Old 05-28-2011, 08:29 AM   #1
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Waterproof Digital Voltmeter by ADvmonster
Now available for $25 on our website
DC 8-28 volts
Three wire connection: Red power, Blue voltage signal, Black ground
22mm high X 40mm wide X 19mm deep leads are 30cm long
7/8" high X 1.5" wide X 3/4" deep leads are 1 ft. long
sanjoh screwed with this post 04-24-2014 at 03:12 PM
Old 05-28-2011, 03:20 PM   #2
mbabc
Curmudgeon trainee
mbabc's Avatar
Oddometer: 1,901
Just ordered one. We'll see how it goes.
"I have never seen a Kentuckian without a gun and a pack of cards and a bottle of whiskey." - Gen. Andrew Jackson
'08 WR250R - '12 Super Tenere - '64 CT-Frankentrail
Little Blue goes looking for Orange
I don't know what time it is, I've switched to kilometers
mbabc is online now   Reply With Quote
Old 05-31-2011, 05:39 AM   #3
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Thanks for your business. Looking forward to seeing your installation.
Old 06-01-2011, 08:47 AM   #4
mchasal
Mostly Upright
Oddometer: 75
Looks great. Is it really "LCD"? It looks like a typical LED 7 segment display. Not that there's anything bad about that.
mchasal is offline   Reply With Quote
Old 06-01-2011, 07:37 PM   #5
Budo675
Budo675's Avatar
Oddometer: 860
Subscribed with a plan to buy when I'm stateside again. Got a triumph with a knack for burning up R/Rs and not charging the battery.
Can you tour on a Sportbike?? Sure....!
Budo675 is offline   Reply With Quote
Old 06-02-2011, 04:29 PM   #6
Shunka
Supervision Required
Shunka's Avatar
Oddometer: 3,962
Sweet! Just ordered as well. Can't wait to add it!! Thx!
Shunka is offline   Reply With Quote
Old 07-19-2011, 11:27 AM   #7
rich tintera
rich tintera's Avatar
Oddometer: 57
Dumb question- does wiring the voltmeter to any wire which is hot when the key is "on" yield the same readout as wiring the voltmeter directly to the battery?
I think I'll be ordering one in the near future for my VFR.
_________________
And the prophet said:
"And lo, the beast looked upon the face of beauty. And it stayed its hand from killing. And from that day it was as one dead".
rich tintera screwed with this post 07-19-2011 at 11:34 AM Reason: speling correction
rich tintera is offline   Reply With Quote
Old 07-19-2011, 01:51 PM   #8
bisbonian
bisbonian's Avatar
Oddometer: 1,020
Not necessarily. Check voltage at multiple locations and you may find it differs quite a bit.
My 2009 Alaska Adventure
bisbonian is online now   Reply With Quote
Old 09-30-2011, 03:07 PM   #9
Cromoth
Inspection due 5_31
Cromoth's Avatar
Oddometer: 571
polarity
I'm not sure I'll be mounting since this could be used to diagnose problems. What happens if you cross polarity?
When I really need it running is when the Gerbings gloves, jacket & pants are on. At idle & full heat, the stator is not making enuf juice so I'm draining the battery. Under way, heat & battery charging ( I assume since volts go >12.5). The Gerbings wire from the battery (inline fuse) should be a good place to connect this, inline would be ideal if a coupler exists in series. Seen anything like that?
What situations would you have blue & red wires separite?
Thanks, just ordered.
"Four wheels move the body,
Two wheels move the soul." http://ridingacross.com/
Three move you & the dog!
Cromoth is offline   Reply With Quote
Old 09-30-2011, 03:18 PM   #10
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,061
Originally Posted by chrisspy View Post
I'm not sure I'll be mounting since this could be used to diagnose problems. What happens if you cross polarity?.
Don't know, haven't done it!
When I really need it running is when the Gerbings gloves, jacket & pants are on. At idle & full heat, the stator is not making enuf juice so I'm draining the battery. Under way, heat & battery charging ( I assume since volts go >12.5). The Gerbings wire from the battery (inline fuse) should be a good place to connect this, inline would be ideal if a coupler exists in series. Seen anything like that?.
Yes, if it is downline of the controller and the controller uses pwm it may not work depending on the pwm frequency. The vm needs a steady state. This is another reason I would not recommend using it as a mobile tester. I would recommend this
What situations would you have blue & red wires separite?.
I haven't seen any.
Old 10-18-2011, 09:28 AM   #11
Cromoth
Inspection due 5_31
Cromoth's Avatar
Oddometer: 571
installed on WR250R
Wired to brake light, shown checking battery voltage by Key ON, Kill switch in kill position so fuel pump doesn't prime & headlight is off. Only 3 LED lights are on (front turn signals, brake light) & license plate bulb. Just run engine & press brake to see stator output. Connect heated gear (&press brake) to see watt's used. Watt's - get it
FWIW when I first connected to 12V battery, it took a wicked long time for it to show voltage. Not sure why but it needed time to power up & works without delay now.
Need to attach meter to frame: silicone caulk, velcro, other?
Old 12-12-2011, 09:00 AM   #12
bete
Oddometer: 546
Wow that was quick, ordered in the morning shipped in the afternoon received in 2 days. Haven't installed yet but it looks like a good meter. thanks. bete.
bete is offline   Reply With Quote
Old 12-20-2011, 10:27 AM   #13
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,520
If you have any questions about the install just let me know.
Cheers,
Dave
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is offline   Reply With Quote
Old 04-21-2012, 01:24 PM   #14
beverclan
Zip'n Onwards
beverclan's Avatar
Oddometer: 56
Ordered. Been looking for one of these!
beverclan is offline   Reply With Quote
Old 05-24-2013, 04:45 AM   #15
Jamie
Oddometer: 1,222
I just ordered one. Looking forward to the install. I'm a little concerned about the security of your site. Your home page says yahoo has blocked your ISP from emails, then when I got your email acknowledgement but it's stamped with Warning: This message may not have been sent by: your email.
I'm assuming it's just the storefront you use, but would you please make me feel safe and secure?
Signed,
paranoid schizo
Jamie is offline   Reply With Quote
Times are GMT -7.   It's 03:55 PM.
