Old 10-09-2012, 03:06 PM   #1
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
video about rusted piston
I had made a video...Rust bucket...here's a link for it.
http://www.youtube.com/watch?v=FwcaSwqVMM0
It was posted somewhere on ADV back in the day.
It was 3 B50's that I disassembled.
Well, now I found some old video tape and created a video about trying to hammer a seized piston through the bore on one of them.
Oh the horror, a 3lb sledge whacking away on the piston dome!
too many...
I have completely lost count
and here's my channel...
http://www.youtube.com/user/2manyrides?feature=mhsn#p/u
2manyrides is offline   Reply With Quote
Old 10-09-2012, 06:40 PM   #2
killfile
49/50
killfile's Avatar
Oddometer: 353
the horror, the horror!
sounds like this was quite a while ago since you just found the video tape... how did this one turn out?
Gallery MotoSF & Neoedo
killfile is offline   Reply With Quote
Old 10-09-2012, 07:54 PM   #3
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
A salvage job to save whatever I could from the rusty hulk.
The sleeve cracked at the bottom as the piston was driven through.
I did save the jug and it's good fins though. (in case I ever need one)
Throughout that motor things were rusted and deeply pitted.
Tranny, clutch ect...
Saved a bunch of pieces, didn't intend to worry about the crank, cases, ect...
It was 2008
Don't misunderstand...as I never had any intentions of rebuilding that motor!
There's other candidates with a better start.
It was in a down time while waiting for one that I was rebuilding.
Since I was going at it, I figured I'd stay busy by pulling some of these apart.
too many...
Old 10-14-2012, 06:37 PM   #4
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,414
When there's a will, there's a way....
but I think you need a taller work bench / engine stand assembly.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
Old 10-15-2012, 08:59 AM   #5
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
Ha, ha!
Well ya use what you got. The wrought iron table base served as a strong base to mount the B50 stand to.
too many...
Old 11-06-2012, 07:41 PM   #6
LashLarue
LashLarue's Avatar
Oddometer: 163
Hot oil
What was that EVOO for cooking? Tell us a little about 'the hot oil treatment". How hot, how much, how long?
LashLarue is offline   Reply With Quote
Old 11-07-2012, 09:22 AM   #7
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
the oil scene
Well,
I had been posting a bit to field ideas about how to unstick this thing. It had the bore soaking in penetrating oil for weeks with NO help at all.
Olive oil was suggested as the medium. I was told that hot oil poured into the chamber would do the trick.
Let me again mention the circumstances with this motor...
This bike had sat in the rain in a field for more than 15 years with the carb off. It was basicly "fused" with corrosion.
The suggestion was that as the oil's heat transfered to the parts, I'd here a click or a "snap" as it expanded and unstuck. I never heard a click.
After the application of hot oil I began to beat the sucker again as seen in the driveway. It was not until I gave it "all I got" that it gave way. 30+ whacks well defined wasn't enough. I had to wail on it.
I'd have to think that a lesser fused item would break loose with the hot oil method. How hot was the oil?
I had it at flash point. Very dangerous!
http://advrider.com/forums/showthrea...ighlight=tr5mx
A link to the original discussion...(in the link above)
Post # 17 by
bk brkr baker
gave me the idea...
A block of wood was no good.
during the heavy hitting a 6"X2" nipple, a 2" cap and coupler were utilized to better meet up with the top of the piston.
You can see the deformed cap which resulted from hard hits!
Hope that answers your Q...let me know if not...
too many...
2manyrides screwed with this post 11-07-2012 at 09:29 AM
Old 11-07-2012, 09:50 AM   #8
What?
curmudgeon
Oddometer: 360
It took me a minute to figure out how you were "talking on the phone" and getting the camera to record it.Did you come up with the "put one radio near the camera and talk into the other" on your own? I want to know who to thank when I steal the idea.
Mike
What? is offline   Reply With Quote
Old 11-07-2012, 10:44 AM   #9
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
Wicked ha, ha...two way radios
Creative minds want to know what was my low tech method of wireless communication with the camera.
Works great on the trail when discribing scenes.
Cool to have the acknowledgement beep in there when you let up the button.
Use this method with my approval. Thanks for speaking up about it!
Cheers...
too many...
Old 11-07-2012, 07:41 PM   #10
TwilightZone
Oddometer: 3,111
>"I'd have to think that a lesser fused item would break loose with the hot oil method. How hot was the oil?"
Dinna try heading the barrel with a rosebud tip (oxyacetylene torch) ???
"I don't really know, I've been too busy falling down."
TwilightZone is offline   Reply With Quote
Old 11-08-2012, 05:49 AM   #11
2manyrides OP
shifty charactor
2manyrides's Avatar
Oddometer: 1,632
Tried a propane torch as seen in the video...
No results....
Don't have a torch, or a press, or much of anything related to a real shop besides wrenches.
I have a 3lb sledge and a splitting maul....
too many...
Old 02-17-2013, 08:59 PM   #12
LashLarue
LashLarue's Avatar
Oddometer: 163
I used the "fire" method successfully after soaking an engine for 8 months in various concoctions. First time I tried fire, it did not work. Second time, no worky. Third time was a charm but I did it different. I filled it with leftover coleman fuel, burned it until it was out of fuel waited 5 minutes for safety, and repeated. After the third fire I hammered it like heck and it came free but what still a B until it cleared the cylinder.
I never heard a pop either and it did not move until I knocked the stuffing out of it (and damaged the cylinder). That was ok, I wanted the rest of the parts.
The burn time was about an hour for the three burns. Depending upon how much fuel you can get into the cylinder, you may have to do more or less. Just keep heat on it for an hour.
Times are GMT -7.   It's 02:16 PM.
