Old 10-18-2012, 05:29 AM   #1
sergiu_sergiu OP
sergiu_sergiu's Avatar
Oddometer: 25
Just another ktm 640 adventure rebuild
Hello everybody!
This summer I bought a ktm 640 adventure [IMG]file:///C:/Users/SERGIU%7E1.GIU/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/IMG]. After riding all summer, i decided that this bike is a keeper so, as winter is coming i'm planning a general rebuild. The previous owner rode the bike for about 50 k and had done some improvements, also an engine rebuild about 10 k ago. As i was surfing the net for bits and pieces to prepare for the project, I came across a 2003 ktm duke 2 barely used with some cosmetic problems so i decided to get it as a donor bike for the adventure.
The plan is this:
- use the duke engine (that comes with a hydraulic clutch and high flow cylinder head) after water pump rebuild and valve check
- check and replace (if needed) all bearings
- front and rear suspension service (haven't decided i will try to do it myself or send them to a specialist)
- use the duke electrical wiring (the one from the adventure is bye bye )
- powder coat the frame black
- paint the entire bike (i was thinking also black but open to suggestions )
And the list continues on and on but more during the build [IMG]file:///C:/Users/SERGIU%7E1.GIU/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/IMG]
As soon as i will figure out how, i will post some photos.
And now some questions:
The new duke engine makes a ticking noise when rpm is very low, the previous owner said it is the automatic decompressor, is it true?
I mounted a trailtech vapor kit on the adventure and connected the power wire directly to the battery, and the wire is now toast - do you have idea why?
Are the duke headlights better than the adventure ones ? (the adventure headlight are an old petrol lamp [IMG]file:///C:/Users/SERGIU%7E1.GIU/AppData/Local/Temp/msohtmlclip1/01/clip_image002.gif[/IMG])
Any other suggestions are welcome!
Here are some more picture of the strip down:
This is the home made front-end that i intend to reuse, but with some mods
sergiu_sergiu screwed with this post 10-26-2012 at 06:35 AM
sergiu_sergiu is offline   Reply With Quote
Old 10-18-2012, 06:09 AM   #2
mrt10x
Dumba$s Jarhead
mrt10x's Avatar
Oddometer: 3,204
You are posting your pictures wrong... you need to click on the "direct link" address in photobucket and copy and paste.
We are enmeshed in the cancerous discipline of "security." And in the worship of security we fling our lives beneath the wheels of routine - and before we know it our lives are gone.
mrt10x is offline   Reply With Quote
Old 10-18-2012, 07:52 AM   #3
SRG
SRG
SRG's Avatar
Oddometer: 1,259
Ticking/clacking sound at low RPM is the auto decompression system. Idle should be set at a high enough RPM (+_1800) so the auto decom. doesn't kick in and make the sound. You should hear the same sound when you shut the motor off, just before it stops.
Lazy Traveler
SRG is offline   Reply With Quote
Old 10-18-2012, 02:07 PM   #4
clintnz
Trans-Global Chook Chaser
clintnz's Avatar
Oddometer: 3,426
Yep, & it will be much louder on a low km's motor - the mechanism is probably getting a little worn & quieter on your 640 adv.
Cheers
Clint
'03 KTM 640 LC4 Enduro
The wilderness, the desert - why are they not crowded
.................................................. .....with pilgrims?
clintnz is offline   Reply With Quote
Old 10-22-2012, 08:23 AM   #5
sergiu_sergiu OP
Oddometer: 25
So this weekend I got around to finish the whole disassembly on both the bikes and Im going to send of the frame and the rest of the parts for powder coating. Here is a question: can I powder coat the aluminium rims? The heat from the oven wont damage them?
Regarding the headlight I decided to go with the duke assembly as the duke bulbs are 65W compared to the 55 w adventure.
Im sorry there are no picture, but I forgot my camera at home and the garage is about 20 km outside the city this is why I can work only weekends .
Old 10-22-2012, 08:58 AM   #6
LukasM
Oddometer: 5,415
Heat for powdercoating is only around 200C, no problem for the aluminum.
Old 10-26-2012, 07:01 AM   #7
sergiu_sergiu OP
Oddometer: 25
ok, so this is where I'm at right now - general strip down complete:
Old 10-26-2012, 07:17 AM   #8
sergiu_sergiu OP
Oddometer: 25
now for the interesting part to begin. The front fairing is home made by the previous owner and altough it's a lot better looking and mode practical than the original one, i think there is room for improvement. So i asked my father to send me the grinder, and after a 15 hour train trip it was in my hands ready to do some damage
As i had the duke front lying around i decided to use this as a donor. If i could manage to use the duke lamp, i would have better light (65w instead of 55) more compact and light mounting system and a perfect fit to the duke electrical wire that i intend to use, so let's cut away
Architect style - no measurements
An epiphany :
and done:
I think it look's a lot better now i it will me more functional.
sergiu_sergiu screwed with this post 10-26-2012 at 08:27 AM
Old 10-26-2012, 12:35 PM   #9
Mat
Mat's Avatar
Oddometer: 667
If you want stronger lights, consider a HID upgrade. Quite cheap and relatively simple with the ADV lights...
And you get a nice defined low beam and daylight with the high beams.
I think there might be a more scenic route somewhere...
Mat is online now   Reply With Quote
Old 11-01-2012, 04:42 AM   #10
sergiu_sergiu OP
Oddometer: 25
The guy that makes my stickers made me very happy the past day se below why :
So the rebuild is turning out to be veeeeeeeeery slow with no chance of ending before march I think....
For now Ive sent of the frame and other metal parts that need welding to be done, and after that I will be sending them to powder coating. I what to make an upgrade to my center stand, so if you know the dimensions and angles in the sketch below, please let me know.
Old 11-06-2012, 01:09 AM   #11
sergiu_sergiu OP
Oddometer: 25
The welding is almost finished, the only thing left is the center stand. If anyone could measure and tell me the dimensions for a b c and d in the picture above, that would be GREAT . I now realize that I should have done this before striping the bike, but now its too late ..
Old 12-06-2012, 01:13 PM   #12
juames
Have Fun, Don't Die!
juames's Avatar
Oddometer: 2,445
Any updates?
2005 KTM 950 Adventure
Roaming Rally 2011RR12 RR13 RR14 RR15
"I don't hate people...I just feel better when they are not around." - Henry Chinaski
juames is offline   Reply With Quote
Old 01-10-2013, 07:22 AM   #13
sergiu_sergiu OP
Oddometer: 25
Originally Posted by juames View Post
Any updates?
well, the fame has been powder coated black, and all the body has been sent to the painter. no progress for now because of very cold weather :(
Old 12-06-2012, 10:23 PM   #14
supercoyote
Oddometer: 88
i'm pretty interested in that vinyl set. Would like to see the finished product if it ever comes out
There's only one rule that I know of, babies - God damn it, you've got to be kind.
supercoyote is offline   Reply With Quote
Old 01-10-2013, 07:25 AM   #15
sergiu_sergiu OP
Oddometer: 25
belive me i'm very anxious as well but for now, to cold in the garage for work.
Times are GMT -7.   It's 02:43 PM.
