Old 02-02-2011, 07:25 PM   #1
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
950 Supermoto Turbo Build Thread
Hey All. I decided to go nuts and turbo my 950 Supermoto. Some folks, even as far away as France, have asked for info on the build so here we go. This is the virgin prior to defiling.
Current Stable : 950SM Turbo! GSXR1000 RT-P1100 VFR800 RXC620 motard EXC520 CR500AF CRF450R Plated! CR250
Past stable : 90 +
Tommy_J is offline   Reply With Quote
Old 02-02-2011, 08:09 PM   #2
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Step one : Decide on objectives
I have in mind a low boost installation. Say under 6 psi. A couple of things are really important to me. One is that boost start early and enhance the already excellent midrange. Peak power does not need to be huge but if the turbo machinery can be sized for 150 hp with good midrange so much the better.
The bike should be quiet. This is important to me as I like to travel with the front tire ½ inch off the ground whenever possible and being quiet make it possible more. Turbos make nice mufflers but additional muffling will be needed for the level of stealth I’m after.
To make things interesting I’m shooting for a net weight reduction and significantly improved off road ability
Past stable : 90 +
Old 02-02-2011, 08:37 PM   #3
andyhol
volcano rider
andyhol's Avatar
Oddometer: 153
standard 950 supermoto not enough?
increase off-road ability and add a turbo?
too awesome and really fucking crazy, good luck
current rides: tiger 200 and cb200 scrambler in indo
90 yamaha xtz750 super tenere, 98 honda vtr 1000 firestorm in the uk
andyhol is offline   Reply With Quote
Old 02-02-2011, 09:33 PM   #4
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
Step Two : Select Turbo
Looks like a clone of a Borg Warner K03 will do fine. This trim should be good for 180 HP at a pressure ratio of 1.63, or 9.26 psi boost. Not that I’ll ever run it that hard. Peak boost is achieved at 4200 RPM.
There’s a lot of talk about how great ball bearing turbos are but I have no desire to spend $700. Final decision was for a Chinese journal bearing turbocharger. K03 turbos are used on untold thousands of VW Golfs and Beetles and there are a lot of these Chinese clones running around as replacements. I goggled around to see if anyone had bad experiences with them and came up empty. Sure, the quality is more spotty than the real thing but this sucker only cost $190. If it goes bad I’ll replace it for less than a change of tires.
Here's the efficiency map
Past stable : 90 +
Tommy_J screwed with this post 02-03-2011 at 05:18 PM
Old 02-02-2011, 11:16 PM   #5
duxrneet
duxrneet's Avatar
Oddometer: 671
Subscribed
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 02-02-2011, 11:23 PM   #6
OaklandStrom
Oddometer: 1,612
Holy crap.
Subscribed!
OaklandStrom is offline   Reply With Quote
Old 08-28-2011, 04:19 PM   #7
pennswoodsed
lizards,bugs and me
pennswoodsed's Avatar
Oddometer: 773
wwwww ow !
My kind of crazy, is map from actual turbo or the kkk original ?
Thanks,Ed
pennswoodsed screwed with this post 08-28-2011 at 04:20 PM Reason: space
pennswoodsed is offline   Reply With Quote
Old 03-10-2011, 11:33 AM   #8
Friday1
Oddometer: 35
Thread about pressurizing carbs
http://www.turbo-bike.net/Pressurize%20carbs.htm
Friday1 is offline   Reply With Quote
Old 03-01-2013, 03:10 PM   #9
GI_JO_NATHAN
GI_JO_NATHAN's Avatar
Oddometer: 2,524
Almost forgot about this.
Jonathan
If guns are outlawed, only outlaws will have guns.
Originally Posted by POLLOCK28 (XDTALK.com)
From what I understand from frequenting various forums you are handling this critisim completely wrong. You are supposed to get bent out of shape and start turning towards personal attacks. Get with the program!
GI_JO_NATHAN is offline   Reply With Quote
Old 03-01-2013, 04:28 PM   #10
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
I really should do some follow ups. Sorry for letting the thread go quiet for so long.
The bike is running great. It hasn't blown up or given me any grief. I've done a bunch more minor refinements to it which I'll try to write up.
Past stable : 90 +
Old 03-01-2013, 04:53 PM   #11
soupknotzee
soupknotzee's Avatar
Oddometer: 245
soupknotzee is offline   Reply With Quote
Old 03-03-2013, 01:58 PM   #12
GI_JO_NATHAN
Oddometer: 2,524
Nice!
Really happy to hear that.
Jonathan
Old 03-05-2013, 01:01 PM   #13
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,124
I would love to see how you have refined your concept!
Tell us more tell us more!!!
snowhawk jockey is offline   Reply With Quote
Old 02-08-2014, 08:22 PM   #14
spartanman
regret minimizer
spartanman's Avatar
Oddometer: 1,100
Why water injection instead of an intercooler?
spartanman is offline   Reply With Quote
Old 02-09-2014, 09:13 AM   #15
Tommy_J OP
won't drive a car
Tommy_J's Avatar
Oddometer: 338
There are multiple reasons. I can clarify if you like but they are :
The intercooler would have been hard to package with the turbo at the very back of the bike and the intercooler needing to be at the front.
The water injection system I'm using is lighter.
The water is sprayed through the compressor. This produces great atomization. Evaporation cooling DURING the compression process better approximates an ideal (isentropic) compression process. This makes the turobocharger's "efficiency island" bigger. Also, I wanted to get evidence to slay the internet myth that water erodes the compressor. It hasn't
If I need to make minor adjustments to the fuel-air ratio I can just mix the water/methanol to a different ratio. I'm already doing this for a supercharged S2000 car, so I have jugs that are 50/50 for the summer, 60% meth for winter (adds more fuel to go along with the cooler denser air) and can "special mix" if I want to be frugal or raise the boost.
Past stable : 90 +
Times are GMT -7.   It's 09:32 PM.
