Old 06-07-2012, 03:36 PM   #1
m800mm OP
Oddometer: 65
tell me about tire balancing
I am going to put a new Mefo SE on my 990 the stock tire
was a scorpion the rim has a wheel weight on it, what do I need to
do?
m800mm is offline   Reply With Quote
Old 06-07-2012, 03:45 PM   #2
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,106
Put air in it and ride it.
traveltoad is offline   Reply With Quote
Old 06-08-2012, 06:06 AM   #3
TwoRats
TwoRats's Avatar
Oddometer: 73
What he said. Even when I roadraced I couldn't be bothered, and only ran into one tire that gave me noticeable troubles. With knobbies and rims that are tweaked on my 950A, I doubt I'll ever notice a slightly imbalanced wheel. I run a Mefo rear and Karoo 2 front.
TwoRats is offline   Reply With Quote
Old 06-08-2012, 08:38 AM   #4
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,106
Exactly.
Even with a rim lock it doesn't vibrate much under 80mph.
Old 06-08-2012, 09:14 AM   #5
buzybraza
buzybraza's Avatar
Oddometer: 274
different
My experience is just the opposite, on my 525, 950 and other bikes I have owned, with knobby, dual sport and street tires, with cheapos or top dollar stuff...... I have always felt a vibration above 30 or 40mph and visually can see the forks getting jerked back and forth. All my stuff gets machine balanced at the shop. When you look at the amount of lead added to the rim to balance everything out it's kinda like holy f%$@!
Not balancing gets really bad if you run rim locks.
If I did not have the shop I would do it myself in the garage. The only situations I would not balance is if it was impossible, like trail side repair, changing tires at the track, etc...
buzybraza screwed with this post 06-08-2012 at 02:26 PM Reason: correcting my awful english
buzybraza is offline   Reply With Quote
Old 06-07-2012, 05:35 PM   #6
avocadofarmer
Oddometer: 161
Make one.
Spin the wheel freely and note what part of the wheel is at the bottom. Put weights opposite of that and give it a whirl again.
Or just ride it.
avocadofarmer is offline   Reply With Quote
Old 06-07-2012, 05:47 PM   #7
wescnmbkr1
Oddometer: 47
New Tire Balance
New tire will have a "colored dot" on the side wall near the bead area, this "dot" is the light area of the tire and should be used to locate the valve stem; in other words line up the "dot" with the valve stem. Air the tire, spin the tire to find the heaviest side of the tire which will be at the bottom, spin it again to be sure it repeats the same location. If the wheel weights always stop at the bottom remove them. Do the spin process to find the heavy side again. Slowly add weight to the top of the wheel location until you are able to stop the wheel in any location without the wheel continuing to want to turn. When you can place the wheel in any location without it wanting to turn, you have a balanced wheel. This is "static balance."
wescnmbkr1
wescnmbkr1 is offline   Reply With Quote
Old 06-07-2012, 07:00 PM   #8
rnoliver
Oddometer: 35
As a way to make a quick balancer, I just stuck a 3/4 inch rod in my bench vice, making sure the end sticking out was level. Put the axle and wheel right on the rod. Worked fine.
rnoliver is offline   Reply With Quote
Old 06-07-2012, 11:36 PM   #9
K2m
....58....
K2m's Avatar
Oddometer: 2,238
I got one of these
http://www.marcparnes.com/Universal_...l_Balancer.htm
http://www.youtube.com/watch?v=EF5QpXmT5o8
Hope this helps
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 06-08-2012, 10:46 AM   #10
BillyD
BillyD's Avatar
Oddometer: 597
Balance Everything DOT, All The Time
I balance every wheel that I expect to ride on pavement or at moderate speeds off-pavement.
This includes the 990, 640 and 525 regardless of tire choice. By definition, this does include non-DOT mud tires (i.e., Michelin M12/S12s) that I put on the 525 from time to time. I typically run 606s, TKCs on all three bikes and, on the 990, Continental Trail Attacks. I have rim locks on both the 525 and 640. I recently tried Kendra Big Blocks on the 990 without rim locks and the rear required a massive number of weights.
Balancing makes a huge difference even at moderate speeds (i.e., 45-65 mph), especially at steady speeds. There are few things more annoying to me that having a wheel bouncing down the road.
When racing, one is typically constantly accelerating or braking, seldom cruising at steady-state. So balancing while racing, even though top speeds can be considerably higher, probably has little benefit. I believe many road racers don't bother balancing.
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Honda XR650R, Ducati 851, Moto Guzzi 850 Lemans & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 06-08-2012, 12:22 PM   #11
TwoRats
TwoRats's Avatar
Oddometer: 73
So, m800mm, a clear concensus. Anything else we can help you with?
Old 06-08-2012, 12:33 PM   #12
Cyclops Motorsports
Cyclops Motorsports's Avatar
Oddometer: 907
Good subject and perfect timing.
I have never bothered with balance on any dirt bike, I see no reason, as it will soon get another dent., I also run my wheels until there damn near square or cracked.
I'm fairly new to the adv bikes. with my old Gs I always balanced, however with the 950 I figured with knobbies I would not balance.. Well last weekend when riding in the rain I was passing a car. at about 85 the front started to jump wildly it was not pleasent..this is a Se wheel with a rim lock..never had an issue with the stock ADV wheel and no balance?? I'm going to pull the front wheel off and do a back room balance, but Ill leave the rear as is..I hope it gets rid of the high speed bounce..
When Quality matters,Its all about choices.
Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
http://youtu.be/1fmEJO3ftFI
Cyclops Motorsports is offline   Reply With Quote
Old 06-08-2012, 03:02 PM   #13
traveltoad
Aaron S
traveltoad's Avatar
Oddometer: 6,106
Yep.... with the rim lock, it starts to bounce a bit around 80mph. That is why I am going to add a second rim lock on the other side (both front and rear wheels) so they balance out. Problem solved!
But if you are going to try to balance a wheel with a rim lock.... buy the really really big wheel weights.
Old 06-08-2012, 04:24 PM   #14
666
Agnostic and Orange
666's Avatar
Oddometer: 1,230
I use motion pro rim locks on my 450 and cant feel anything up to 75-80. With stock rim locks it was very bad above 50 mph.
Never balanced tires on 950 (no rim locks) - no problems up to 110.
2006 KTM 950 ADV
2004 KTM 450EXC
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 06-08-2012, 05:39 PM   #15
Cyclops Motorsports
Oddometer: 907
Thats a good idea.. never crossed my mind,. much better than a pile of lead.
Times are GMT -7.   It's 02:39 AM.
