Old 02-03-2012, 09:03 AM   #1
rdcyclist OP
rdcyclist's Avatar
Oddometer: 1,093
NHSTA Opens Investigation into BMW Final Drive Failures
A number of us have been wondering when this would happen. Apparently you have to be pretty diligent to get the process started. This is crossposted from an Iron Butt Rally list:
After over 145 individual complaints filed between April 2001 and August 2011, the NHSTA has finally opened its first official investigation into the failure of crown gear bearings on BMW models equipped with the Paralever style final drive. NHSTA investigation DP12001 opened 1/20/12 is centered on 1999-2005 K1200LTs for now. But, if the findings are what we all believe they will be, the scope of the investigation should be expanded. I found the only way to get NHSTA to listen and focus was to pepper its director, David Strickland, with repeat letters as well as inquiries from WA Senator Patty Murray who chairs the subcommittee over funding for the NHSTA. If you have had a final drive failure on your Paralever equipped BMW, and have NOT already reported it to the NHSTA, I urge you do it now.
You will need your VIN, (est.) date of failure and mileage. State your model as well. While they should be able to identify from VIN, their data was wrong 50% of the time. Specify if gear oil leaked.
www.safercar.org
or call (888) 327-4236
or mail to:
NHSTA
Office of Defects Investigation (NVS-210)
West Building
1200 New Jersey Ave SE
Washington DC 20590
In your complaint, select "Power Train" as the component and reference that you have had the same failure as described in ODI No. 10439549, and currently being investigated under Campaign DP12001.
Send an email to your Congressman and US Senator to follow up on your behalf as well.
Chris Cimino
_______________________________________________
rdcyclist is offline   Reply With Quote
Old 02-03-2012, 09:54 AM   #2
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,703
Have not had my FD fail but am glad to hear this so I'm ready when mine fails. (I know, I know, most don't fail)
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Old 02-03-2012, 10:01 AM   #3
GB
Mod Squad
GB's Avatar
Oddometer: 55,993
It's good to light a fire under bmw's butt... but i doubt anything will come of it..
Old 02-03-2012, 01:31 PM   #4
Bill 310
Poser Emeritus
Bill 310's Avatar
Oddometer: 3,132
Well there is nothing like a little investigation in an election year.
I posted the note from Chris on our local Sport bike forum and added these two factoids
This is really good news for BMW owners. I have had rear drive failures on my 2001 GS, 2003 GS Adv and my 2008 K1200GT. My LT was written off before it had a chance to fail.
Fortunately they all were covered under the warranty due to BMW's 3 year / no mileage restriction on CDN bikes. This is BMW making marketing a no cost marketing benefit as a result Canada's 5-6 month riding season.
As Chris outlines in his email below, the initial investigation will be on the K1200LT's, expect more bikes to follow.The classic photo of the GS's rear drive on fire and melting is one of the great pieces of motorcycle photography.
Canadian recalls generally follow the US it seems.
So the issue that "never existed" is finally being investigated.
A couple of notes
2009 IBR
The four BMW final drive failures that occurred in the 2007 Iron Butt Rally are having
an effect on hardware choices this year. Another K1200GT rider, Jeff Earls, will actually be carrying a spare final drive with him. Long time BMW rider Eric Jewell has taken an even more effective step to minimize the risk of having his ride end with a final drive failure; he sold his BMW and purchased a Honda ST1300. Tom and Rosie Sperry, who have been riding BMWs 2-up for many years, have adopted the same strategy. After experiencing a final drive failure on their K1200LT following the last Iron Butt Rally,
they switched to a Honda Gold Wing.
While BMW continues to claim that there is no significant problem with its final drives, a number of long-time BMW riders disagree and are switching brands. BMWs reputation for building the most reliable motorcycles has been damaged within the long distance riding community.
There's a *very* extensive article in the September 2008 Motorcycle Consumer News magazine on the final drive failures.
Limited summary:
- BMW uses two different final drive systems: the older Paralever design, which is still used on the K1200LT, and the 2nd-generation "EVO" Paralever, introduced in 2004 and, used on most current bikes. EVO design is easily identified by the 50mm hole in the rear axle.
