Old 04-09-2012, 07:00 AM   #1
Cortez OP
BAZINGA!
Cortez's Avatar
Oddometer: 6,966
JCosta vs Dr Pulley sliders - specific questions!
Greets everyone!
This may ended up as a rant, but I'm hoping someone will still read it..
I'd love to hear owners of JCosta CVTs and their opinions/experience with
it, and what exactly it does to the riding experience.
I'm no noob at this, but NO ONE will reflect on ANYTHING in their review
other then writing that when they give it WOT, the revs will rise a lot
higher then with their stock CVT. I've seen that some report lower revs
at top speed, so, it seems the jcosta does exactly what Dr Pulley sliders
do
(IF you pick the exact sliders that would rev the bike out like the
jcosta will).
What about cruising revs? Normal use? City riding?
I don't want the scooter screaming at 7000rpms (out of let's say 8500
available) while riding at 40mph in the city with my GF in the back, I want
the engine to be as relaxed and revs as low as possible.
With the Pulley sliders in my scoot (Downtown 300i), I've managed to get about
2 seconds better acceleration to 60mph while only slightly affecting the
cruising revs up to 50mph (I usully see 5000 now instead of 4500 at same
speeds up to 50-55mph).
The revs at speeds above 65mph start dropping slowly, and at 75mph now
I've got 6500 showing, and before I had exactly 500 more = 7000.
That made a huge difference in fuel consumption at cruising speeds.
WOT from dead stop revs the bike to 6600-6700 now, and it was at around
5900-6100 before
which made a huge difference in acceleration at any
speeds, and got rid of the flat spot around 65mph. I'm not sure if it's due
to the engine not being fully broken in yet, but the scoot won't go over
87mph at around 7600 rpm, which is a shame since the engine's power
tops out at 8000 and I know there's some juice left. The stock test bike
I tried topped out at 96mph @8700 rpms (not that I'd ride at those speeds
or revs, but it was possible), but that thing had worn out weights.
I went from 15.5 stock weights to 14gr sliders, for the record.
It'll probably get a bit better (only 1000 miles on the scoot) with time, but
I was wondering what jcosta would do to the revs - and not
only at full throttle?
I see that I can expect that it would rev out to 8000 at WOT, which would
be great, BUT, NOT at the cost of high revs all the time. I don't want the
needle pinned in the last quarter of the rev range at all speeds. I can do
that with 13gr sliders, don't need a different CVT at all.
I guess what I want is the eCVT from the Burgman 650 with power mode
on demand, and a nice overdrive for my 70mph cruising.
Anyone who put on the jcosta on his scoot, chime in!
I'm hoping someone made an effort to notice the revs at normal usage,
cruising revs etc.
I'd just like to have the same revs showing as they do now, when riding
normally, and when I punch it, I want to me able to use all (or most) of
the available power, since at 6500revs that I get now, I'm using only 24
of the available 30+hp.
I guess it's the same with all scoots, and the Dr Pulley sliders made a
huge improvement, but I don't think I could live with a lighter set of those.
Mission impossible?
Don't even want to start about aftermarket clutches..
Thanks to anyone who read the whole thing, you get a free picture! YAY
'08 Yamaha FZ6n S2 ABS
SOLD: '03 Peugeot Speedfight2, '07 Kawasaki ER6F ABS, '06 Kymco Agility 125, '12 Kymco Downtown 300i ABS
My Flickr gallery --- My 500px gallery
Cortez is offline   Reply With Quote
Old 04-09-2012, 08:00 AM   #2
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,070
Good questions Cortez. And no, that's not a rant!
I know you said you don't want to hear about aftermarket clutches.......BUT.......I have used the HiT clutch and set it up so it has high revs on launch, but lower revs than stock when cruising, and in conjunction with the Dr Pulleys, adds yet more accel. If you use them with the sliders of a similar or even higher weights, you have better accel AND higher speed at lower revs, but that was with a 50cc 2smoke, not a big motor..
I haven't used the J.Costa, but I know the Tmax guys swear by them. Whether it's better than Dr Pulley and the HiT clutch combination will probably be hard to find out, because it's probably unlikely that anyone has bought, fitted, set up and then tested both systems to compare them. Perhaps do a search on the Tmax thread?
This Signature line is intentionally left blank.
MODNROD is offline   Reply With Quote
Old 04-09-2012, 08:13 AM   #3
Cortez OP
BAZINGA!
Cortez's Avatar
Oddometer: 6,966
Sorry, I'll make an extra effort next time.
Yeah, I've read a bit of the tmax stuff long time ago and am subscribed to
the thread, but will have to re-read some older posts. I should ask LARC0,
if he's still alive and kicking, but considering how he's riding, he won't know
the cruising revs stuff, and I figure you didn't have a rev counter on your
50cc either, right?
