Old 01-27-2012, 06:24 AM   #1
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Kawasaki ZX6D - ZZR600D build thread
UPDADE :-)
THIS IS HOW IT LOOKS LIKE ON MAY 2014
Od zzr slaganje molvice
Hi folks, bought a beatten up 21 year old kawasaki sport/touring bike that has been streetfightered really badly and really ugly, so my plan is to take it all apart, and do a complete overhaul of the bike, some parts of the engine, and build a completely custom bodywork and electrics scheme, and turn it into a trueblooded sport touring bike.
I am doing all of the work by myself, with no help, and I don't own a garage, so I am doing all of the work outside, on the "terrace" in my back garden of the house that is around 100 years old, there is 10% slope so I am leveling it with some bricks and old wooden planks. I will ad a few tips on some stuff, you can basically do all of the work alone, you just need to think outside of the box :-)
I allready dissasembled the whole thing, there are a lot of pictures of the process, so you are welcome to watch a lot of stupid pictures of an old and rusty bike xoming into a life again :-)
Od zzr 600 d - build
I will be updating this thread constantly, I plan to finish my work until 21.3.2012, start of the spring, so I have a lot of free time, but not really a big budget, so I will produce most of the stuff fon my own.
cheers,
a.
aposaric screwed with this post 05-18-2014 at 01:39 PM
aposaric is offline   Reply With Quote
Old 01-27-2012, 07:37 AM   #2
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Od 27. siječnja 2012.
A night fell, I realised I still have the energy to take the frame from the engine. Well, here is a tip for any garden mechanic as I am on how to dissasemble the frame and the motor. Every single manual says that you should have at least 3 people, engine hoist, a lift and I don't know what not. Simple logic is: engine is around 60-70 kilograms, the frame is 13 kilograms :-) Simply lower the engine on the ground, undo 6 bolts holding the frame, and lift the frame with one hand or with two, if you are a girl ;-) It is a 5 minute process, so I really don't se what all the fuss is about.
Here is the engine sitting on the improvised stand of bricks and plywood. The frame, the wheels, the forks, are all getting reassembeled, and are going to get a nice sanding, and then I am going to powdercoat them in a nice MAT BLACK colour, as it should be :-)
I have to change stator cover on the left side, I have to adjust the valves, clean out the carbs, replace few nuts and bolts, redo the radiators and electrics, and get some new valve cover seals and couple of other tiny bits on the engine. I have to redo the exhaust, intake, and then assemble the bare structure together. After that I am going to start to custom wire the thing, because a lot of factory wires are bust, and connectors don't seem too reliable to me, and there is a nice way to bypass some switches, few less things that can go wrong. I just hope it doesn't snow in the near future because it will stop my progress.
to be continued...
a.
Old 01-27-2012, 11:52 AM   #3
thomas.tc.young
Oddometer: 861
or rain. looks like a good start, i would cover everything with a tarp or something.
1969 CL350 permanent project
2013 Ninja 650
1987 XR600R
2001 TTR-125L
the klr/versys project: http://advrider.com/forums/showthread.php?t=810279
thomas.tc.young is online now   Reply With Quote
Old 01-27-2012, 05:42 PM   #4
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
There is a small balcony right above the bike, so I hope that it is going to protect it from the elements. I have a 50 square meters spare space in the first floor, but I can' really put the bike in the house because I would have to kick some walls to put it back out once it is reassembled :-) old architecture, tight corners...
Old 01-28-2012, 06:10 AM   #5
joenuclear
Planning.....
joenuclear's Avatar
Oddometer: 6,301
Thumb
+1
joenuclear is online now   Reply With Quote
Old 01-28-2012, 06:18 AM   #6
TerraRoot
Oddometer: 61
nice shots, is that a huge hole in the frame brace?
TerraRoot is offline   Reply With Quote
Old 01-28-2012, 06:45 AM   #7
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Yes, there are holes on both sides of the braces, but they are factory made. They really look ugly, but while I am et the sanding process, i am going to round the edges a bit, because I might put some wires through them in the future, once I decide how the bodywork would fit in.
There is going to be hundreds of pictures here in the future, I like to document my work so I know where the bolts go in case I forget :-) Wiring loom is pretty much straight forward, idiot proof, every conector has ots own shape, so there is not going to be any problems on assembly, and I might cut it all out in the end :-)
Old 01-28-2012, 07:02 AM   #8
Derailleur
Oddometer: 21
Having done similar things on a smaller scale, it might be an idea to put a tarp down under the bike, it's easier to find nuts & bolts when they drop onto a high contrast surface than when trying to find them under the piece of grass or slightly buried in dirt the same colour as they are.
It looks like a great project though, I'm looking forward to watching your progress.
