Old 05-10-2012, 09:08 PM   #1
Hytram OP
crash test dummy
Hytram's Avatar
Oddometer: 690
800XC front wheel direction?
I just got a phone call from my mechanic, I dropped the wheels in so he could change over the tyres...
the numpty forgot to look at the direction of the front tyre and there is no marking on the rim or discs
he said that the discs are off centred so they can on fit one way (I was unaware of this)
anybody have any ideas?
the bike it at home hanging from the roof so I would rather sort it out without 2 taking 2 trips
ta
Marty
Marty
'10 Multistrada 1200
Hytram is offline   Reply With Quote
Old 05-10-2012, 09:27 PM   #2
Flying Dave
Oddometer: 143
I just bought mine and have not looked it over that well but is there a mark anywhere on the hub with an arrow?
Flying Dave is offline   Reply With Quote
Old 05-10-2012, 09:51 PM   #3
Hytram OP
crash test dummy
Hytram's Avatar
Oddometer: 690
no, no arrow
no markings anywhere I believe
Marty
Old 05-11-2012, 08:44 AM   #4
jphish
Oddometer: 617
800xc - as you're sitting on bike (facing forward of course) "JKExcel....." stamped into outer rim is on the right & 'DOT' (in raised letters) on hub on left side. Didnt see any arrows.
jphish is offline   Reply With Quote
Old 05-11-2012, 09:31 AM   #5
dwoodward
dwoodward's Avatar
Oddometer: 5,567
Originally Posted by Rob Dirt View Post
If its ABS, then the ABS ring goes on the clutch side.
Originally Posted by Hytram View Post
Non abs
The place where the ABS ring would go is on the left. (kidding- the ABS ring is held on by the brake rotor bolts)
Concur- the wheel info is stamped into the right side of the wheel.
dwoodward is offline   Reply With Quote
Old 05-13-2012, 04:00 AM   #6
Hytram OP
crash test dummy
Hytram's Avatar
Oddometer: 690
Thanks guys....
I got the mechanic to put it on hoping he would guess right and he didn't
No stress, he is going to swap it over for nicks
Marty
Hytram screwed with this post 05-13-2012 at 05:54 AM
Old 05-13-2012, 05:51 AM   #7
internalcombust
Yes its dirty, thanks.
internalcombust's Avatar
Oddometer: 1,586
In the future to avoid confusion, you could put a small directional arrow on the disk carrier with a paint pen. That's what I have done, seems to hold up well enough.
2012 Tiger 800XC
04 DRZ400S
79 GL1000 basket case
internalcombust is offline   Reply With Quote
Old 09-07-2012, 04:56 PM   #8
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 8,980
I always shove a piece of cardboard between the spokes with a directional arrow on it, the shop always gives me dirty looks, and the tire is always put on correctly.
High Country Herb is offline   Reply With Quote
Old 09-09-2012, 03:54 PM   #9
Hytram OP
crash test dummy
Hytram's Avatar
Oddometer: 690
hehehe, we ended up lightly punching a small arrow on the disc carrier... which was perfect for me last week when I went changed over the front tyre and forgot to look at the tyre before i removed it..
another trick I have done it draw and arrow on the disc with a permanent marker, this comes off as soon as toy apply the brakes the fiat time
Marty
Hytram screwed with this post 09-09-2012 at 04:03 PM
Old 05-11-2012, 06:43 AM   #10
Hytram OP
crash test dummy
Hytram's Avatar
Oddometer: 690
Non abs
Marty
Old 05-11-2012, 06:49 AM   #11
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,667
This WOULD be the day I chose to ride the ZZR to work rather than the XC, else I'd pop out to the parking lot and figure it out for you.
Times are GMT -7.   It's 03:42 AM.
