance to do it soon.
Hmm...could this be done with the lower tank bolts too...?
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 05-01-2012, 04:13 PM   #13
Corn Fed
Son of Carl
Corn Fed's Avatar
Oddometer: 42
Dangnit...I wish I had read this before galling the threads getting the $#(%*^ HB bars back on my bike today. It was my first shot at reinstalling them and I failed the class. I even tried gently lining up the hole with the smooth end of a tool that fit perfectly in the hole. The tanks not fitting particularly well didn't help matters.
It looks like I will be tapping and installing some studs.
CBC
Corn Fed is offline   Reply With Quote
Old 05-02-2012, 06:16 AM   #14
DragonsTailR1
DragonsTailR1's Avatar
Oddometer: 85
If you will remove your glove box and loosen the top bolt that secures the tank to the frame it makes it a breeze to get your bottom bolt in. Otherwise, good luck!
DragonsTailR1 is offline   Reply With Quote
Old 05-03-2012, 07:16 AM   #15
michaelmy
Oddometer: 30
You need to instal the studs on the battery box
I also use a nylock nut at the bottom on each side side in place of the KTM metal tab washer nut thingy
Also dont forget to make sure the back bracket round the frame tube is on solidly
Michaelmy in Fulham
06 HP2, 67 Honda Monkey (since new!)
michaelmy is offline   Reply With Quote
Times are GMT -7.   It's 01:02 PM.