Obligatory Bike list
2008 cbr 125 daily beater, tourer, track bike, 1986 vt 1100sc(paint it & sold), 1982 cb450sc(done & done, love drivers dontcha)
Derailleur is offline   Reply With Quote
Old 01-28-2012, 10:24 AM   #9
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
I think that I am going to build a wooden deck in a few weeks when I start to reassemble the bike, just to level the things out :-). I managed to lose one nut in the grass, but I have a couple of really strong neodimium magnets from some old hard drives, so I just take one swoosh and it colects all of the metal bits from the grass. It is amazing how many bicycle nuts I found in the last couple of days in the gras with my magnet :-)
I started to untangle the wiring loom, there are few wires that have scraped insulation, so I am going to recheck it all, to try too lose all of the unwanted resistance in the electrical circuts, to try to "blueprint" the loom as close to ideal values. It is a sloow and boring process, but it puts me in some kind of a "zen mod"
Old 01-28-2012, 10:48 AM   #10
JamesG
Rabid Poster
JamesG's Avatar
Oddometer: 10,946
A "street-fighter" came with GIVI bracketry?
Cool project. I had been toying with getting an old 6E or ZZR and tarting it up for ST duty.
Have fun.
JamesG is offline   Reply With Quote
Old 01-28-2012, 11:54 AM   #11
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Well. it wasn't really a streetfighter, rather a really sloppy repair after the crash boy racer :-) I added the Givi luggage this sumer, it is from my old" Versys, I had to mock it up because I am going to make all of the body work on my own from carbon fiber and fibrerglass, so I needed to check the clearances between the luggage cariers and the body work. I will have to relocate the water owerflow bowl to the front of the bike because I want to have the rear as slim as possible. The Givi luggage alone cost as 3 of these motorcycles put together :-)
I strongly recomend you to get an old zzr, the older the better, because they are such a joy to work on. I got borred with the new motorcycles such as Versys, they really work fantastic, and have literaly no errors, but my engeenering nature drives me to dissasemble everything and redo it on my own, so I wanted really beaten up bike that I can build from ground up based on my own specifications :-)
Bloody hyperactivity, it drives my girl nuts, whole house filled with old engines, car parts, bicycles, lights, even lego technic :-)
aposaric screwed with this post 01-29-2012 at 07:30 AM
Old 01-30-2012, 06:06 AM   #12
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Well, as it seems, we had a pretty mild winter, but as soon as I start to dissasemble my bike the shit storm comes and it seems that there is going to be a lot of snow for the next couple of weeks, so I am going to do all of the stuff that I can do inside.
I started to go through the wiring loom, all hundred meeters of it or something like that, and it is in a pretty good condition, except some loose conectors and scraped wires.
Here is a wiring in my warm kitchen, I have to source some new conectors for the new headlight, rear light, blinkers and such. I also need a new ignition sistem, the current lock and the keys are all fooked up, so it is going to be a pita to source all of the parts :-)
I started sourcing cheap parts that I can implement in the bodywork, and I found nice and beatten up zx12r fairing, with lights and the visor,
I am in the negotiation process with the owner, I am not in a rush so I am dampening the price :-) Iff I buy this mask, I am going to chop it to pieces, I really only need the lights and the surrounding parts of the mask, the rest is going to be fiberglassed in with the rest of the bodywork, which I still have to source :-) Fun stuff.
P.S. I am sory for my dislexic English, I seem to make a lot of typos, but I am doing my best
Old 02-01-2012, 06:37 AM   #13
TonyKZ1
TonyKZ1's Avatar
Oddometer: 714
Wow, nice project! Keep us updated on your progress as you go along.
Tony
1997 Yamaha Seca II - mostly stock, Oxford Sports Style Heated Grips, Barkbusters Blizzard Cold Weather Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old 02-01-2012, 06:57 AM   #14
aposaric OP
Garden mechanic ;-)
aposaric's Avatar
Oddometer: 270
Thank you for the support ;-) I sourced the brand new wiring loom from the ER6 so it is getting chopped into peaces tu suit my mutant bike build :-)
I also sourced the yamaha xt 600 steering ( wheel - *uck, I can't remember the english name for the thing that you steer with on the bike- ha ha ha :-) ) and acerbis hand protectors for 25 $ so have to wait for about 2 weeks to get them. Meanwhile I am preparing the frame and the wheels for propper sandblasting. The temperature here is -10 celsious, so I am not going out of the house tu fiddle on the engine untill it gets warmer, at least to zero :-)
Old 02-01-2012, 07:02 AM   #15
jasonc32amg
Hello Gubner
jasonc32amg's Avatar
Oddometer: 135
Good luck on the build. I had a zx6e back in the day and it was a brilliant road bike. Equipped with a pipe, jet kit, and advancer it would run with its contemporary 750's with vastly better comfort an range.
12 1200 Tenere
13 Goldwing
jasonc32amg is offline   Reply With Quote
Times are GMT -7.   It's 02:51 PM.
