Old 10-23-2012, 07:55 AM   #1
Mambo Dave OP
Mambo Dave's Avatar
Oddometer: 2,481
What to use to clean black chain lube off of aluminum rims easily?
Obviously I don't want to use an abrasive on aluminum rims to clean them, but I was somewhat shocked that pure strength, then diluted strength to soak, Simple Green didn't really clean much chain lube off of the rear wheel of my DR650.
I'm no neat freak with the bikes since I ride them at least six days a week, but the one time I've thought "Yeah, maybe I should wash the DR..." it didn't really get clean looking with the goop on the rear wheel, sprocket, etc.
Should i go buy a little kerosene? Does WD-40 still cut through modern lubes? (I think the spray-can lube I have at home is PJ1 Black Label).
Mambo Dave is offline   Reply With Quote
Old 10-23-2012, 07:57 AM   #2
Offcamber
Offcamber's Avatar
Oddometer: 1,108
I use Simple Green straight without diluting it. Its safe on the rims and is an excellent grease cutter....
"I don't ride to be seen....I ride because I want to disappear...."
Halfthrottle
"The difference between genius and stupidity is -- genius has its limits."
~Albert Einstein
Offcamber is offline   Reply With Quote
Old 10-23-2012, 07:58 AM   #3
Wlfman
Wlfman's Avatar
Oddometer: 869
Simple Green
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 10-23-2012, 08:02 AM   #4
urbanXJ
urbanXJ's Avatar
Oddometer: 2,140
WD40 on a rag
Also, the chain cleaner that you hose off with water seems to works really well.
...SPEEDING PAST THE LINE OF GOOD TASTE...
urbanXJ is offline   Reply With Quote
Old 10-23-2012, 08:33 AM   #5
DAKEZ
DAKEZ's Avatar
Oddometer: 17,983
Originally Posted by urbanxj View Post
wd40 on a rag.
+1
"Be who you are and say what you feel, because those who mind don't matter, and those who matter don't mind."
— Dr. Seuss
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 10-25-2012, 08:07 PM   #6
farmboyfz1
Oddometer: 33
Wicked
Originally Posted by dakez View Post
+1
+ 2 on WD-40
farmboyfz1 is offline   Reply With Quote
Old 10-23-2012, 08:08 AM   #7
CharlestonADV
Oddometer: 107
I've found that Honda aerosol cleaner / wax works most of the time for grease and bugs. For stubborn stuff I spray WD 40 on a rag.
CharlestonADV is offline   Reply With Quote
Old 10-23-2012, 08:31 AM   #8
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 8,130
Send a message via ICQ to Yossarian™ Send a message via MSN to Yossarian™ Send a message via Yahoo to Yossarian™ Send a message via Skype™ to Yossarian™
Just use a little diesel / kerosene. It'll cut through caked on asphalt and tar, so it will work great on chain lube as well.
It's cheap and easily obtainable. It won't damage the finish.
Old 10-23-2012, 09:20 AM   #9
Mambo Dave OP
Mambo Dave's Avatar
Oddometer: 2,481
Thanks guys.
I'm either surprised the Simple Green is working for some, as I stated it was pretty useless, or that the chain lubes they use are cut by it when PJ1 Black isn't.
Old 10-23-2012, 09:26 AM   #10
DAKEZ
DAKEZ's Avatar
Oddometer: 17,983
p.s. STOP using chain lube. There is NO valid reason to spray "Chain lube on a modern O-Ring/ X-Ring chain. NONE.
Spray a bit of Teflon lube every 400 miles or so to help with the chain to sprocket contact...
All the "won't fly off" chain lubes trap dirt and destroy the the O-rings, cutting chain life in half (or worse)
— Dr. Seuss
Bib
Old 10-23-2012, 10:55 AM   #11
Human Ills
Useful Idiom
Human Ills's Avatar
Oddometer: 19,485
polishing compound.
I like to use ATF
Human Ills is offline   Reply With Quote
Old 10-23-2012, 12:42 PM   #12
Wlfman
Wlfman's Avatar
Oddometer: 869
WOW I guess my current chain that is sitting at 25K miles on it (and the two prior that each got 20K+) that I use Chain Wax on after every ride would have lasted 50K??? Actually the chain is still fine, just need new sprockets..
Wlfman screwed with this post 10-24-2012 at 05:25 AM
Old 10-27-2012, 01:20 PM   #13
PT Rider
Oddometer: 485
Here's a drawing of an o-ring (x-ring, whatever) chain:
Note that the ring seals in lube between the pin and the bushing, but the bushing to roller surface is not lubed by the sealed lubricant.
Here's what RK chain says: Use formulated O-ring chain cleaner or other similar product to keep dirt from building up around link plates and rollers. Don’t use a wire brush or pressure washer. If your chain comes in contact with water, be sure to use a moisture displacement (like WD40). Lubing an O-Ring chain is vital for maximum wearlife. All RK O-Ring chains are injected at the factory with a lifetime supply of internal lubricant. The purpose of an O-Ring lube is to keep the chain from rusting and the O-rings from drying out. Use a lubricant specifically designed for O-Ring Chains.
http://www.rkexcelamerica.com/faq.html#oring
I agree, the gunky chain lubes are old school. I use an industrial roller chain lube that has moly and graphite in an evaporating penetrating liquid. DuPont has a chain lube in a 4 oz. drip bottle. The DuPont blue can multi purpose teflon lube has been reformulated and is no longer adequate for chains. PJ1 blue label is good.
It's not what you look at that matters, it's what you see.
Henry David Thoreau
PT Rider is offline   Reply With Quote
Old 10-31-2012, 01:26 AM   #14
atomicalex
silly aluminum boxes
Oddometer: 595
I use, um, chain cleaner. Usually the kind with some citrene or limonene in it. Amazing that it works on chains AND wheels!
Katherine - F650GSa
atomicalex is offline   Reply With Quote
Old 01-13-2013, 11:19 AM   #15
atomicalex
Oddometer: 595
I just had to do this, and since my chain cleaner was not immediately at hand, I used WD-40. And it worked!
Katherine - F650GSa
Times are GMT -7.   It's 11:44 PM.
