Old 10-09-2012, 09:04 AM   #1
BeamingBeagle OP
n00btube
BeamingBeagle's Avatar
Oddometer: 87
2001 r1150gs slight knocking noise
Hey all. I hear a slight knocking on my bike. If I'm facing the bike it's most clearly heard from the left side.
The valves sound really nice. I've done the chain tensioner mod which is on the other side.
Maybe I just need to rebalance and idle the carbs?
It's not that there's any problem right now I would just like to prevent a complete rebuild or some kind of worse failure on a trip. Any advice would be appreciated. Thx.
BeamingBeagle is offline   Reply With Quote
Old 10-09-2012, 09:13 AM   #2
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,537
Engine knocking to the untrained ear is deceptive and often misleading. It is rare that the boxer engine blow up after the owner reports an engine noise. You'll need to provide more details regarding the so-called knock so we can accurately diagnosis your issue. So, here are the hints; 1- Frequency of the knock. 2- From what area of the engine does the knock come from? 3- Does it go away with RPM changes? 4- Clutch in or out? 5- Hot or cold? 6- What engine oil is in the engine ans how many miles on this oil? What brand filter? Finally, try this. When you next cold start the engine, let it run for 10 seconds cold and shut it off with the kill switch leaving the key on. Count the seconds from the time you shut it off and when the oil light comes on and report back here.
def is offline   Reply With Quote
Old 10-09-2012, 09:41 AM   #3
mike54
You don't get me
mike54's Avatar
Oddometer: 13,308
It could be the throttle bodies. The shaft wears and allows the butterfly to move in pulse with the intake. I would call that a tapping sound but some might call it knocking. Easy enough to put a finger on the shaft while the bike is running and see if it makes a difference.
A genius is the one most like himself. - T. Monk via S. Lacy
Do stand up guys lie?
mike54 is offline   Reply With Quote
Old 10-10-2012, 06:31 AM   #4
Ron from BC
Ron from BC's Avatar
Oddometer: 1,394
+1
There is a flat silver plate which is on the engine side of the throttle body that the throttle cable connects to. When I put a finger on that plate and apply some pressure the clicking noise even stops. I have the rebuild kit for both TB's which will be installed this winter.
For now, it sounds like a set of false teeth from a trick and joke shop
'02 BMW R1150 GSA
'06 Kawasaki KL250H Super Sherpa
Ron from BC is offline   Reply With Quote
Old 10-11-2012, 07:30 AM   #5
jachard
Oddometer: 603
As a matter of curiosity I did the cold shut down test you outlined above and got ~12sec. on my bike. I would assume the longer the time, the better the health of the engine. Is there a number which indicates "bad"?
Cheers, James
2005 640e
2012 R1200GS Rallye
1993 Porsche 964 RS
http://octaneworks.wordpress.com/
jachard is offline   Reply With Quote
Old 10-11-2012, 09:32 AM   #6
def
def's Avatar
Oddometer: 10,537
Cheers, James
This test is rather crude and would show signs of loose lower end bearings if the cold oil pressure was not sustained for several seconds as you observed.
The trick is to do this occasionally before you change oil and after you change oil. You'll get a reasonable baseline with which you can judge oil viscosity, engine bearing clearance and how temperatures effect oil viscosity and engine clearances.
I would speculate that good 15w-50 oil in a boxer with normal bearing clearances at 75 F. ambient, the ~12 seconds cold oil pressure bleed down you observed is normal.
Old 10-11-2012, 10:07 AM   #7
def
def's Avatar
Oddometer: 10,537
I just did my oil pressure bleed down on my '01 with ~50,000 miles and old 15w-50 Mobil 1 oil. About 10 seconds cold (ambient is 70 F.). I had some errands to run so when I returned to the garage with the bike hot, I did it again. This time about 2 seconds with hot oil and engine. I consider those nominal times. Remember, there are many variables in this test so use caution when evaluating the information.
Old 10-11-2012, 04:21 PM   #8
BeamingBeagle OP
n00btube
Oddometer: 87
Thumb
Wow guys, thanks for all the advice! Sorry it's taken me a while to get back with the answers but here they are along with a link to a youtube video I made trying to capture idle and a slight rev.
link to video:
https://www.youtube.com/watch?v=iVqO...1&feature=plcp
1. frequency seems pretty consistant
2. sounds like just under the cylinder head (if your facing the bike front left)
3. No, it's more noticable when it's idling but I can still feel it (or so I think) when its up around 4000
4. clutch in or out has no effect
5. pretty consistant hot and cold (maybe a little more pronounced when hot)
6. 20w-50 castrol synthetic. almost 3000 on this change (engine has 48,000) filter is bmw,
Cold start test was 6 seconds until light came on
And thank you!!!
Old 10-13-2012, 10:54 PM   #9
def
def's Avatar
Oddometer: 10,537
link to video:
And thank you!!!
Your Youtube sounds normal. You may want to check the alternator belt.
Old 10-09-2012, 02:56 PM   #10
Jazz62
Jazz62's Avatar
Oddometer: 1,035
Jazz62 is offline   Reply With Quote
Old 10-10-2012, 08:39 AM   #11
def
def's Avatar
Oddometer: 10,537
No carbs on your boxer...those are fuel injection throttle bodies. Before you tackle any adjustments, read some more about how and why the adjustments are made. Also DO NOT DISTURB THE LITTLE BLACK BOX ON THE LH SIDE THROTTLE BODY. That is the throttle position sensor and is factory set and marked with blue paint. Also, do not adjust the throttle stop screws. Doing so will leave you with a bike that does not run correctly. You need to better understand how the fuel system works on the boxer before you break out the tools. I would recommend your buddy up with someone experienced in your neighborhood who will keep you out of trouble while you learn just how and why adjustments are carried out.
Old 10-10-2012, 08:58 AM   #12
mike54
You don't get me
mike54's Avatar
Oddometer: 13,308
Calm down. He hasn't responded to your first suggestion yet.
I second def's suggestions in his previous post. It may help to use a stethoscope/long screwdriver/woden dowel/piece of hose to try to isolate where the 'knocking' is comming from.
Old 10-11-2012, 04:25 PM   #13
Ron from BC
Oddometer: 1,394
I must need new speakers....sounds like an 1150gs boxer to me. Not trying to be funny here, perhaps it is my speakers?
'02 BMW R1150 GSA
Old 10-11-2012, 04:34 PM   #14
Stegerman
MotoOCD sufferer
Stegerman's Avatar
Oddometer: 588
I agree. I'm no JVB, but that sounds like my 2000 and it was just at the mechanic, not for engine issues, but they checked it over it gave it the thumbs up.
2000 R1150GS- ZenPig
2003 F650GS (sold)
formally trained to screw with people's minds..
Stegerman is offline   Reply With Quote
Old 10-11-2012, 04:36 PM   #15
BeamingBeagle OP
n00btube
Oddometer: 87
I don't ride with anyone who has an 1150 so maybe the noise/feeling is nothing but normal boxer click-ity clack?
Times are GMT -7.   It's 04:57 AM.
