01-14-2011, 03:10 PM
#1 |
FunHog
Oddometer: 3,455
Double Dog Hack
I got a sidecar rig last year mainly to allow my dogs to come along with me for rides.
Problem is the two Golden Retrievers will not both fit into my Velorex 562 sidecar body at the same time. Here's a recent shot with the larger male (Roscoe), who weighs around 80 pounds: ![]() It's quickly became obvious that my 60-pound female Goldie (Bailey) isn't going to fit at the same time. So I've been trying to come up with a plan for a new sidecar body that I can switch out depending on whether riding people or canines. After seeing this rig on another thread I thought the basic design could work for my rig: ![]() I'm probably going to do with a fiberglass-covered wooden substructure instead of the sheet metal of the one above. I'm planning to put a hinged door between the front of the car and sidecar wheel and a waterproof hinged trunk behind the doggie compartment. Anyway, this is an initial concept; nothing set in stone. ![]() I'm posting here hoping that some inmates with experience of this kind can offer suggestions that might help prevent me from making obvious mistakes. Thanks in advance for any suggestions/comments.
My book's website (Now Available) 2003 BMW F650 Dakar (Back from the Brink) 2003 Victory V92C + Velorex sidecar chassis + Harley sidecar body (Canine Chariot) ![]() 2010 WR250R (Twiggy)
01-14-2011, 03:47 PM
#2 |
Will ride for bacon.
Oddometer: 2,789
I don't have much to add but I am curios what comes of this.
01-14-2011, 04:22 PM
#3 |
Travels With Barley
Oddometer: 2,440
I'm also curious about this. I have a Hannigan dual sport, which is very similar to their classic. With the seat removed, I have a very large opening and have actually fit three of my four goldens inside. The problem is they all want a place up front. The Hannigan is wide enough that two can sit abreast, with noses out each side of the windshield. But the third dog feels left out, and when he tries to squeeze in fights break out.
If one of your dogs is clearly dominant it might work out with the submissive willingly taking the back seat. Interesting challenge. Let us know how it turns out. Pete |
01-14-2011, 06:01 PM
#4 |
Wrong Island, NY
Oddometer: 1,242
01-14-2011, 06:57 PM
#5 |
I solved that problem with my Grand daughter by doing this:
'99 Ural Patrol '02 Ural Sahara BC '03 BMW CLC/Ural '06 Honda Ruckus /Sidecar '10 Ural ST Solo http://www.flickr.com/photos/ivanrider/ |
01-14-2011, 07:17 PM
#6 |
Dirt floor engineer
Oddometer: 492
I like the rumble seat idea.
01-14-2011, 10:19 PM
#7 |
Heckler™©®
Oddometer: 3,459
First of all ,I loved the fact that you took the time and effort to photo-shop the dogs into the drawing .Excellent
Just an idea .A CJ or something from China . ![]() ![]()
I'm diagonally parked in a parallel universe . |
01-15-2011, 03:47 AM
#8 |
FunHog
Oddometer: 3,455
Thanks...
...For all the comments and ideas. Muchly appreciated all
![]() I should have mentioned above that I'm trying to keep this project simple (and as inexpensive as possible). And while I like the concept of the rumble seat for riding people, I don't think the added complexity and loss of storage in the rear would work for me and what I'm trying to do. Another consideration is the height of the sidewalls. I was drawn to this design because it would be high enough the dogs couldn't accidently fall out. That's also the reason for the entry door in the side. Wouldn't work for people as well. Once in the hack, they'll be tethered to the floor with a quick-release webbed strap attached to a harness. This allows them to sit or lay down, but prevents their jumping out. My brother is a master cabinetmaker and is presently restoring a sailboat, so he has all the tools and skills to help me with this project. We're thinking a flat bottom made of 3/4" Baltic Brich plywood. A simple framework would support the sides, which will be some kind of bendable 1/4" plywood made for cabinet fronts where there are curved lines (such as on a television studio set). Once the frame and skin have been test fitted to make sure everything fits, we'll fiberglass the entire thing, probably using a black pigment in the resin so when the inevitable scratch in the paint comes along it won't be as noticeable. Again, that's what we're thinking after my spending 5 minutes measuring around the rig and 30 minutes in Photoshop putting together the above plan. At this point no materials have been purchased and no actual work has been done. So, I'm still open to all options.
01-15-2011, 04:23 AM
#9 |
3rd Wheel Adventurer
Oddometer: 505
Lucky Dogs!!!
Howdy!
Your idea of a new tub for the dogs is gonna look awesome beside your Victory! The dogs will love it. I'm following you on this one. Keep on going with this project! Later Kamakaziozzy |
01-15-2011, 05:07 AM
#10 |
FunHog
Oddometer: 3,455
Thanks Ty!
I'm planning to get together with my brother (25 miles away) today to come up with a firm plan of action. Will post here as the project progresses.
01-15-2011, 06:31 AM
#11 | |
Travels With Barley
Oddometer: 2,440
After 8k miles with the dog it's worked out very well for both of us.
01-15-2011, 06:53 AM
#12 | |
FunHog
Oddometer: 3,455
This clip gives a pretty good idea... Here Bailey is already snapped into the harness and I'm putting on Her Doggles and attaching the tether to the D-ring in the middle of the harness at her back, then finally clipping the 'biner to where the two harness straps cross at her chest:
01-15-2011, 08:26 AM
#13 |
Oddometer: 270
I'm sure your brother knows, but you can laminate multiple sheets of plywood together and get some curvature in it.
Don |
01-24-2011, 10:27 PM
#14 |
Oddometer: 263
ideas to ponder
You may have already considered other options which don't require as much modification as a complete tub build, such as a cargo box or even these two seater option, but they too may offer some ideas. The one tub in the b pics looks like an adapted water tank metal tub from Tractor Supply. Certainly lots of space for hack dogs in it.
http://i56.photobucket.com/albums/g162/a1930ford/a1.jpg http://i56.photobucket.com/albums/g162/a1930ford/a2.jpg http://i56.photobucket.com/albums/g162/a1930ford/a3.jpg http://i56.photobucket.com/albums/g162/a1930ford/b1.jpg http://i56.photobucket.com/albums/g162/a1930ford/b2.jpg
A sidecar without a dog is just another sidecar. MY SIDECAR BUDDY SONG: (Hold yur ears & yur nose when watching this clip) http://www.youtube.com/watch?v=0_QnN8oqPCc |
01-27-2011, 10:26 AM
#15 |
Oddometer: 263
I like the harness set up, as it does not put pressure on the neck during a quick stop or accident.
The snap you use to the front belt in the clip may not hold with a great amount of pressure applied to it, such as when the dog is pushed forward and then gravity pulls him back with great g-force. Maybe I am incorrect on it, but those snaps are more for show than for use on a security harness set up. If they are the aluminum ones (I couldn't tell by what I saw on the video clip), they don't handle g-force stress very well and will stretch loose when strong g-force is applied. I found out the hard way when my Wire Hair Jack Russle took a dive out of the moving hack to chase rabbits which had jumped out in front of us while we were riding on an old back road. I had a trigger snap that failed when the dog pulled back from it. I thought she was likely hurt badly at the time, as we were doing a good 20-30 MPH, but she was fine. There was an interesting article on Yahoo news recently in which a Vet claimed Goggles (Doggles) are bad for dogs, as it interferes with their sense of equilibrium. The Vet also claimed that dogs have a 3rd eyelid that is very good for when necessary if something is likely to get into their eyes. That may well account for all the stories of folk with Doggles having difficulty in getting their dogs to adapt to them at first. I have several pairs out in my garage, but the dogs won't wear them without a bonified fight.
