Old 04-26-2012, 03:07 PM   #1
JimRidesThis OP
Local celebrity
JimRidesThis's Avatar
Oddometer: 273
Talking Yet another XL600 project...
About a month ago someone made me an offer...
“You look like an idiot. Would you like to swap your nice 1980 XT250 for a dead 1985 Honda XL600R ‘project’ bike with unknown history?”
I know, I know, that doesn't sound like much of a deal, but being a closet fan of big singles I committed the cardinal sin of trading my road-legal runner for a non-runner with the irresistible added attraction of ‘some bits missing’.
Somewhere in there and a small box of bits is an XL600R. Honest!
And so that honeymoon period of garage time with a new bike project began. That time when you really get to know what you've bought into. Usually this consists of finding all sorts issues that you didn't spot when you actually inspected the thing. "How come I didn't spot the oil dripping out of drain plug because the thread's stripped ?", "Is that a 6" nail stuck in the front tyre?" that sort of thing. Well, so far it seems that karma has something slightly different in mind for me and the XL.
As I said, this XL is a totally unknown quantity. As I haven't heard it running, the first task is to get it fired-up before spending any money on it. Unusually, for this to happen, the engine has got to come out of the frame first! This is because karma obviously wasn't on the side of 'a previous owner', who at some point decided to cut a 6 inch section out of the frame tube, presumably to get around the problem of a seized top engine mount. There were tell-tale traces of engine oil everywhere; possibly because karma hadn't finished with our man yet, and didn't tip him off that the tube he was cutting held oil!
Ooops
The top engine mounts didn't come with the bike, so before welding a new piece of tube in I needed to know how and where these fit. A transatlantic message or two later and Advrider inmate, Brucifer, very kindly measured his XL frame giving me the measurements I required (he also had the idea of making a thread out of this rebuild - so if you're already bored, take it up with him!)
Happily, the rest of the bike doesn't seem so bad. The tyres are hardly worn. The wiring loom is in very good shape with just a couple of flag connectors to replace. Most of the fasteners are original and not chewed up, though two helicoils are needed on 6 mm stud holes in the cam cover. The first of the missing, but essential, parts - the bracket that holds the coil and CDI unit under the tank and the top engine mounts - have arrived from breakers in Germany and France via Ebay. I've selected some likely looking steel tube to repair the frame and my MIG welder is warmed up and ready.
So, everything is set, you're welcome to come along for the ride, but it might take a while...
JimRidesThis screwed with this post 05-01-2012 at 12:43 PM
JimRidesThis is offline   Reply With Quote
Old 04-26-2012, 03:27 PM   #2
kubiak
Oddometer: 4,829
im in!
Old 04-26-2012, 08:04 PM   #3
brucifer
brucifer's Avatar
Oddometer: 2,427
Hey, HEY! Now were talkin'!
2014.5 Kawasaki KLR650 NE-2008 Yamaha TTR110-2006 Buell XB12SS-1993 Kawasaki KX500-1984 Honda XL600R/XR650L Hybrid-1984 Yamaha TT600L-1980 Honda CB750F-1977 Yamaha TT500
brucifer is offline   Reply With Quote
Old 04-26-2012, 08:59 PM   #4
Tech23
Tech23's Avatar
Oddometer: 476
Awesome...a home made total loss lubrication system. IMO it would have worked better is the PO would have shoved (yes that's a mechanical term used in many shop manuals) a section of rubber hose over each end of the cut frame tube...removed one intake and one exhaust tappet cap and routed the hoses into the tappet cap holes letting the oil dump into the engine rather than lubricating the top of the rocker box. I give him an A for effort though, oil that recirculates ends up with contaminants from the combustion process,not to mention metal particles from the usual wear and tear of metal to metal part contact....brilliant I say. Oil tanks, sealed crankcases, and motor mounts are all over rated anyway.
Tech23
2004 Suzuki DR 650SM
2000 Harley Davidson FXDWG
2011 Victory Cross Country
Tech23 is offline   Reply With Quote
Old 05-01-2012, 12:34 PM   #5
JimRidesThis OP
Local celebrity
Oddometer: 273
Question Procrastination is the thief of time...
I'm considering my next move regarding the frame repair.
One thing I do know is that my current welding skills are not going to produce a good oil-tight job. Do I practice my welding until I'm 'good enough' or farm the job out to someone competent? Of course, I'm going to go down the practice-my-welding route. Anyway, the guy I got the bike from says he has a spare XR frame (of a similar year he says) that I can have. It'll probably turn out to be for something completely different and, for some reason, I'd like to keep the standard frame if possible. But I could use the XR frame to 'test' the engine while I improve my welding skills. The XR frame should arrive next weekend
In the meantime, to get in some garage time, I took the engine out of the frame and got it onto the work bench.
