Old 07-03-2012, 09:38 AM   #1
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
Installing a CPR air filter on my 990
The CPR Rottweiler air filter had been sitting around on my workbench for too long and it seemed like I would never have time to put it on. Then, yesterday, my wife announced she was going to visit her mom over the 4th - free time
A quick call to the tuner insured he could get me in and I started the install last night
Here is the stock configuration
and what it's going to look like
After a few hours I had the stock air box removed and the fuel injectors reinstalled.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 07-03-2012, 11:14 AM   #2
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
SAS removal
I had thought I would just leave the SAS plumbing installed for now but when removing the stock air box I found out the the pump is attached to it So.......
It's gone now. For those of you removing the SAS, remove the rear cylinder plate first. Why? because the front cylinder plate is such a PIA to replace that if you try and do it first you will most likely decide it's not worth the effort I had to keep telling myself, the other plate is already removed - ya got to figure out how to get this one off
Moto-Treks
moto-treks screwed with this post 07-04-2012 at 07:44 AM
Old 07-03-2012, 12:05 PM   #3
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
Setting up the base plate
Next it was time to setup the baseplate. The crankcase breather check valve and Temp Sensor need to be installed onto the Rottweiler baseplate.
Once the baseplate is mounted on the bike I rerouted the crankcase breather cutting about 1.5 inches off before it would match up to the check value. Then I tied to connect the temp sensor wire.
But it's not long enough. I've checked everywhere and there is no way for me to get the extra inch or two needed to connect the connector to the Temp Sensor
Moto-Treks
Old 07-06-2012, 04:18 PM   #4
CPRFAB
Oddometer: 208
A customer alerted us to this thread and we wanted to let everyone know that this MAP sensor issue has been fixed early on. For some reason our test bikes had more than enough wire length to meet up but some bikes do not. Probably a difference in who was making the harnesses. We have since moved the map sensor to the front of the base plate where A: It cannot interfere with the throttle plates if installed improperly and B: The wire loom will easily reach it. All of our dealers have these models now. (We also stopped putting those impossible to remove stickers on the plate, sorry about that!)
Moto-treks, thank you for posting this how to and the kind words. It still thrills us to see when our customers find such great results from our Rottweiler Filter. Be safe and most of all, have a great ride!
CPRFAB screwed with this post 07-06-2012 at 05:10 PM
CPRFAB is offline   Reply With Quote
Old 07-08-2012, 12:33 AM   #5
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
That would sure make it easier to install as you could skip the whole cut the wires and add 5 inches step
Moto-Treks
moto-treks screwed with this post 07-08-2012 at 04:47 PM
Old 07-03-2012, 01:03 PM   #6
EatinDirt
WannaB Thumpin
Oddometer: 19
Your in way to deep now you can't stop and go back cuz I want those other filters....
EatinDirt is offline   Reply With Quote
Old 07-03-2012, 02:05 PM   #7
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
Oh man don't I know it
I lengthened the wire for the Temp sensor about five inches and it fits great. Just hope adding the extra wire doesn't change the way the ECU reads the temperature.
After I had the connector installed I check the clearance with the secondary throttle. It didn't touch but was a little too close for me so I rotated the Temp Sensor 180 degrees in the base plate and now there is plenty of space between the connector and the secondary throttle arm.
This is how I ended up installing the Temp Sensor in the base plate.
Baseplate all ready to go - just need to add the filter
Moto-Treks
moto-treks screwed with this post 07-04-2012 at 04:18 PM
Old 07-03-2012, 07:49 PM   #8
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
PIA SAS Plate
Here is the location of the front cylinders SAS plate. A real PIA to get at.
Moto-Treks
Old 07-03-2012, 08:10 PM   #9
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
And Installed
And here it is all oiled up and installed
And all buttoned up - lots of room in there but I will need to take the top cover off to clean the filter
I didn't know if I needed to install a resistor in place of the SAS pump so for the first test I plugged the SAS pump in, hit the starter button and she fired right up
Next was to plug in TuneECU and switch the SAS off. After that I removed the SAS pump and again, she fired right up with no FI errors
Finally, since I'm guessing I'll be getting more air I loaded the map for a 2011 R Akrapovic slip-on, did the 15 minute idle reset and I was ready for a test ride.
All I can say is the bike ROCKS it has a lot more power over the whole RPM range.
Tomorrow I'm off for a custom tune
Moto-Treks
moto-treks screwed with this post 07-04-2012 at 07:52 AM
Old 07-04-2012, 05:55 AM   #10
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,971
Wonderful Report. Thanks for posting. Very helpful.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 07-04-2012, 08:45 AM   #11
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,177
If I may, the breather tube could get kinked as it is hooked up onto the bottom plate and is too long. Rerouting or shortening is necessary in my experience.
Great pix
Cheers!
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 07-04-2012, 09:11 AM   #12
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
Great pix
Cheers!
Good point - I had to cut mine 4 times before it was the right length
Moto-Treks
Old 07-04-2012, 09:15 AM   #13
bikyto
bikyto's Avatar
Oddometer: 2,177
Old 07-04-2012, 08:46 AM   #14
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,797
More benefits
In addition to the increase in HP you also get to reduce the weight of your moto by removing all of this
and replacing it with this
for a total loss of 5 lbs
Moto-Treks
Old 07-04-2012, 04:11 PM   #15
Helajames
Oddometer: 25
I just got one for my 2010 990R, going to do the Sas removal at the same time, can you tell me where you found the KTM specific info on the tune ecu? Very interested in this too! Great info!
Jim
Helajames is offline   Reply With Quote
Times are GMT -7.   It's 10:06 AM.
