Old 04-30-2012, 07:23 PM   #1
2fast4u OP
Oddometer: 746
My dual sport Ninja yep another one
I have this bike about 80% done so this build thread will not take to long to finish.
The reason for this build is, i need a bike i can ride on the interstate, dirt, gravel roads, and light single track and not break the bank. Not much out there fits. A friend pointed out JD rocks thread and i loved it .So my build is based around his.
I do have to point out that this will not be a long trip bike more of a weekend bike.
Okay here we go. The first pic is the bike with the stock fork tubes half way out of the triple tree and a r1 rear shock to see about where the ride height will be.
2fast4u is offline   Reply With Quote
Old 04-30-2012, 07:29 PM   #2
2fast4u OP
Oddometer: 746
The seat on this bike sucks,so it had to go.
Old 04-30-2012, 07:39 PM   #3
2fast4u OP
Oddometer: 746
I had a sportster seat and it is comfortable so ....
Had to cut it down.
Old 04-30-2012, 07:43 PM   #4
2fast4u OP
Oddometer: 746
Better!
Old 04-30-2012, 07:49 PM   #5
2fast4u OP
Oddometer: 746
Time to make the sub frame.
Old 04-30-2012, 07:59 PM   #6
2fast4u OP
Oddometer: 746
[IMG][/IMG]
Old 05-01-2012, 03:28 PM   #7
2fast4u OP
Oddometer: 746
Changed out the triple tree to a Versys and put DRZ400 forks in them with a shim in the lower tree. I will have two sets of wheels one with big blocks and one with street tires. Also changed the R1 shock for a Versys .
Found a ruckus headlight and changed out the bulbs for brighter ones. Mounted the lights and speed O .
Put some dirt bike bars and DRZ hand controls on it.
Old 05-01-2012, 03:38 PM   #8
2fast4u OP
Oddometer: 746
Changed out the Ninja peg mounts for Versys .Made the kickstand longer and the shifter shorter. Put dirt pegs off a KX450 on it.
Had the seat wrapped up again and mounted DRZ fenders.
Old 05-01-2012, 03:54 PM   #9
2fast4u OP
Oddometer: 746
So now i will need a crash bar.
I had a old Harley crash bar so i cut it up. I put some off road lights on the bar and made it where it will come off. It works great for lifting the front wheel off the ground with a jack.
Old 05-01-2012, 04:41 PM   #10
mpowers
mpowers's Avatar
Oddometer: 738
Nice! Liking the rear fender and seat cut....but not feeling the HD crash bars though.
mpowers is offline   Reply With Quote
Old 05-01-2012, 04:42 PM   #11
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,323
That just makes me smile. The seat and headlights really make the look.
As a pair of fresh eyes on your bike, I have two small suggestions. Please don't take them as negative comments, just ideas:
1. The crash bar looks wider than it needs to be, and may catch on tree branches and stuff in the forest.
2. It would look really cool if you could add some strips to cover the gap between frame and fuel tank. Maybe they could be made from textured material for your knees to grip?
High Country Herb is offline   Reply With Quote
Old 05-01-2012, 05:45 PM   #12
jdrocks
Gravel Runner
Oddometer: 4,277
lookin' good...but man, those bars gotta go, and it has nothing to do with aesthetics, but all about protection...assuming you're going to use the bike for what it's designed to do.
here's the aftermath of one of my flops, note the missing paint near the tip of the shifter. might be conjecture, but with your bars that rock may very well have taken out the generator cover.
also, the bike needs to be able to slide forward on the bars, not grab the surface, no matter what it is. if the bike can't slide, you could see damage that might not happen otherwise. cool that you fabbed your own bars, any changes would be an easy fix.
might want to think about some pannier rack mounting points before the subframe gets painted.
who turned the 49mm DRZ fork to 52mm bottom clamp adapters and what was the cost? did you get a photo before you installed them?
jdrocks is offline   Reply With Quote
Old 05-01-2012, 06:10 PM   #13
2fast4u OP
Oddometer: 746
Thanks JD for your ideas but for the most part it will not get out of Tennessee. I'm lucky if i can get away for a weekend. No need for pannier just a weekend bike. Will see on the crash bar if i don't like it i will change it . No big deal.
My buddy owns a machine shop and it was $40 but he is a good friend.
Old 05-01-2012, 07:05 PM   #14
jdrocks
Gravel Runner
Oddometer: 4,277
i'd add the mounting points anyway. you can fab yourself a nice tail rack, carry a tail bag for your day rides. tools, spares, water bottles, lunch.
Old 05-02-2012, 09:05 AM   #15
2fast4u OP
Oddometer: 746
I hear what your saying. I may fab up a removable set up. My plan is to be able to ride to the smoky mtn. (250 miles) on the interstate get a room drop what little i have off except for tools and ride. I like as little on the bike as possible. The guys i ride with ride at race pace on 450s. I know this bike will not be able to keep up but don't them waiting to long.
Times are GMT -7.   It's 02:15 PM.