- From 1980 to 2000, BMW final drive failures were rare
- Starting in 2001 an increasing number of final drive failures started appearing on K1200LT and R1150GS models
- Most of those were on 1st generation Paralever bikes, although some were on EVO Paralever bikes.
- Of 38 Paralever-equipped BMWs in the 2007 Iron Butt Rally, 14 were R1200 EVO models. Of these four didn't finish due to final drive failure -- a 29% failure rate.
- In Sept 2006 BMW revised the service recommendation for final drives to include final drive oil change at the 600-mi service (previously was considered lifetime lubricated).
- In 2007 BMW increased the size of the pinion gear needle bearing on EVO Paralevers, and added a magnetic drain plug.
- BMW didn't publicize but extended the final drive warranty to five years on bikes sold after January 2007
- Owners can check final drive status by putting bike on center stand, grabbing back wheel at 12 and 6 o'clock positions and rocking back and forth. Repeat at 3 and 9 o'clock positions. On EVO bikes up to 1 mm of play measured at the wheel rim is considered normal. More is abnormal and might indicate an impending problem
- A better inspection inspection method is draining final drive oil and inspecting magnetic plug for metallic particles. If any uncertainty, the final drive must be removed and gears/bearings inspected and gear lash measured
- A survey on the BMW LT forum resulted in 174 reported final drive failures
- A separate survey resulted in 80 people reporting failures, of which 11 were EVO Paralevers
- So far no reported crashes resulting from final drive failures
Canada "It's a rough place, son. In fact, you have to puke twice and show your razor just to get in. Better grow some whiskers if you wanna go to Canada." Ronnie Hawkins when asking Levon Helm to join his band and play in Canada.
Bill 310 is offline   Reply With Quote
Old 06-13-2012, 08:08 AM   #5
Merlin III
Mean SOB
Merlin III's Avatar
Oddometer: 1,602
This is really good news for BMW owners. I have had rear drive failures on my 2001 GS, 2003 GS Adv and my 2008 K1200GT. My LT was written off before it had a chance to fail................
Limited summary:
I am not real knowledgeable about the mechanics of the subject. I have a 2001 1150GS which I have owned for about three years. I know nothing about the previous history of the bike. After one year in my ownership the dealer told me that my bike had metal flakes in my final drive fluid and he replaced the bearing. Yesterday, Max BMW informed me of the same thing and replaced the final drive bearing. The time between near failures was 1 year, 10 months. I mean, how can this be? Besides design flaws, are there any contributory factors in how the bike is ridden?
Last year at the BMWRA rally I met a rider with exactly the same bike as mine. A few years before, I am not exactly sure when, he told me he was in a bad single vehicle motorcycle accident where the cause of the accident was that his rear wheel came off his bike for no apparent reason. Is this the type of incident that would be possibly caused by a catastrophic final drive failure?
"I have approximate answers and possible beliefs and different degrees of certainty about different things, but I am not absolutely sure about anything." Richard Feynman, CalTech Scientist, Challenger Disaster Committee member.
Merlin III is offline   Reply With Quote
Old 06-13-2012, 08:25 AM   #6
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 51,697
Read the whole thread, then you decide.
There are multiple reasons for FD failures, and especially one following the other like yours. The original failure could be from poor initial assembly, overlaoding the bike, riding in very rough conditions, while overloaded, and getting water in the Fd through streem corssings. Or, it could simply be a defective FD from the start.
As for a FD actually falling off, not unless the owner was so out of tune with the bike that he never noticed major self destruction impending. They do not simply grenade with no warning.
Jim
Old 02-03-2012, 04:10 PM   #7
JimVonBaden
"Cool" Aid!
Oddometer: 51,697
This has been tried many times before.
Jim
Old 02-03-2012, 07:46 PM   #8
WeazyBuddha
Oddometer: 4,703
Jim
Are you saying the NHSTA has opened an investigation on FD failures before?
