06-03-2012, 03:25 PM
#1 |
Oddometer: 209
Generator cover
Rolled into a fuel stop today and thought I heard/felt a crunchy/scraping sound. After gassing up I checked everything over and couldn't find anything amiss. About 4 blocks later while sitting at a stop light I heard it again coming from the motor. I pulled to the side and while the bike was idling could hear crunchy noises coming from the left side. Put my hand on the generator cover and it felt like bad things were happening inside! I immediately knew what was probably going on in there.
So anyway, got the bike at home in the garage now and I'm trying to get the generator cover off to see the damage. I have removed the vent tube and all of the bolts around the perimeter. The only bolt I didn't remove is the one for the idler gear. I'm thinking the cover should come right off now but no go. It will rock back and forth and show as much as a 1mm gap on one side or the other but that's it. I've used the 14mm allen to turn the motor thinking that loose bolts etc may have the stator jammed in the flywheel but it turns smoothly. Everything that I've read here and in the manual suggests that you simply remove the bolts on the cover and pop it off. What am I missing?
"Life is either a daring adventure, or nothing." -- Helen Keller Stranger 315 '04 KTM 950 Adventure S '04 BMW R1150RT |
06-03-2012, 03:49 PM
#2 |
Ride that nasty thing
Oddometer: 1,425
That's it, just remove the bolts . You may have some parts in a jam so to say , if all the bolts are off ,you should be able to remove with ease .
"04" 950 Adventure S 34,000+ miles Smokin Hole Rally 1,2,3,4,5,6...upcoming 7 Cromag 05, 08. "The Grim Brothers" Where's my 690 rally replica |
06-03-2012, 05:08 PM
#3 |
Oddometer: 687
That baffled me too, at first.
What the heck is going on??!?! There's a honkin' BIG magnet inside that cover, and that's why it doesn't pull off easily. Serious, BIG, honkin', STRONG magnet. Which is why you can "slide" it a little bit, and nudge it around, but it won't come off. But it will. Trust me. It will. Be strong! (But, of course, DO be sure every last screw is removed from the perimeter. That's important, too.)
You must be the change you wish to see in this world. |
06-03-2012, 05:26 PM
#4 |
Oddometer: 209
No doubt there's some bad shit going on under there. If the magnet is that strong there should be a puller for it! Seriously, at 250 lbs I'm no lightweight and if that's just a magnet holding it on maybe it's time to check in at the old folks home. Sounds like I'll just have to keep fiddling with it and see if it works loose. I'll keep you posted.
06-03-2012, 07:18 PM
#5 | |
Ride more, BS less!
Oddometer: 8,398
I just had mine off a couple days ago... the magnet isn't that strong. After wiggleing it loose from the dowel pins, you can pull it off with one hand. I'd give the starter button a quick nudge and then try the cover again. At this point you pretty much can't do much more damage than has already been done.
08 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150 Hi/low beam conversions for: Trail Tech, Baja Designs |
06-06-2012, 04:30 PM
#6 |
Oddometer: 209
I was finally able to get back to this last night and with the use of a wood dowel in the vent connection to make it easier to keep some constant pressure on the cover while at the same time turning the engine with the 14mm allen wrench I was able to get the cover off. I found what I fully expected to find:
![]() Stator is not beat up too bad but still a worthless lump of copper ![]() So the good news, I guess, is that there is next to no debris strewn around. Now the question is what parts do I need to replace. Obviously the stator and the bolts. Not entirely sure about the flywheel. All the little dings from the bolts bouncing around won't hurt anything but I'm not so sure about the inlaid strip at the back of the inside of the flywheel. What is it and what is it there for? Balancing? Vibration damping? Can anyone here shed some light on it? ![]() One thing I won't have to buy is a new gasket - I have one hanging on the wall that I ordered with the intention of checking these bolts this spring. Just hadn't gotten a round to it... For the record it's a 2004 S model with 24k miles on the clock. This is the first trouble it's given me so I sure can't complain.
06-06-2012, 04:40 PM
#7 |
Semi-Adventurer
Oddometer: 9,822
I have an '04 flywheel. It is the early one without the keyway, if that is what yours is.
In fact I probably have most of what you need.
I miss round headlights. "When I was a young man, I liked to race my horse...." - G.H.W.S. 1878-1962 |
06-06-2012, 05:00 PM
#8 |
Nothing to see here.
Shit there goes another one.... Was there some weird weather phenomenon this winter that is causing this? I know it's a known issue but seems like a rash of them lately.
This one doesn't look as bad as some. Hope the OP gets off easy. Mine is coming apart as soon as the parts get here so I can check it. |
06-06-2012, 05:25 PM
#9 | |
Don't mean sheeit. .
Oddometer: 2,541
Irv: that flywheel's gotta go, I'm afraid. I think you'd stand a high chance of having one of the magnets below the sheet metal on the inside of the flywheel come loose and shred your nice new stator.
Zak ktm old bmw others |
06-06-2012, 05:37 PM
#10 | |
Oddometer: 209
I am curious as to its purpose though.
06-06-2012, 05:32 PM
#11 |
Oddometer: 209
First I'll have to get the puller bolts and get the flywheel off. If it's without the keyway I'll be in touch. Thanks!
06-06-2012, 07:00 PM
#12 |
Oddometer: 209
Removed the rotor bolt and can see that mine does have the keyway. What other parts do you have?
06-06-2012, 07:24 PM
#13 |
Oddometer: 822
Stator
Look at my thread on this. Trust me, it could be way worse. Cheapcycleparts for the parts,I've done the research. Pm if you need info on the fix.
06-06-2012, 08:02 PM
#14 |
Oddometer: 209
Ok, so now I have another question. Did the '04's not have the torque limiter that I keep reading about installed in them?
Mine is just one solid piece ![]() ![]() From time to time I have heard the snapping sound when starting that I assumed was the torque limiter doing its thing. In fact on the fateful day it did it three times when I first started it and I remember thinking to myself that I better check into the updated version soon. Was the sound I was hearing really the flywheel bolt snapping?
06-06-2012, 08:13 PM
#15 | |
Semi-Adventurer
Oddometer: 9,822
PM sent on the other stuff.
