Old 10-07-2012, 07:24 AM   #1
kingmildred OP
kingmildred's Avatar
Oddometer: 6
Rear Break Bleed
Hey All,
I'm a new 950 ADV owner.
I think the recall for the rear break was done but the breaking is soft to nonexistent.
Can somebody give me a clear method for bleeding the rear break?
Sorry for the noob question, I''d just like to do it right.
This is what happens when you find a stranger in the Alps!
kingmildred is offline   Reply With Quote
Old 10-07-2012, 07:59 AM   #2
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 986
Use the HOW
Originally Posted by kingmildred View Post
Hey All, I'm a new 950 ADV owner
Here's what you are lucking for.
Read the sticky at the top of our forum and use the HOW. Everything you could want to know is there- look first then ask the folks here at OC if you really need to
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..."
geometrician is offline   Reply With Quote
Old 10-07-2012, 08:26 AM   #3
kingmildred OP
Oddometer: 6
Yeah I saw that.
I'm just not sure how to "push the calipers back" during the bleed.
I'm off to buy a mini-pump, syringe and some .4.
Old 10-07-2012, 04:38 PM   #4
gefr
Life is a trip
gefr's Avatar
Oddometer: 3,125
You could use the following method
Use a hose fitting on the bleeder and leading to the brake fluid reservoir. Pump 10 times the brake lever and then hold pressed and loosen the bleeder. The lever stops at its end. Tighten the bleeder and start another cycle with ten times pumping the brake lever. Redo the whole procedure till the brake lever feels it has strong resistance. Keep an eye on the reservoir not to run out of fluid. Refill as needed.
Cheers.
There is always a reason!!
Old 10-07-2012, 07:36 PM   #5
kingmildred OP
Oddometer: 6
Yep.
Piece-o-cake.
Old 10-08-2012, 02:34 AM   #6
K2m
....58....
K2m's Avatar
Oddometer: 2,238
Use Motul 600 and completely change it once a year (at the start of Summer) and you will not any more problems. If you do have problems, it's your riding, change it more off-ten. This brake runs hot, very hot, and builds up moisture in the line during the heat cycling.
http://www.linkint.com.au/motul_rbf600.html
"100% synthetic, RBF 600 FACTORY LINE is a polyglycol-based brake fluid exclusively designed for races. Developed to resist high temperatures and wet-weather conditions, RBF 600 has a high dry boiling point of 312°C and a wet boiling point of 216°C. This ensures effective braking under extreme racing or rainy conditions. Couple this with its outstanding anti-vapor lock performance, RBF 600 has become a well-trusted brake fluid in many races."
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 10-09-2012, 05:21 AM   #7
BIG-E
AKA; Mongo-E
BIG-E's Avatar
Oddometer: 1,748
No, No! Do not use 4 break fluid, ONLY use 5.1 motorex!
Replace the pads with the Galfner "green" pads and if you have boiled your existing fluid, be sure to de-glaze your rotor.
You won't beleive how much better these pads work!
Take care Brother, Eric.
"If my Technique Improves, so will my riding"!
BIG-E is offline   Reply With Quote
Old 10-09-2012, 06:40 PM   #8
kingmildred OP
Oddometer: 6
Cool2
Thanks for all the advice.
The bleed was simple once I figured out what I was doing. Break worked fine back and forth through the city today.
I used dot 4 because I figured that would be easiest to get my hands on quickly.
A scotchbrite pad and some 5.1 followed by the green galfers should get me where I need to be.
Soon:
New tires - Conti T/As (I think)
New chain and sprockets (maybe 16 up front)
Figure if I'm jetted properly for my akropovic exhaust (pops and gurgles a bit on deceleration)
Get rid of bubbley decals
Get rid of mickey mouse mirrors (I like the looks of the highway dirtbike stuff)
And the list goes on...
Old 10-10-2012, 09:15 AM   #9
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,105
If you have a good bleed with the DOT 4 I'd leave it be.
KTM calls for DOT4 anyway.
If you want to go with something fancier, I've also had good luck with the Motul 600 and prefer it over the 5.1 fluid I've run at the racetrack. YMMV, of course.
Steve
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Times are GMT -7.   It's 01:29 AM.
