Old 10-05-2012, 10:49 PM   #1
algie70 OP
Oddometer: 6
Hard FIRST start BMW F650 GS
My 2003 F650gs is struggling to start the first time. It's September in Phoenix, AZ so it's not the temperature. It takes about 10 cranks of the motor to get the first start after sitting all night. I can shut it off immediately and it will start in 2-4 cranks. It's only hesitating on the first start. I'm running a fuel injection cleaner through the tank now. Has anyone had this issue? I appreciate your input.
Mark
algie70 is offline   Reply With Quote
Old 10-06-2012, 05:25 AM   #2
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 712
Mark
You didn't mention mileage or maintenance; such as valve adjustment, spark plug replacement,
fuel filter/pressure regulator replacement....(?)
CycleDoc59 is offline   Reply With Quote
Old 10-06-2012, 07:50 PM   #3
algie70 OP
Oddometer: 6
It has 10500 miles and I had the 6000 mile service done at a certified BMW mechanic. I'm rolling up on the 12K service. If I can't resolve this, il just do it early. And everything on the bike is original. I bought it in December with 5200 miles on it. I was told that FI can be an issue with older F650s if they sit and to listen for squeak or squill coming from the FI when I turn the key prior to starting it. It was fine and worked flawlessly for 5k.
Old 10-07-2012, 06:30 AM   #4
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 712
Ok; it's but a baby mileage wise, but a clue may be so few miles
since it was built. Bad things happen, especially to fuel systems
when vehicles sit... My guess is the fuel filter/pressures regulator
is sticky. Some dingleberry decided that the regulator should be
clamped onto the end of the filter (?), as seen in this photo:
http://www.ascycles.com/detail.aspx?ID=31503. This gives the
item the silly price of about $110 dollars, and no substitutes.
Before assuming I'm correct, dig thru here, and maybe pose the
question to the collective on this forum (The Chain Gang):
http://faq.f650.com/GSFAQs/FuelInjectionFAQ.htm
Old 10-07-2012, 12:06 PM   #5
divimon2000
divimon2000's Avatar
Oddometer: 416
I'm sure there are many potential issues here, but what come to mind are:
Fuel Filter/Regulator clogging/dying
Pump on its way out
Injector dirty (only way to really clean is sending out, ie. "cleaner" won't do it)
Exhaust sensor
Airbox sensor
You may come closer to figuring it out before sending it to $$ BMW service. Try these one at a time:
1. Cold starting with a bit of throttle (one of my bikes requires it below 60 degrees)
2. Starting it only after waiting a real long time after you turn the key to let the pump pressurize more
3. unhook airbox sensor- sometimes null is better than a bad reading.
4. unhook exhaust sensor
F650 GS 2001
F650 GS DAKAR 2002
at least one should be running
divimon2000 is offline   Reply With Quote
Old 10-07-2012, 05:53 PM   #6
algie70 OP
Oddometer: 6
All good advice. I appreciate it. Il try it.
Old 10-13-2012, 03:05 PM   #7
algie70 OP
Oddometer: 6
I had some other people swear by Sea Foam. I'm running that tank now and it seems to be getting worse. I think your fuel filter/regulator idea is spot on. As the Sea Foam is doing its job, the filter is only clogging more. I ordered a new one yesterday.
Old 10-13-2012, 04:51 PM   #8
divimon2000
Oddometer: 416
Could be, I know they are expensive but..E10 has helped mess up more than two of my pumps/filters on combustion engines. Also scratch 02 exhaust sensor, and change for water temp sensor. Water temp is used on start up, my bad.
F650 GS 2001
F650 GS DAKAR 2002
Old 10-14-2012, 09:27 AM   #9
algie70 OP
Oddometer: 6
Are you using an additive to counter the E10? I was in the BMW shop the other day and they recommended it but they don't ride my bike. They also don't seem to know a lot about it. The world seems to favor the 1200s.
Old 10-17-2012, 01:40 AM   #10
RedRockSA
F650 GS
RedRockSA's Avatar
Oddometer: 2
Have you considered ...
.....the battery and are you adopting a "hands-off" the throttle start?
I don't want to upset the apple-cart (and all the flushing & filter replacement) I have a 2003 F650 GS as well and had a similar problem a few months back -
My solution/cure was:
  1. charge/replace battery
  2. before start give throttle 3 full turns
  3. do not twist throttle when starting
  4. keep starter depressed until motor catches or dies
The reasoning ....
BATTERY
I checked the battery and it was slightly low, so left it on charge overnight - next morning was smooth as silk..... ...the following morning was back to burlap sacking. Once again a charge on the ever-so-slightly below par battery did the trick.....but not for long.
Suspecting a 'surface charge' on the battery I tested whilst 'under load' of starting & got confirmation when the voltage dropped faster than a feather in a vacuum chamber. One new battery later and no problem!
THROTTLE
My habit obtained years ago with my Honda 500R (which required a more physical relationship) didn't help.
I am so used to giving the throttle a good wank together with a full body drop down on the kick-starter, that when the 650 was doing its 'cough'-'cough' start I just could not stop myself from trying to catch it with the throttle .... an absolute No-NO as it upsets all the readings and cannot set properly, resulting in a probable cut-off soon after, even with a new battery.
Also before attempting the first start with a new ( or re-charged) battery, give the throttle 3 full twists first (key off), remove hand and then attempt a proper key start.
Finally & very important...... continue depressing starter until motor either starts or cuts out entirely do not release the starter, if motor is turning over but not catching - wait for it to die or catch!
This starting process is a requirement of the 650 - necessary for correct readings and settings to take place & NO damage will occur.
RedRockSA is offline   Reply With Quote
Old 10-17-2012, 09:11 AM   #11
algie70 OP
Oddometer: 6
The reasoning ....
BATTERY
THROTTLE
RedRock
When I added Sea Foam to my fuel, the sputtery throttle effect got worse. This led me to believe that the fuel filter was getting bad and the effect of the fuel addidtive was exacerbating the filter problem because it was clearing the system. I changed the filter/pressure regulator last night (good times). The sputtering/surging stopped. The start is still a little slow. I have had my battery off and on the charger all week. I ordered a new sealed battery that should be here Friday. Cross your fingers. I think this combo will fix it.
I do not use the throttle at all when starting the bike. Why the three turns on the throttle before turning the key? I was under the impression that without the bike running, the throttle was ineffective.
Old 10-17-2012, 01:03 PM   #12
coletrain
All aboard!
coletrain's Avatar
Oddometer: 450
twisting the throttle 3 times "resets" the Throttle position sensor. It basically gives the "brain" the parameters it needs for closed throttle and wide open so it "knows" where the throttle is in order to start/idle/run. I do it with the key on, twist to wide open three times, key off. key back on and push in starter button, release starter button when running. Resetting the TPS is a good idea after long periods of non-riding.
All good advice above. These bikes like nice strong batteries. The moment the battery starts to go- all kind of weird stuff starts happening. If the new battery dosent fix your prob, try cleaning the idle control valve.
http://faq.f650.com/GSFAQs/HardStartingFAQGS.htm
North Georgia Tag-O-Rama
'01 F650 GS
CG#2727
coletrain is offline   Reply With Quote
Times are GMT -7.   It's 12:14 PM.
