03-27-2012, 06:04 PM
#1 |
Oddometer: 91
car tire size for Vstrom ???
I am considering going to the darkside and was hoping to get some info on what size works best.. thanks in advance
03-27-2012, 07:58 PM
#2 |
Oddometer: 1,842
Maybe its just me but I'm not getting your question
Ride 365 LLC Braaaap! |
03-27-2012, 08:00 PM
#3 |
Lost and Cornfuzed
Oddometer: 610
Stromtrooper
Check out the "darkside" threads on stromtrooper.com. All will be revealed there. Good luck.
03-28-2012, 02:44 AM
#4 |
Oddometer: 1,523
There are not really many sizes to choose from. I'm running a 205/55 if I remember right. I think I remember seeing something like A 195/45 but I think that might be a smidge too small in Dia. but hey,,,,, you never know till ya try.
Pics- http://s563.photobucket.com/albums/s...eon/?start=all Places visited on two- http://s563.photobucket.com/albums/s...0two%20wheels/ Endeavor to Persevere Blue Skies Coming
03-28-2012, 08:43 AM
#5 |
Oddometer: 91
Thanks guys
FYI...according to the fellars over on the trooper site. 205 50 17 is optimum
03-29-2012, 04:32 AM
#6 | |
Oddometer: 1,030
![]() I sure have been tempted though!
![]() Whoever undertakes to set himself up as a judge of Truth and Knowledge is shipwrecked by the laughter of the gods. Politics is a pendulum whose swings between anarchy and tyranny are fueled by perpetually rejuvenated illusions. Albert Einstein
03-30-2012, 12:01 AM
#7 | |
Oddometer: 1,523
That 185/70 might well be better but ummmm,,,,,,, I don't think you will actually find that size in a 17.
03-28-2012, 12:25 PM
#8 |
Oddometer: 695
Why??
I have to ask....why would you do it? A car tire is meant to have the tread in full contact with the road surface. A motorcycle tire is contoured (rounded) for a reason. It can grip when the bike is leaning into a turn. Car tires and not designed to be run on the sidewall and will attempt to cancel the lean angle. This should be obvious if you ever ran your rear tire down to where it has no center tread left.
If you have a trike or sidecar then the car tire might work, otherwise the lack of safety using the car tire would be too risky for me. Good luck, Terry
Not2fast TJ |
03-28-2012, 03:38 PM
#9 | |
REALLY Gnarly Adventurer
Oddometer: 1,225
the car tire works perfectly fine on a motorcycle, I noticed a slight difference in handling when I first put a car tire on but after about 2 corners you don't even notice it, it's cheaper to start with, will outlast a motorcycle tire by a factor of 3 to 4 or better, gives excellent grip in the rain and is generally a better engineered contact point between the bike and the road than a motorcycle tire! ![]() but then YMMV |
03-28-2012, 07:10 PM
#10 | |
Gadget Guy Supérieur
Oddometer: 542
Studly adventurers. Those are the guys with the carbide accessorized tyres, right? |
03-29-2012, 02:56 AM
#11 | |
Oddometer: 1,523
![]() ![]() Seriously though,,,,, I did it for a specific reason, that being I was gonna go on a long ass trip {15-20K miles} and there isn't a single bike tire out there that will reliably do that sorta mieage. I normally bring a spare as I have had to replace a tire and been caught out one too many times due to tire availability or getting screwed price wise. This time, the trip was to be two up and I didn't have room for a spare. I put it on thinking I would absolutely hate it but would basically just live with it for the trip so I wouldn't have to buy a tire along the way. Much to my surprise, it isn't too bad once you find the right pressure to run which fore me is around 20psi. It actually has alot of traction,,,, yes, even when heeled over as the tire distorts and it probably has more rubber on the road than a 150 sized "proper" motorcycle tire. Would I mount a car tire on the rear of a Gixxer and go play Ricky Racer up in the mountains? Nope and I will also admit I don't like it much in rough, rocky and rutted dirt roads either. But for long trips or mundane commuting,,,,, I will state right now, it's a damned good compromise. You wouldn't throw a Pilot Power on the back of your adv tourer and expect it to last a 10K mile trip nor would run mount a TKC to the front of your Gixxer and do a trackday. All tires are a compromise and this may well be the best compromise for commuting and touring. I can move along pretty well on my turd of a DL650 with the car tire on back and I can push hard enough that I worry about pushing the front 705 so tell me why I need a bike tire for the rear unless I'm hitting the dirt and I'll tell you right now, I have no visions of pacing Valentino and the Wee Turd is no Gixxer. ![]() And to answer another poster,,,,, the gas stop banter can get quite lively due to opinionated, know nothing, scared to experiment, know it all peanut galley experts. ![]()
03-29-2012, 05:10 AM
#12 |
Unreasonable
Oddometer: 2,257
Signature line material right there. Curious to see how you make out...
TransLab a Go Go 2011 Nova Scotia Fresh Air Inspectors Investigate the Cabot Trail "Second star to the left and straight on till morning” ― James T. Kirk |
03-29-2012, 05:32 AM
#13 |
Be aware
Oddometer: 2,472
Oh the Darkside. We are all gonna die in flames.
![]() When considering a heavy touring bike i did some research on the subject and if one was bought i'd give it a go. But on a bike 300# lighter i am kind of surprised that it is considered/used. The owner of Traxxion test road a new Goldwing and it uses a flat profile Bridgestone 180/60x16. He did not like it and said the bike was to his liking with the older type profile. Someday i'll have to read over at stromtroopers i guess. For a long trip on a sharp gravel road like the Dalton... |
03-31-2012, 01:33 AM
#14 | |
This sentance intent
Oddometer: 14,755
but...but...they have cookies!
DSI #694 Quote:
03-28-2012, 05:40 PM
#15 |
Whatever...
Oddometer: 2,462
Riding behind a friend who runs DARKSIDE a couple days ago for 200+ miles, I can tell you this: the tire does not run up onto the sidewall at all. The tread on the inside of the corner stays flat to the road surface, and the tread on the outside of the corner rides up. Looked like he probably maintained a larger contact patch with the road than most MC tires do.