If I got this right, with the HiT clutch, you're able to keep lower revs at
cruising speeds? That sounds interesting. I'd like.. let's see.. at least 500
more at WOT in any given situation and same or lower revs at minimal
throttle.
If a clutch can do that, I'm sold.
ANd yeah, I've read great things about the HiT clutch already.
Old 04-09-2012, 12:41 PM   #4
Qaz
Oddometer: 177
Cortez, Let me be the first to congatulate you on you excellent purchase 30+ HP out of a 300cc scooter is really strong, you may have the only one in existance.
I do not have either the Dr. Pulley or Hit clutch in either of my scooters, but I have played around with the variator weights. With scooters, you give up something and some times alot, with changes to the transmission. On your 300, you went down 1.5 grams x number of roller slots lets say 6, which equals a total weight loss of 9 grams. Although the DP sliders act differently than rollers, they are still bound by the laws of physics. Your around town RPM's increased because the lighter weights do not react to the centripital force as quickly as the 15.5 rollers did, also because the spring on the pulley behind the clutch is balanced for the 15.5 rollers. The DPS's push the variator faces closer together because of the angle of their face which causes the reduction of RPM's on the highway. Whith a motorcycle and their manual transmission, you can usually have your cake and eat it too. That is not the case with a scooter, a CVT is always trade offs, you can go for more bottom end acceleration, but you give up top end and that is what you did. With CVT you are essentially picking an operating RPM and then have to live within it. The Hit clutch is leting you pick a RPM where the clutch engages, it may have softer compound on the shoes, or stronger springs or both, but it only stops clutch slipage and does nothing to change operating RPM's.
Hey, got to go! I will finish this Tuesday.
Qaz is offline   Reply With Quote
Old 04-09-2012, 12:49 PM   #5
Cortez OP
BAZINGA!
Cortez's Avatar
Oddometer: 6,966
Um, what?
The rest I was mostly aware of.
Old 04-10-2012, 12:01 AM   #6
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,070
With respect, I beg to differ.
The HiT clutch isn't like a normal clutch, eg. Malossi, etc. It has TWO sets of springs, one set varies the revs where the clutch shoes start to press against the drum, the same as a Malossi, but there is a second set of springs that then allows extra weights to operate a cam that presses the shoes harder into the drum than normal, and these weights are primarily driven by road speed. You also have the ability to change cam ramp rates and secondary weights to really fine tune the set up.
You can have heavy springs on the launch weights, like a normal clutch pack, to raise the revs on launch, say take launch revs from 5000 to 7000, but then have lighter weights on the second spring set that lock up the clutch at 50kph/60kph/70kph, to reduce revs on highway cruise. while cruising, if you snap the throttle, the variator weights and the clutch springs both work as a normal set up.
But again, whethyer the system as a package works BETTER than the J.Costa, I don't know, sorry man,
Old 04-10-2012, 08:43 AM   #7
Cortez OP
BAZINGA!
Cortez's Avatar
Oddometer: 6,966
This also sounds interesting since I could live with a bit less revs going
around town, the clutch is slipping a lot there, and 5000 rpms sounds like
too much for 20-40mph speeds and 1mm of throttle opening. If I could
drop the revs a bit at low cruising speeds, that would be great, but that's
not enough to justify a rather steep asking price of the clutch.
Thanks for the info.
Old 04-09-2012, 07:28 PM   #8
TheReaper!
TheReaper!'s Avatar
Oddometer: 651
Hands down it's the jcosta , I have them in my Big Ruckus and my Tmax .
Without the jcosta the Big Ruckus runs for shit , with it it's a totally different
scooter . The jcosta is by far the biggest bang for the buck mod in scooter land .
TheReaper!
TheReaper! is offline   Reply With Quote
Old 04-10-2012, 08:40 AM   #9
Cortez OP
BAZINGA!
Cortez's Avatar
Oddometer: 6,966
TheReaper!
Yeah, so I've heard.. but my questions still remain, regarding the cruising revs
and normal usage.
The most quoted benefits of jcosta are the same as Dr Pully slider mod, so
I'm trying to figure out if it's an investment that I need.
I'm aware that I'll get even better performance then now, but that's easy
to do and cheaper with the sliders, but I don't want to have the engine
screaming 24/7 even when I ride normally, and that's most of the time.
Old 04-10-2012, 09:24 AM   #10
TheReaper!
TheReaper!'s Avatar
Oddometer: 651
and normal usage.
