Old 10-05-2012, 11:33 AM   #1
JamesM OP
JamesM's Avatar
Oddometer: 103
Peeling Sidewall?
I just purchased a K1200RS which needed a new rear tire but after taking it home (in the rain ) pulled into the garage and noticed some bits of tire shedding from the right sidewall.
Is this normal when tires get older? Its on the para lever side so I double checked for contact wear and couldn't find any.
Before spending a few hundred $$ to replace my tire, I want to make sure the new one doesn't get chewed up as well.
Pics:
photo 1
photo 4
photo 3
photo 2
JamesM is offline   Reply With Quote
Old 10-05-2012, 11:44 AM   #2
pjensen641
pjensen641's Avatar
Oddometer: 334
Sure looks like it is rubbing on something.
I'd check Tire pressure, recommended tire size vs what is on there, wheel bearings etc. Not normal.
Did the final drive go bad and the original owner have it repaired, but left the old damaged tire on?
pjensen641 is online now   Reply With Quote
Old 10-05-2012, 11:44 AM   #3
Big Lee
Big Lee's Avatar
Oddometer: 210
That does look like it`s been rubbing on something, have you checked for play in the rear wheel?
Big Lee is offline   Reply With Quote
Old 10-05-2012, 11:53 AM   #4
rocker59
diplomatico di moto
rocker59's Avatar
Oddometer: 15,706
Is it wider than OEM fitment?
Rocker59 (aka guzzimike), Aux Arcs (NW Arkansas)
Moto Guzzi Sport 1100
IBA #24873
"Do what you can, with what you have, where you are." - Theodore Roosevelt
rocker59 is offline   Reply With Quote
Old 10-05-2012, 12:02 PM   #5
ChR1s
Spherical Bastard
ChR1s's Avatar
Oddometer: 336
That tire looks like it's been in an accident.
Chris
ChR1s is offline   Reply With Quote
Old 10-05-2012, 12:14 PM   #6
JamesM OP
JamesM's Avatar
Oddometer: 103
How so?
Old 10-05-2012, 12:18 PM   #7
ChR1s
Spherical Bastard
ChR1s's Avatar
Oddometer: 336
Originally Posted by JamesM View Post
How so?
The chafing looks like it's happened at a slow speed, and there appear to be lateral marks on the tread?
Chris
Old 10-05-2012, 12:14 PM   #8
JamesM OP
JamesM's Avatar
Oddometer: 103
Stock Rubber: 170 60 17 at 40 PSI (+-3 PSI for digital reader) BMW recommends 42 PSI but I cant see how +-5 PSI would cause that kind of wear.
Performed 2 test:
-12 and 6 o'clock check for rear bearing play without luck.
-I put my finger between the Brake Rotor and Final Drive housing spun the wheel, while trying to move it horizontally to test for play but didn't feel any pressure change on my finger.
Here are a few more images showing the space between the paralever and tire:
Bottom Looking Up:
photo 4
Top Looking Down:
photo 2
Old 10-05-2012, 12:20 PM   #9
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
That is foreign object damage.
I had road debris hang up on my swingarm and rub the edge of my tire just like that. It left all kinds of scraped marks and rubber shreds. I didn't realize it was there, until the tire sucked it through and it cleared itsself
Don't know what the debris was, but it freaked me out when it cleared.
snowhawk jockey is offline   Reply With Quote
Times are GMT -7.   It's 10:49 AM.