I was hoping that a brief look under the covers would suggest an engine strip wasn't necessary and, generally, it didn't look too bad inside. A brief peering, prodding and measuring session around the clutch, crank, cam-chain, cam bearings, etc and everything seemed OK. The oil residue was fairly clean (like new oil) and there were no metal fragments, flakes, grit or collections of grunge in the places where you might possibly expect to find such things.
I wanted a first look at the radial valve layout too so I lifted the rocker cover too. The cam and rockers all seem in reasonable shape (these are uncleaned parts, straight off the bike) with fairly minimal scoring or wear evident.
Silicone-gasket overkill on the clutch and generator cases. However, I've not recovered any bits of silicone from the oil filter or strainers.
Finding this is a bit worrying. The broken bit is the automatic decompresser cam thing that's operated by the kick-start, that's the kick-start needle bearing below it in the picture. So far I haven't found any chunks of it inside the engine so perhaps it's an 'old injury' that was never fixed? As a precaution I'll strip the oil pump to make sure it's clear of any debris and flush the engine out as best I can. I suppose I should strip the engine, split the cases and make sure there's no metal debris in there, but I'm tempted just to put it back together and take the chance. False economy?
In the meantime, back to the frame...
JimRidesThis screwed with this post 05-01-2012 at 02:47 PM
Old 05-01-2012, 09:26 PM   #6
Ghost_Mutant
looking for bionics
Ghost_Mutant's Avatar
Oddometer: 713
Yeah, I'm not so sure about that 250 to 600 swap based upon your description either
At least I now don't feel so bad about missing some items during my pre-purchase inspection of my 84 XR500
That frame should prove interesting to fix. If the other frame you get is from an 83-84 XR500, then I think there might be a better chance of the top engine mounts matching the XL6. But you will tell us all about it I'm sure
Another thought, did the frame get cut because someone wanted to remove the valve cover without removing the entire engine? That job can be done on newer XRs, but the XL6 and my XR5s don't have enough clearance between the cover and the frame member to remove the valve cover with the other engine mount bolts still attached. Although I agree that the seized mount is the more likely explanation. I may have a pair of upper engine mounts from an XL6 in my spares box. Let me know if that is something you would want, but I suppose you will make your own set to match your repairs.
You should double check that right side cam bearing. The shield/seal on one side of the bearing should be facing the right side next to the oil cup/chamber. That bearing looks to be installed backwards, or worse its the wrong bearing.
I updated my 84 oiling system to more modern components. Its a straight swap and I you can read about our discussions regarding the dry sump RFVC oiling system on this thread:
http://www.advrider.com/forums/showthread.php?t=552341
Ghost_Mutant is offline   Reply With Quote
Old 05-03-2012, 12:07 PM   #7
JimRidesThis OP
Local celebrity
Oddometer: 273
Question
Thanks for the heads-up on that bearing, I would have missed that completely. Turns out it's the wrong one i.e. no shield. Typical! Presumably that means that at some point the camshaft might not have been properly charged with oil, etc. I'm going to have to replace that bearing with the correct type so as the cam's coming out I might as well take the head off too and clean up the valve faces and so on.
Any hints on removing the cam chain tensioner?
Interesting and useful stuff, thanks again :-)
Originally Posted by kennythetiger View Post
You'll wanna fix that, they are a real pain to start without it. Make sure that you orient it properly before you re-install the cover, they can snap pretty easily if you tighten them down when oriented the wrong way.
I wonder if that's what happened to it?
JimRidesThis...
1985 XL600R "Tamworth"
1992 TDM850 "Ivy"
1995 R1100GS "Herr Flick"
JimRidesThis screwed with this post 05-03-2012 at 02:48 PM
Old 05-07-2012, 10:08 PM   #8
Ghost_Mutant
looking for bionics
Oddometer: 713
That frame repair looks great. Did you notice a cracked rear engine mount? I have three XR500 frames and interestingly enough all three had a cracked rear engine mount/tab in the same spot. I also had some small cracks were the seat and air filter box cross members meet the frame rails. I think the stress of getting too much air combined with the sharp angles caused the cracks. Newer XR frames look to have curved ends on those cross members which probably handles the stress better.
I recall you just pull the pin on top that keeps the tensioner shaft from moving to the right, and then just grab the tab and pull it out while giving it a twisting motion. Once the shaft is out then tensioner can be removed from the top.
There is a pdf manual recently linked on The XL600 thread if you don't have one.
Old 05-08-2012, 03:53 PM   #9
JimRidesThis OP
Local celebrity
Oddometer: 273
I hadn't noticed a cracked rear engine mount but I'll have a close look and let you know. I have checked the the 'flat' cross members and couldn't see any cracks in them though. I'll have a good check over the frame now it's repaired and stripped-out. The main thing for now is that it's oil tight
Yes that's what the Haynes manual says (got to say it really is a poor effort from Haynes). The pin is not a problem but the tensioner shaft doesn't seem to want want to come out (tried pulling it out with pliers). Are they a really tight fit? Should the tension be off the tensioner? If so, how do you do that? Mr Haynes is no help here
I just found a link on page 229 of that thread but the resource file's obviously been removed. Does anyone have a copy please? Is it emailable?