I did the slider thing and IMO it was a waste of time and money . The difference between
the sliders and the jcosta are like day and night . Between the re-jetting , the proper amount of
oil in the crank case and the jcosta , it made the Big Ruckus a good performing scooter . Without
those mods it really wasn't drivable to me . While the Big Ruckus might be the most solid built
scooter ever built , it ran for shit . With those mods mentioned above , again IMO made it one of
the best scooters ever FOR ME .
While I would love it if the Big Ruckus were a little bigger overall
and had more horse power , it is what is which is the best around town 250cc scooter ever
built . Was it perfect off the show room floor ? HELL NO ! It came stock with several built in gremlins ,
but again it is what it is . So not only is it an expensive scooter in comparison to a lot of other scooters ,
it came with about $700 worth of gremlins that needed to be exorcised .
Bottom line to me it was well worth the trouble , maybe for some very budget minding types it won't be .
It's up to the individual . As long as I am able to ride 2 wheels , I will own a Big Ruckus .
TheReaper!
Old 04-10-2012, 10:17 AM   #11
Pimpwerx
Oddometer: 22
TheReaper!
I know Big Ruckus owners use the JCosta, but do they make one for the 150cc GY6? I have only read about sliders and rollers.
The price doesn't seem that high, so I'd love to hear more about your experience with it. Is it quieter throughout the rev range? Any drawbacks compared to rollers and sliders? Also, is it as easy to tweak the weights as with traditional variators? PEACE.
Pimpwerx is offline   Reply With Quote
Old 04-10-2012, 10:33 AM   #12
TheReaper!
TheReaper!'s Avatar
Oddometer: 651
Check with SIP for availability http://www.sip-scootershop.com/en/main/base/Home.aspx .
I didn't notice any "noise" difference with the Big Ruckus , but I did with the Tmax .
As far as bang for the buck , the jcosta ranks 5 stars in my book .
TheReaper!
Old 04-10-2012, 11:55 AM   #13
Cortez OP
BAZINGA!
Cortez's Avatar
Oddometer: 6,966
TheReaper!
Well that's great again, but doesn't answer any of my specific questions
from my original post and the posts in which I repeated some of the
questions.
But I'll try again.
I have no doubt that the jcosta perfomance upgrade is huge, BUT, does
it rev the engine out all the time, even when cruising normally or does it
keep the revs low unless you gun it? That's my main concern.
It's gonna be hard to answer for folks running smaller scoots without the
tach, but..
And one other thing, I wouldn't dismiss the dr pulley sliders since, again,
you probably didn't use the EXACT weight that would have put the revs
at the same revs the jcosta does, which would result in SAME acceleration,
but the revs would perhaps stay too high even at normal speeds, and I
don't want that.
Most youtube videos with jcosta runs show the needle hit the maximum
power revs at WOT, which is great, and I can make my scoot do that
even with the stock vario and probably 12-13gr sliders, BUT..
..don't want to write the same thing for the 4th or 5th time..
I guess people don't understand what I'm asking, or choose to ignore the
question, or just don't know.
Old 04-10-2012, 08:28 AM   #14
Qaz
Oddometer: 177
Modnrod- The hit clutch uses a set of springs to control at what RPM the shoes engage and a pillow spring to control stall rpm's. A slide is used to exert mechanical leverage on the shoe for extra bite. All mechanical actions are determined by RPM's not road speed. The stall speed is usually set at 3,000 rpm's, so it makes no difference whether the scooter is traveling at 5mph or 20mph if the engine is turning 3,000 rpm's or faster, the clutch is engaged, lower than 3,000 rpm's you are free wheeling!
Please explain what part of this I am wrong about, I am always open to learning something new. Also explain how clutch engagement can varie your rpm's at cruising speeds.
Old 04-10-2012, 03:07 PM   #15
MODNROD
Perpetual ponderer
MODNROD's Avatar
Oddometer: 2,070
Modnrod- Please explain what part of this I am wrong about, I am always open to learning something new. Also explain how clutch engagement can varie your rpm's at cruising speeds.
No, you're probably right man, and I didn't explain myself properly as well, which never helps.
I got the higher launch revs from the actuation springs, then I got the lower cruise revs from a combination of cam ramp rates, pillow springs AND the addition of the Dr Pulley sliders.
The J.Costa I know on the Tmax works to reduce cruise revs, probably as you have said due to the ramp rates on the variator. As the Tmax doesn't have an easy way to adjust launch/cruise revs (I don't consider modifying clutch pressure plate weights to vary lock-up an easy mod), you would have to say the J.Costa has the best of both worlds it would seem out of bolt-on bits (but I don't know coz I haven't ridden one yet, just off reports).
Sorry Cortez, I would love to fly over there and donate my time and spanners to the cause! Perhaps we could find an understanding benefactor who could help us conduct physics experiments (purely for scientific research purposes)on your bike.
Times are GMT -7.   It's 11:35 AM.