Old 02-08-2012, 08:33 AM   #9
muskieken
Oddometer: 176
they will just raise the price of bikes 5 grand to cover the replacement of the of past and future
Final Drive Failures.
crf230l
st1300
muskieken is offline   Reply With Quote
Old 02-08-2012, 09:44 AM   #10
Dallara
Creaks When Walks...
Dallara's Avatar
Oddometer: 1,900
Cool2 BMW automobiles...
Again, not to be the devil's advocate here...
But can anyone imagine the wailing fervor and furor there would be in the automobile world if BMW cars had rear ends that lasted only 60,000 miles, or often less, and that blew up with the same frequency as the motorcycle ones do?
As for the mention of Honda Gold Wing final drives failing... I don't have any experience, either as a rider or an owner, about the GL-1800's, but I can honestly say, without equivocation, that in my time around Honda motorcycle dealerships - as a mechanic, parts guy, salesman, or shop owner - I never saw a Honda final drive issue of any kind. And on Gold Wings never saw one through the GL-1000, GL-1100, GL-1200 fours, or GL-1500 sixes...
Not saying none ever happened. Just saying after seeing literally hundreds upon hundreds, with all sort of wear, tear, lack of maintenance, etc. I never saw one fail. I also owned a GL-1000 and two GL-1200's (not to mention two standard CX-500's and a CX-500 Turbo), and had no issues with them, either. One of the CX-500's was endurance road raced for three seasons and never had anything done to the rear end other than fluid changes, and that bike was built from a wrecked one, and was breathed on to within an inch of its life!
Dallara
You never see a motorcycle parked outside a psychiatrists office. - Unknown
'Cos it's easier to try than to prove it can't be done, and it's easier to stay than to turn around and run. - Justin Hayward
Dallara is offline   Reply With Quote
Old 02-08-2012, 04:18 PM   #11
EJ_92606
Rider
EJ_92606's Avatar
Oddometer: 1,779
They do...but its much more frequent than FD failures and occurs at much lower mileage...its the high pressure fuel pumps used in the latest generation of turbo BMWs.
EJ_92606 is offline   Reply With Quote
Old 02-08-2012, 05:50 PM   #12
cardoctor1
cardoctor1's Avatar
Oddometer: 532
as an auto repair shop owner i would like to thank all the engineers for designing sub par equipment.
as a motorcycle enthusiast over paying for unreliable motorcyles sucks.
IBA#35592
RIDE EVERY RIDE LIKE ITS YOUR LAST
00 R1150GS
cardoctor1 is offline   Reply With Quote
Old 02-08-2012, 06:07 PM   #13
ZONKR
ZONKR's Avatar
Oddometer: 520
It sounds like I got the only good one ever built. My '05 1200GS has the original FD and clutch at 107,000 miles. Maybe I should go buy a lottery ticket.
2005 R1200GS
2007 Ural Gear Up
2013 BMW F800 "Baby" GT
BMWMOA 116478
ZONKR is offline   Reply With Quote
Old 02-08-2012, 06:22 PM   #14
svennoly
svennoly's Avatar
Oddometer: 513
Or a Chrysler :}
svennoly is offline   Reply With Quote
Old 02-03-2012, 01:05 PM   #15
Hawk Medicine
Coyote's Brother
Oddometer: 3,302
Bmw rear drive investigation
I don't know how many of you have heard about this buy I found this imbeded in my BMW mail list this morning. Don't bother asking me for more info, I'm an Airhead rider! Just thought that this might help someone down the line:
-------- Original Message --------
Subject: [IBDone] NHSTA Opens Investgation into BMW Final Drive Failures
Date: Fri, 3 Feb 2012 07:46:00 -0800
To: 'IBDone list'
(IF SOMEONE COULD PLEASE CROSSPOST THIS LD RIDERS AND OTHER SITES, I WOULD
REALLY APPRECIATE IT)
www.safercar.org
or mail to:
NHSTA
West Building
Washington DC 20590
as well.
Chris Cimino
IBDone mailing list
IBDone@ibdone.org
http://ibdone.org/mailman/listinfo/ibdone_ibdone.org
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Times are GMT -7.   It's 11:25 PM.
