Old 10-07-2012, 07:50 PM   #1
HoloHolo OP
2 wheels !!!!
HoloHolo's Avatar
Oddometer: 259
K60 front wobble
I have a wobble at around 45-50mph with these tires? *I took the rim to BMW dealer and had the rim with the tire on it balanced but the wobble still exist. I also check to make sure the triple tree wasn't loose.*
Has anyone else had this issue. They also seem to slide quite a bit on the dirt. What are these recommended for? *50/50 dirt? *If so what would be a more aggressive dirt tire?
Any suggestions, thanks
HoloHolo is offline   Reply With Quote
Old 10-07-2012, 08:20 PM   #2
ebrabaek
Oddometer: 4,757
I only have it on the rear (K-60), and it is 18 inch.... front is a Karoo-T.....no wobbles.....
Erling
Old 10-07-2012, 11:40 PM   #3
Nacho911
Nacho911's Avatar
Oddometer: 463
Change pressure. Go with the F800 manual on pressure. Air it down from spec 41psi to 32-36 PSI. Try that. Also add a run flat tire goo, as it also balances.
N
Nacho911
Nacho911 is offline   Reply With Quote
Old 10-08-2012, 05:07 AM   #4
Loutre
Cosmopolitan Adv
Loutre's Avatar
Oddometer: 3,743
It's a common problem on the front. It'll go away in a few hundred miles/kms.
Loutre is offline   Reply With Quote
Old 10-10-2012, 03:40 PM   #5
albany23
Aficionado
Oddometer: 77
I'm sorry, but it will not go away. I installed a fresh set and took the bike out for a 1500km ride. Lots of highway riding, then mountain passes and off-road.
I had a wobble and lots of vibration up until 40kph, then it was gone. After 120 kph, the vibration was really bad, worse than a TKC80.
Off-road, they were very slippery, because of the hard compound. The new K60 Scout design for the rear tyre might be good for a long lasting tyre, but this is not a 50/50 tyre. They scared the crap out of me on loose gravel, and i dropped the buke more times that i want to remember.
In all, after more than 1500kms, the vibration is still there, the wobble is still present, so i went back to my old set of TKC80's. It might not be a great road tyre, but on the beach is smokes any other 50/50 tyre out there.Looking forward to a fresh set of Karoo T's.
<a href="http://jupiterstravellers.org" target="_blank"><img width="120" height="60" border="0" src="http://jupiterstravellers.org/buttons/linkbutton_120x60.jpg" alt="The Ted Simon Foundation" title="The Ted Simon Foundation" /></a>
albany23 is offline   Reply With Quote
Old 10-08-2012, 06:56 AM   #6
NCD
Dirty Hairy
NCD's Avatar
Oddometer: 500
The one I just put on did that. I deflated it and rotated it 180 on the wheel
Wobble gone. Maybe the red balance dot was wrong on some.
NCD is offline   Reply With Quote
Old 10-08-2012, 07:12 AM   #7
puckinet
Safety third
puckinet's Avatar
Oddometer: 346
Very common on a new set, air down to about 35 PSI, the tire is very hard and takes a little wear because the sides are a little squarded.
Our famous last words "It doesn't look too bad".
08 KTM 450 EXCR
2010 BMW F800GS
Rick
puckinet is offline   Reply With Quote
Old 10-08-2012, 10:17 AM   #8
njoytheride
NJOYN' THE JOURNEY
Oddometer: 947
my front k-60 started the wobble after a few thousands miles. Tried balance, air pressure with no luck. Put a TKC 80 on the front and the wobble went away. Love the K-60 back tire but giving up on the front tire.
njoytheride is offline   Reply With Quote
Old 10-08-2012, 03:53 PM   #9
scarygary
Drawing blanks
scarygary's Avatar
Oddometer: 383
I would check out your steering head bearings for a notch developing when your steering goes back to center. The K60s could be magnifying the problem that already exists.
scarygary is offline   Reply With Quote
Old 10-08-2012, 05:53 PM   #10
HoloHolo OP
2 wheels !!!!
HoloHolo's Avatar
Oddometer: 259
The steering head seems smooth and not loose. It has to be the tire. I will check the pressure and take it for a spin this weekend. I already have over 200 miles in the tires.
Frustrated with this front tire and the rear k60 sure does slide in dirt and gravel.
But I am use to a dirt bike.
Old 10-09-2012, 10:20 PM   #11
Kobie
Oddometer: 1
Wobble ???
I had the K60's fitted front & rear last week. These tyres must be the most dangerous on wet tar, thought I was riding in thick mud (at 180k/ph) Maybe I was pushing it a bit. Have'nt been on the dirt yet, will let you know.
Kobie is offline   Reply With Quote
Old 10-18-2012, 11:18 PM   #12
Steveman
Steveman's Avatar
Oddometer: 471
wow 180 in thick mud, thats cool
Steveman is offline   Reply With Quote
Old 10-10-2012, 09:08 PM   #13
HoloHolo OP
2 wheels !!!!
HoloHolo's Avatar
Oddometer: 259
Thanks for the input. The bike came with a set of new tkc80's and I think I may just put those on. I prefer the dirt and with the wobble and the sliding was a little outside my comfort overall.
This is the most street bike I've had and the tkc's look more similar to any other dirt tire I've had in the past.
Old 10-18-2012, 07:45 PM   #14
fletman
fletman's Avatar
Oddometer: 21
I get a slight shake at about 70, but nothing either side. I like the Heidenau's but have a lot of difficulty getting them in my part of the world. It's hot here and the roads are not overly tire friendly, most cars chew through a set in about 12-15 thousand miles. With that in mind the TKC's just wouldn't last.
I need to replace my rear K60 as it got a nasty spike through it, came across this post whilst searching alternatives. The front (K60) is new, looking at an alternative for the rear if I can't source the 60 for the back.
Any ideas??
Stupidity got us into this mess, then why can't it get us out?
Will Rogers
fletman is offline   Reply With Quote
Old 10-19-2012, 03:08 AM   #15
machinebuilder
Oddometer: 1,127
you do know these tires are 35psi max inflation.
air down to about 30psi they will settle down.
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table
machinebuilder is offline   Reply With Quote
Times are GMT -7.   It's 04:41 AM.