JimRidesThis...
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 05-08-2012 at 04:05 PM
Old 07-07-2012, 02:01 PM   #10
JimRidesThis OP
Local celebrity
Oddometer: 273
Wink Head, cylinder & piston...
Wake up at the back! Project XL is back on the bench...
I intended to just pop the engine back in the frame to see if it would run, but, when I started to clean out the clutch casing I started to come across some small chunks of debris, presumably from the broken decompressor cam. I don't want these getting into bearings, gears or oilways, so I'll to strip the engine, at least part way, to give me a chance to swill out any further bits and bobs that have found their way in there. With an engine this simple it's only a minor PITA :-)
I made a start this evening by removing the head and cylinder from the engine...
The head doesn't look in too bad a shape...
...and neither does the bore. No appreciable wear and no score marks that I can feel with my fingernail. The broken fins are NOT down to me!
I can't believe how big that piston is! I think Honda might have got a job lot from Leyland trucks or something
All these parts will be cleaned up, properly inspected and relevant tolerances measured. I've come across some small bits of debris or swarf in the timing side case so I'll remove the clutch to get better access for cleaning and strip the oil pump just in case.
More to follow...
JimRidesThis...
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 07-16-2012 at 08:09 AM Reason: spelling
Old 07-16-2012, 06:31 AM   #11
JimRidesThis OP
Local celebrity
Oddometer: 273
Thumb Timing side strip-down
Having revealed bits of the broken decompressor cam in the timing side case, karma decreed a partial engine strip might be a sensible idea. It'll allow me to swill out the cases with paraffin and check the crank and gearbox bearings for any free play or 'grittiness'.
It's what's missing here that I've found in the timing side case
Here's where we start from...
The following photos are really just my reference shots so I don't forget the order of parts, etc. :-)
The kickstart camplate and associated gubbins ready for inspection and cleaning
Holding the clutch centre without the correct tool could have proved tricky; but a strip of leather protecting the clutch centre, a pair of mole grips providing a positive stop against the outer drum and and extension bar on the socket did the trick
The crank nut with assorted pinions and the cam chain. I guess I it would be foolish not to replace the cam chain seeing as it's stripped down this far.
Almost a bare timing side case.
So, all in all it's not looking too bad so far. The clutch basket has some indentations from the clutch plates, but nothing that won't be cured with a few file strokes. The gearbox shafts turn very smoothly as does the crankshaft; there's no detectable wear in the bearings but these will be replaced anyway seeing as it's this far apart.
JimRidesThis...
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 07-18-2012 at 11:13 AM Reason: accuracy/change of plans
Old 07-18-2012, 12:13 PM   #12
Ghost_Mutant
looking for bionics
Oddometer: 713
oil pump
The newer oil pumps have shaft seals internally. Those help prevent frame tank drain back when the engine is off.
But I think the bigger deal is the newer pump drive gear set. They run the pump a little bit faster for a given RPM.
You can run the new pump drive gears on the old pumps if you don't think you have a drain back problem.
I found the newer pump parts on ebay for my engine rebuilds.
Old 07-18-2012, 02:25 PM   #13
JimRidesThis OP
Local celebrity
Oddometer: 273
Thanks GM. That's a great synopsis of the thread I had in mind. I don't know if it was wet-sumping or not, but I'll check out the availability and cost of the alternative pump parts anyway. I guess it's not that difficult to change it later, if the current pump has issues.
JimRidesThis...
1992 TDM850 "Ivy"
Old 07-19-2012, 01:46 PM   #14
JimRidesThis OP
Local celebrity
Oddometer: 273
Question Flywheel removal
Needless to say I haven't got the "special tool" so...
do any of you gents know an alternative for removal of the flywheel? e.g. use rear wheel spindle as slide hammer, that sort of thing. I do own a set of 2/3 legged pullers (currently in hiding) but I don't think they're going to be the right tool for the job anyway.
Removed the kickstart shaft and took the piston off the conrod this evening and also cleaned up the clutch side casing threads, just in case any helicoils were needed - none were. Circlip added to the shopping list!
JimRidesThis...
1992 TDM850 "Ivy"
JimRidesThis screwed with this post 07-19-2012 at 05:04 PM
Old 07-20-2012, 08:13 AM   #15
Ghost_Mutant
looking for bionics
Oddometer: 713
By special tool you mean the "bolt"?
http://www.motionpro.com/motorcycle/partno/08-0074/
M22X1.5 Right Hand threads.
To answer your question, no, I used the above motionpro bolt to remove my flywheels.
Times are GMT -7.   It's 05:27 AM.
